Question about Panasonic NN-S553 1350 Watts Microwave Oven
My panasonic inverter microwave turns itself off after about 25sec can restart and does it again does any one have a clue what could be wrong
MicrowaveSvc
  • 9098 Answers
SOURCE: panasonic inverter microwave
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle. It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Dec 28, 2008
SOURCE: Panasonic Microwave about 9 years old with
In all likelihood the mangnetron is failing, or perhaps even the Power Supply is faulty. You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Posted on Jan 28, 2010
Testimonial: "Couldn't ask for more - response was prompt, helpful and clear. Thanks "
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic microwave shuts off
Posted on Dec 25, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: inverter microwave stopsafter 25sec no
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Jun 08, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: My Panasonic Inverter Genius Sensor 1250W Lights
This is most likely because of a faulty interlock monitor switch, operated by the door latch. If it thinks you're running the oven with the door open it will cause the fuse to blow (or trip a circuit breaker in your case). The switch may be bad (not opening as it should when the door is closed) or out of adjustment.
The switch is replaceable and it's not a costly part. You should have microwave service done by a professional, especially if it involves the door. There are potentially lethal voltages present with the cover off, and the possibility of microwave leakage is the repairs aren't dome properly.
Hope this gets you cooking again. Thanks for using Fixya!
Posted on Feb 17, 2010
Panisonic inverter microwave lights up but doesn't fully come on
How to fix microwave that counts down but does not heat or ...
? 4:51
https://www.youtube.com/watch?v=PIU1NRpeA_8
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. ... with a different part number (D3V-16G-2C25) but it doesn't look like it's stocked. ... Problem now is that when we open the door, themicrowave comes on by itself! ... I am not sure, when you hooked up the volt meter, did the lights turn on and off ...
All comments on Fixing Panasonic inverter microwaves ...
https://www.youtube.com/all_comments?v=hBJJU4ZRh7U
i have a nn-h965wfx the light comes on the countdown initiates but nothing comes .....I have a similar full size panasonic inverter microwave NN-L931BF built in ..... After putting it all back together the thing doesn't even power up the display.
Panasonic 1200W 1.2 Cu. Ft. Countertop Microwave Oven ...
www.amazon.com/Panasonic...Microwave.../B005BFZ...
Amazon.com, Inc.Ft. Countertop Microwave Oven with Inverter Technology NN-SN661S Stainless at Amazon.com. ... The microwave panini meals even end up with toasted crisp bread. ...But, right now, I find the interior light functionality just fine. .... (1) In this Panasonic, the light doesn't come on when the door is open; it only comes on when ...
Jan 05, 2016 | Microwave Ovens
Child mode off panaso inverter
reset the microwave. Disconnect from power cord, by 1 minute, and try again.
God bless you
Jul 05, 2013 | Microwave Ovens
Our microwaze is shutting off after ~25sec saying H98
Your microwave generation system has failed and Panasonic recommends that you get it serviced by a qualified tech. Hope it is under warranty!
Sep 14, 2012 | Panasonic Genius Prestige Nnsd997s...
Panasonic NN-S752BF
You have a bad inverter. Time to replace the unit. The inverters are expensive and its cheaper to replace the unit. Unless your microwave is under warranty, and you can have THEM pay for it. I would say you have at least a bad inverter, and possibly a bad magnetron too. Good Luck!!
Aug 20, 2017 | Panasonic Microwave Ovens
It is actually NN-T695SF, it will not warm food. It powers up then goes dim, then powers up then goes dim, it keeps doing that. Food comes out cold.
Hi, if it is an inverter microwave and the problem is cycling every 2-3 seconds, my experience is the magnetron has most likely gone short circuit and the inverter board is shutting down to protect itself and then restarting, hence your symptom.
DO NOT try to test this unless you are experienced with extra high voltages - the voltages present/stored in a microwave even when powered off can kill you.
Aug 13, 2010 | Panasonic NN-T694SF Microwave Oven
Inverter microwave stopsafter 25sec no matter what the setting and nothings hot
Jun 06, 2009 | Panasonic NN-H664 Microwave Oven
Microwave turns off by itself after being on for 3 seconds
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt and
http://www.microwavedisplay.com/disassembly.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Mar 03, 2009 | Panasonic NN-S532 1200 Watts Microwave...
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Faint buzzing sound smoke coming from back
The high-voltage transformer (or inverter transformer) has probably failed.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Oct 24, 2007 | Panasonic NN-T655SF Microwave Oven
Panasonic NN-S553 1350 Watts Microwave Oven Logo
382 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
