Question about EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard
I have 5 ECS GeForce6100SM-M Socket AM2 networked computers that do exactly the same thing . I have replaced them because they are not dependable.Some of them will boot if I warm them up by editing boot.ini to 5 minutes or sometimes pressing f8 and choosing safemode with networking rarely. I feel that all of them have a defective power supply that corrupt the hardrive after shutting down abruptly, there should be a recall on the power supply's
Benimur
  • 6966 Answers
SOURCE: problem with ecs elitegroup P4M800PRO-M2
Hi, Based on your post/description, it appears to be a hardware issue. Check that you have a 300watt PSU (or higher) preferably with 24 pins (ATX v2.x). Perhaps you can try to do an R&R, remove and reinstall everything especially the power connector, memory and video card (if add-on). It may also be worth your while to reset the BIOS/CMOS to default and try again. If problem persist, then perhaps it will be to your advantage to have the motherboard replaced. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 03, 2007
  • 5 Answers
SOURCE: Computer shuts down while loading OS
I have the 6100 sm-m and was having same problem .. I went to ecs website and flashed to old bios then downloaded new bios ... when updating make sure you check the bootblock , dmi, and hole .. I also checked the update all ... seems to have fixed the loading of vista and has not shut off
Posted on Oct 15, 2009
ihaterich
SOURCE: Dear Sir, Have P4VXASD2+ with AMIINT - 10 BIOS
When I upgraded this motherboard to 1 gig of ram I had to set a long line of jumpers. It explains it in the manual.
Posted on Dec 17, 2009
map9966
  • 2351 Answers
SOURCE: where does the HDD Led, Power SW, Reset SW, and
You'll need the manual for this MB. If you do not have it you can download it from the link provided;
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=685&DetailName=Manual&MenuID=1&LanID=9
You'll also need Adobe reader to view the manual. Download Adobe here; http://www.adobe.com/products/reader/
Open to page 12 and zoom in with Adobe if needed. See pages 4 and 5 for location of, PANEL1.
Wire colors do vary from case to case. Colored wires are more often positive where white is common for negative. As you look at you're case wires you will find one color in common with most of the jumpers. This common color will be positive.
The internal speaker wire colors are red for positive and black for negative.
Main Web Page for ECS GeForce6100SM-M (1.0)
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?DetailId=685&DetailName=Feature&MenuID=1&LanID=9
Take you're time.
Mike
Posted on May 13, 2010
  • 1116 Answers
SOURCE: can i used sata hard disk drive in EliteGroup ECS
Yes, your motherboard supports 2 x Serial ATA 3.0Gb/s devices.
Posted on May 26, 2011
How to plug your usb control wire into *********** board
it will say usb on motherboard the spot that dose not a wire goes to that spot only one way
Mar 03, 2014 | EliteGroup ECS GeForce6100SM-M (1.0)...
Pci simple communications controller driver xp
This is a modem or network card. You must... Never mind.
Here it is.http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=820&MenuID=21&LanID=0
Feb 13, 2013 | ECS GeForce6100SM-M2 V1.0A Socket AM2/...
Will mcp61sm am take amd 64x2 7750?
maybe its not compatible,, try another processor
Feb 27, 2012 | EliteGroup ECS GeForce6100SM-M (1.0)...
Im looking for ecs geforce6100sm-m driver
http://www.ecs.com.tw/ECSWebSite_2007/Products/ProductsDetail.aspx?detailid=685&CategoryID=1&DetailName=Driver&MenuID=52&LanID=0
Sep 13, 2011 | EliteGroup ECS GeForce6100SM-M (1.0)...
Its a geforce6100sm-m reformatted and now its telling me info Network connection: Name=Local Area Connection 2, Device=USB Cable Modem 351000, MediaType=LAN, SubMediaType=LAN info Network connection:...
The computer has an ethernet adapter builtin, in the control panel disable the ethernet connection Device=NVIDIA nForce 10/100 Mbps Ethernet and then make sure the drivers for the usb cable modem are installed.
Sep 21, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard Logo
99 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
