Question about John Deere Garden
I have a john deere x300, brand new this summer. The height adjustment knob suddenly stopped working?
bargainbin2
  • 123 Answers
SOURCE: need to remove and replace
This look like it would be hard but it only takes a few minutes to remove. First put it on jack stands and lock the clutch down to release the belt so you can slip it off the pully. Then there are only about 6 bolts and two control shafts pins and its is out. It make things simpler by removing the deck first.
Posted on Aug 28, 2009
SOURCE: John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
Posted on Jul 16, 2010
SOURCE: My John Deere x300 won't
I am not familiar with this particular model but from the smell of raw gas I check the air filter and choke first to see that you are not flooding it. You could also take out the spark plug to see whether it is wet with gas.
Posted on Aug 07, 2011
  • 41 Answers
SOURCE: john deere x300 after restarting will not go
Check the transmission disengadge lever located behind the transmission. Make sure it is pushed in all the way. Otherwise, make sure the traction belt from the motor to the transmission is on track. If this is not the fix, please respond for further instructions... I've been running the "X" series JD tractor since they came out!
Posted on Oct 07, 2011
  • 123 Answers
SOURCE: john deere x300 will not move
It sounds to me like the traction drive belt slipped off of a pulley or broke. The easiest way to get to the traction belt is to remove the mower deck. There is no easy way to replace the belt, however. It runs from the transaxle at the rear to the engine at the front, around idlers. Let me know if you would like assistance in replacing the belt and I can walk you through it, Daniel.
Posted on Oct 12, 2011
How to level the mowing deck on 2002 John Deere (Scotts) 42 " mower. Mower deck drags on right side. Mower height adjuster doesnt work seems jammed.
Have a look underneath while someone operates the height adjustment. There's probably a link arm come off which does deck height. Go to google images for this machine, type height adjustment and look at the pictures if you don't have a handbook. Google JD handbooks and see if you can find a free download.
Aug 13, 2016 | John Deere Garden
John Deere x300 want go forward are backward and the lever is all the way in also when you pull it out it doesn't go into neutral
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
JOHN DEERE X300 SERVICE REPAIR MANUAL
Oct 29, 2015 | John Deere Garden
Do I need to switch to the high lift blades for my rear bagger to work right?
Yes. I use gator mulching blades during the summer. They won't bag a thing. The original/standard blades will bag some grass/leaves, if they are dry and not too dense, but they are prone to clogging. The high lifts work much much better.
I get mine on amazon. The shipping is free. LA145 48" deck. Part GX21785.
http://www.amazon.com/gp/product/B00CAXMAG2/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1#product-description-iframe
Apr 13, 2015 | John Deere Garden
Hello. My x300 john deere ride on mower starts but will not move. The lever at the back is pushed in where it is supposed to be. can you plese help?
There is an adjustment that tightens the drive belt. This is the drive tensioner pulley. If you need a schematic or instructions on how this is done, go to John Deere dot com and they will have repair manuals and parts schematics.
May 10, 2014 | John Deere Garden
My mower deck will not hold adjustment
I had the same problem. I fixed it by wrapping one end of a bunge cord around the adjustment knob and the other end to the tractor frame. The pressure from the bunge cord holds the knob against the height adjustment slots. Give it a try.
Aug 22, 2012 | John Deere Garden
John deere x 300 carb needs adjustment
If you want to solve your problem, click on the link I attach.
Apr 20, 2017 | John Deere Garden
X300 series tractor problems climbing steep inclines belt seems to be slipping Is there an adjustment to tighten?
The X300 has a self adjusting tensioner on the drive belt. Are you trying to mow uphill in the morning? or when the grass is wet? And did you buy it new, and how long has it been acting this way. Have you had a rear flat tire repaired latley? These are some questions that will help us answer you problem.
Thanks,Matt
Nov 10, 2010 | John Deere 22HP Hydrostatic 42" Riding...
May 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
57 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
