Question about Sony PlayStation® 3 Black Console
I have a PS3 that has been hooked up to the same HDMI cord for the bast six months. I used it the other night and turned it off for the night, now it is not working. I have attempted to reset the video with still no results. Anyone have any suggestions?
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 82 Answers
There is a way to perform a hard reset of the console. i had to do this once.
BACK UP BEFORE YOU DO THIS OR YOU'LL LOSE GAME SAVES MUSIC ECT. GO TO THE BACK UP UTILITY IN THE MENU AND BACK UP WITH A SD CARD(PS3 FAT 60gb) USB STICK OR EXTERNAL HDD
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/2 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
This should take care of the glitch in the A/V
Posted on Oct 17, 2010
Hooking up my ps3 using HDMI cord to my olevia 232-S13 and it says invalid format
Setting up your HDMI cable on your PS3 games console
1: Turn on your TV and set its input to HDMI.
2: Make sure your PS3 is connected via a HDMI cable.
3: Power on your PS3 and press and hold the power button for approx. 5 seconds, you will hear the PS3 start to beep, release the power button after the second beep.
4: Your PS3 should automatically configure itself for HDMI video and Audio output.
Jun 28, 2015 | Olevia Televison & Video
Can't find setting to use my ps3
Try each setting if you have it hooked up via HDMI. If nothing comes in, try turning the PS3 and TV off and disconnect the cord and reconnect it. You may also wish to use a different HDMI port. Otherwise, your HDMI cable, PS3 or TV may be faulty.
Nov 10, 2013 | Televison & Video
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
I bought a hdmi cord so my son can play ps3 we
Hi:
Check the video connector on the PS3 for a switch to switch from composit video to HD video.
Dec 26, 2009 | Vizio VW32L 32 in. LCD HDTV
Ps3 static audio
I just bought my PS3 and noticed this exact problem, Go into your audiosettings click hdmi. then go to manual. Uncheck Dolby 5.1. save your settings. This fixed the static for me. Sony should fix thier 5.1 drivers
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
I've had my 80G PS3 for less than 1 month and I am having a major problem. Everything was working fine. I occassionally turned it off directly from the back. 99% of the time I shut it down correctly. I...
Hold your ps3 power button. It will scroll to different video settings. I believe there are 3 different video settings. I believe each beep is a different video setting
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Flashing screen
It sounds like its set for s video at 480p for analog tube tv's you need to hook up to tube tv and change in settings for hdmi
Jul 24, 2008 | Sony Playstation 3 (PS3) Console
PS3 or LCD TV?
when the ps3 is in standby hold down the power button for over 4 seconds, it runs the optimal screen settings page. hope this helps
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
Jan 11, 2008 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3  Black Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
