Question about Sylvania 6842-PEM 42 in. EDTV-Ready Plasma Television
Turns on for two seconds then shuts it self off?
Whenb
  • 1 more comment
  • Anonymous Jun 06, 2008
    turn on for 10 seconds then auto shut itself off.
  • lpaul55 Aug 04, 2008
    Nothing is visibly or smells burnt on my power board, the capacitor is fine but changed it, the tv still does not stay on. there must be somthing else wrong. please help.
    laz
  • Anonymous Oct 12, 2008
    my television
    Problem Solver:
  • 8 Answers
Sounds like a blown capacitor. I fixed the same problem in mine by replacing it with this one:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=490-4260-ND
If you can do a little bit of soldering, you can fix it yourself. Good luck!
Posted on Jul 22, 2008
MY R.C.A. MODEL 20F420T WILL NOT STAY ON. TURN IT ON IT MAY STAY ON 3 SECONDS TURNS IT SELF OFF TRY AGAIN IT MAY STAY ON 2 SECONDS BACK OFF THANK YOU ????
The first couple of seconds of operation, most TVs are doing some self-test and if something has failed making full power on dangerous (for fire) they will shut down. Either a major component in the horizontal section has failed or the main power supply itself is defective.
Dec 05, 2010 | RCA 20F420T 20" TV
Oven Stuck on Self-Clean/Locked cannot undo
you can press the clear off button for 3-5 seconds this should turn off the oven. if not turn off the circuit breaker for a few minutes then turn it back on and hit the clear off button again
Feb 27, 2010 | Ovens
JVC Receiver RX-6040B turns it self off after 10 seconds
the amplifier is seeing a short,or the internal components like one of the output ic are causing dc to show at the speaker terminals.the speaker protect is causing it to shut down.
May 14, 2009 | JVC RX-6040 Receiver
Akia lct2070 screen went black and will now shut its self off
You may need new inverters, CCFL's, or your power supply is not [providing regulated 24 volts...
Inverters
CCFL assembly
power supply
We have these Akai boards in stock if you need them.....
Dec 25, 2008 | Akai LCT2060 Television
My emerson tv is turning it self off
my tv shuts off after a few seconds what can i do to fix it
Sep 12, 2008 | Emerson EWL20D6 Television
Projection TV keeps shutting off
Good Day, checho3435;
Try this to help to narrow it down:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Day, big IRISH. back.gif
Jul 30, 2008 | Mitsubishi WS-55807 TV
Shut it self down after 5 seconds.
TV's have a circuit that monitors the high voltage and shuts down the set if it senses something amiss.
On projection types, figure on just replacing the entire board that has the flyback transformer on it.
Jan 02, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Tv wont turn on
I have the same problem , i will try new batteries and a new ac box. my email ramonmechshop@yahoo.com let me know what you think?
Dec 28, 2007 | Televison & Video
Sylvania 6842-PEM 42 in. EDTV-Ready Plasma Television Logo
59 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
