Question about Black & Decker CWV4830 DustBuster Handheld Wet/Dry Vacuum
Replacement battery pack & instructions for replacement.
I have a scunci rechargeable wet and dry vac. Model 52069. I plugged it in to charge green light turns on. Couple hours later I unplug it and push the button nothing. Need instructions or manual.
Most likely the rechargeable battery needs to be replaced.
Unfortunately, I haven't been able to find a battery pack listed anywhere. You'll probably have to have a company like Batteries + Bulbs (In the USA) take it apart and replace the battery pack.
Nov 11, 2016 | Scunci Vacuums
Were to find replacement battery pack
I would suspect that they would only be available thru DIRT DEVIL
Jan 03, 2016 | Dirt Devil BD10165 Gator Bagless Hand Held...
Need battery for fhv1200
Black and Decker, does not provide a replacement battery for your model. It is supposed to last 4 years. I have been scouring the web in order to find a suitable replacement but can not find anything. Is there a model number on your battery pack that you can provide for further research?
Sep 03, 2013 | Black & Decker Black Decker FHV1200...
I need instructions for installing a replacement battery in a Shark V1725QR vacuum, please
I am not familiar with your type of vacuum. Is it a stick vacuum or sweeper type, you should remove your accessories, turn the vacuum upside down and you should find one phillips screw holding the battery pack in.
If this is a handheld, please ask for a second opinion or repost.
Hope this helps,
Handie Andie
Mar 28, 2011 | Vacuums
My phv1800 18 volt hand vac's battery seems to be running down. is there any way to revive it? if not; can i purchase a new battery to replace it? thank you!
If you are handy with a soldering iron, and don't mind spending a few hours building a new battery pack using 1.2 volt "sub c" cells, you can disassemble the PHV1800, and rebuild the pack yourself. I just did it tonight, and the vacuum works like new.
However, I'm not going to do this again. The PHV1800 doesn't use a single battery pack, but 2 packs that have to be assembled with very little room for error. You can purchase a combination battery pack/motor assembly for $75 (US currency, price currect as of 10/2011), unscrew the screws that hold the vacuum together, and replace the battery/motor unit as one.
Jan 24, 2011 | Black & Decker PHV1800 Bagless Handheld...
How to replace battery for PHV1800 type 1 18vdc
Nov 29, 2010 | Black & Decker PHV1800 Bagless Handheld...
Can you take the Swivel Sweeper battery pack apart to replace the batteries with new rechargeable batteries? Batteries look like AA or AAA, but it appears that the battery pack is sealed. Is there any way...
Yes you can if you have a way to cut through the plastic outer case,(I used a Dremel rotary tool). Inside you will find six double A Ni-mh batteries. I found eight of these for sale on ebay for around ten bucks,then all you do is solder some wire to the batteries like the original battery pack and tape up the case and charge.
Nov 20, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Battery Pack for the Eureka Boss Model 93B
tHE 96 F IS ALMOST THE EXACT SAME AS THE MODEL YOU HAVE. THEY HAVE THE SAME POWER TO THEM THE BATTERIES WERE JUST DIFFERENT
Jul 18, 2009 | Vacuums
I am looking for a battery for a westinghouse model wst1600a
I too was looking for a battery for the WST1500a. I took the charger and a defective battery pack to BATTERIES PLUS. They rebuilt the pack with new fresh and fully charaged batteries in a short time. The result was good and better then a new battery pack that had been sitting on a store's shelf for 5 years. The advantage is that they are new batteries with a correct charage. The cost was about 75 dollars.
BATTERIES PLUS is a chain and are available in many large cities.
If you need a new "case" for the batteries so you can rebuild the pack, they do have some "packs" on E-Bay listed under BP1600. It's always a "hit and miss" on E-Bay. The problem is that the current vendor lists the BP1600 pack as a Black & Decker part and doesn't know exactly what he is selling. There is no picture of this on the current listing which isn't good.
Feb 19, 2009 | Westinghouse WST1600 Upright Vacuum
Black & Decker CWV4830 DustBuster Handheld Wet/Dry Vacuum Logo
48 people viewed this question
Top Black & Decker Vacuums Experts
Greg Cann
Greg Cann
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
