Question about Kenmore 24032\24036 Top Load Washer
Washer is leaking after it finishes completely from bottom front. my husband thinks its the pump? any idea how much a pump costs and is it worth fixing?
You can go to Sears website, click on Sears parts direct, enter the ENTIRE model number, which is three numbers, dot 8 numbers ie something like 106.24032400. This will give you access to information about parts and costs.
Posted on Oct 17, 2010
1. Decrease in pressure. Can't clean deck properly. 2. Water leaking from underneath. 3. There is a short clear hose not attached to any thing. 4. I'm not a mechanic. I'm an x-ray tech and my...
If the pump is leaking then it is going to either be the water seals or o-rings on the inside of the pump. If this is the case I would recommend just tossing the unit, what it would cost to rip the machine apart and replace these items would be more than what the machine is worth.
Oct 15, 2010 | McCulloch FHH18A Electric Pressure Washer
Kenmore top load washer leak out the bottom
In order to accurately determine where the source of the leak is coming from, you need to remove the exterior case on Kenmore top loaders. The following link explains how to access the washer interior components and how to inspect for leaks:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
In the majority of the cases, the source of leaks on a top loader comes from the drain pump or drain hoses. There is a follow-on link inlcuded that explains how to replace the pump if it is damaged. These pumps are not servicebale and must be replaced if leaking.
Replacement parts (if required) can be ordered from any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing. The first three sites I listed also inlcude helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
Mar 27, 2010 | Kenmore 24032\24036 Top Load Washer
We have the kenmore stackable washer and dryer the water won't drain my husband thinks something is stuck in the pump Any ideas?
On the bottom front of the washer there are 2 screws.
Remove these screws and insert a screwdriver in the space where the front panel meets the washer top and push down on the screwwdriver. The locking tabs will come down with the front panel.
Pull the panel off and set it aside.
When you are through with the repair, tilt the machine back slightly and insert the panel tabs in the groove, place a screwdriver handle or something of similar thickness under the washer and front panel. Let it down on this and it will hold the panel up so that you can get the screws back in.
Apr 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
I have a front loading frigidaire washer gallery 1670 series
I would say yes, its worth keeping. Mine leaked a while ago and I bought a new pump assembly. I think it was about $70. You can remove the two screws on the bottom of the bottom face plate and remove the cover. The pump is on the right side. Look for goo leaking out of the shaft seal. Verify before you buy parts, It could be the rubber boot torn or something similar.
Don't reach inside untill its unplugged.
You can replace the shocks easily too. Lots of parts places online with illustrated parts catalogs.
Jan 19, 2009 | Frigidaire GLTF1670A Front Load Washer
Can't find the pump
the pump for this machine is located underneath the unit, lean the machine back, remove (3) 5/16 screws across the front bottom panel and remove the panle, the pump will be in the rear right side mounted upside down, wiht 2 hoses comin off the bak, the will be waterin the pump area( maybe as much as 2 gallonns so be prepared to get wet.
Nov 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Roper top load leaking from pump.....any solution other then replacing pump?
replace pump it is all spin welded together and not made for repair besides you already have it off $45-50 will finish repair normally costing 150-200 for tech to do
Aug 06, 2008 | Roper RAS6233KQ Top Load Washer
Water leaking on floor after every wash
there should be an acess panel that your husband can remove(2 screws on either side of bottom of panel. From there you will get a bettter idea of where leak is coming from. might be as simple as a hole in a drain line. take a look
Mar 08, 2008 | Kenmore 43042 Front Load Washer
Amana washer leaking.
Have your husband disconnect the power and water lines, pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Feb 23, 2008 | Amana ALW880WH Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
29 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
