Question about Compaq iPAQ MP4800 Multimedia Projector
I am trying to use the DVI connection of my Compaq MP4800 projector with a Motorola DCH3200 cable box, but it doesn't seem to be picking up the signal. I'm using a 25ft HDMI to DVI cable and am sure the cable is fine since it worked when connected to my TV. On my cable box menu I can change the output to DVI or HDMI, 480i, 480p, 720p, and 1080i, but none seem to make it work. Two times under DVI it appeared on the projector for half a second then went away. Under 480i and 1080 though the projector says "Input Signal Out of Range. Please Change Display Mode". Also, sometimes a blue message appears on the TV saying "your box is not authorized to receive high quality hd content through this digital connection." Not sure what that means since I have the HD channels. Any ideas? Thank you, Jason
PABLOCSA
  • 1124 Answers
SOURCE: External microphone not working
Check first if your sound card is working properly.
My Computer >> Right click...Properties >> hardware >> Device manager >> Sound
Then go to Start >> Control Panel >> Sound and Audio Devices .........hit ADVANCED
one dialog appears MASTER VOLUME >> Go to OPTIONS >> Then PROPERTIES..........
CHECK the MICROPHONE...........Hit OK.............
This will be fixing your problem (if your sound card is working well)
Posted on Oct 30, 2008
SOURCE: ipaq mp3800 projector--no source found check signal cable
compaq pesario c700 audio drver for this link
Posted on Jan 06, 2009
Geekman
  • 32281 Answers
SOURCE: Connecting my laptop to my new TV
To convert VGA format to HDMI format you need a piece of hardware, check this WEB site.
http://www2.dvigear.com/convert-scaler-video-pc-hdmi.html
Posted on Feb 23, 2009
sijudoniston
  • 134 Answers
SOURCE: no input signal on monitor after changing resolution
While booting press F8 , Go to safe mode and change the screen resolution and reboot the system.
Hope this helps
Siju.D
Posted on Nov 12, 2009
  • 23 Answers
SOURCE: When I connect the projector to my PC after the
you may need to turn on dual monitor on your computer. sometimes just restarting the PC while connected will do it as well.
Posted on Mar 13, 2011
Where is the serial number on Motorola dch3200?
MAC I D but I would use chat and they should help.
Mark
Motorola support
Jun 15, 2014 | Arris SURFboard SBG900 802.11g/b...
Cannot get image on screen from xbox 360 to mp3800 using hdmi to dvi cables
mp3800 can not got the HDMI source,even if you use the "HDMI TO DVI" cable
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 12, 2014 | Compaq iPAQ MP3800 Multimedia Projector
Motorola DCH3200 cable box: sound and sometimes video cutting out
Sounds like your SNR is getting too high and causing the signal to overload. A few things can cause this a bad splitter that causes the signal to bleed and introduces noise, or a more common issue is having a weak signal coming from the cable provider and once it goes through a splitter it causes the signal to become to weak to be stable.
Since it sounds like your cable has been working up until recently, you may have had a cable or splitter go bad.
Call comcast and have a technician come out and test the line.
Sep 11, 2009 | Motorola Televison & Video
I am trying to hook up my panasonic tc-32lx700 tv to a motorola dch3200 cable box and i am totally confused! Help!!!!!!
I can help you but this may take a while with this method.
What do you have connected where at this point.
Give me from and to information:
ie: from the audio out on the cable box to video 1 audio in in the TV.
Apr 15, 2009 | Televison & Video
Hdmi connection problem
it does do dvi-d for computer, but does not handle high-definition video. it does not have the same resolution.
Mar 14, 2009 | InFocus Proxima DP6155 Multimedia...
Connecting Macbook with a compaq MP1400 digital projector
You're going to need a conversion dongle that goes from the Mini-DVI to VGA.
Then:
  1. Connect one end of the projector signal cable to the Video Graphics Array (VGA) connector on the projector.
  2. Connect the other end of the projector signal cable to the Digital Video Interface (DVI) connector or VGA connector on the notebook computer and tighten the screws.
  3. Connect the projector power cord to the power cord connector on the projector.
  4. Connect the other end of the power cord to an electrical outlet that is easily accessible and close to the projector.
  5. Turn on the projector first, then turn on the computer.
Nov 09, 2008 | Computers & Internet
Motorola DCH3200 Cable Box
Be sure that you took the time to force the output of the DCH3200 to 1080i. They do not seem to come set that way by default! This is true whether you are using either the component or HDMI output.
Power OFF the unit and immediately push the Menu key on the front panel. Using the remote, be sure that the 2nd line of the config is set to 1080i and not something less.
Mar 27, 2008 | Sony KP-57WS500 57" Rear Projection...
Compaq MP 2800
Hi there
Does your Projector support Windows Vista ?
Mar 07, 2008 | Compaq 207685-001 - Microportable...
Projector and pc not picking each other up
Hi, Normally your connection should work straight out. Pls verify that your dvi output is enabled/activated by checking your display properties. In a Windows based OS machine, right click on any clear area of your desktop, click on Properties. Click on the settings tab, Advanced button. Check on the different abs such as Monitor, display and others. There should be an indicator for dual view or enabling/activating your secondary display unit (which is your projector). Hope this be of some idea/help. Post back how things turn up or should you need further information. It may also be of help if you can provide info on your PC. Good luck and kind regards.
Sep 23, 2007 | LG DLP Projector 1400Lum RD-JT30...
Greenish display
Had the same problem. Opened the cover and find out that when I press the part above the lump the display become normal. Some loosed connector was my first thought. But, after a while looking and pressing around found out that the cover of the lamp was not placed properly and one corner side of the lamp cover was displaced. Opened it, returned it back to fit properly and the green display is gone. Hope that will not appear again and that is the same "problem" with yours.
Aug 12, 2007 | HP Compaq iPAQ MP4800 Multimedia Projector
Compaq iPAQ MP4800 Multimedia Projector Logo
53 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Tony
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
