Question about Compaq Computers & Internet
I have one vertical line from the very top to the very bottom of the screen. It changes colors depending on what is displayed but it appears YELLOW on black, and its defiantly hardware related because it starts like that with the BIOS when booting up. It appears translucent when a white back ground is used. Its blue on a grey back ground. The line changes colors. It kinda flickers in some areas also depending on what is displayed. Is this something I can fix or do I need a whole new monitor? The monitor only has 1,300 hrs on the back light. Its hardly been used. The warranty is no longer valid through HP and I dont know what to do.
  • Compaq Master
  • 2,009 Answers
NO PC stated
no photos posted of SCREEN FAILING.
NO OS STATED< XP? , in this case , it dont matter.
i sure its a bad screen. 100%
why post and not tell the helper your service tag model #
HP made 1000s of PC.s not one can we guess, from 1984 to now.
you never even told DESKTOP or LAPTOP.
the back lamp does not do DATA its only a LAMP.
its a bad screen, im sure.
is it this PC?>
I have one vertical line from the very top to the - 1984-yurc2tkkgu0y15feq43cohvv-3-0.jpg
Do know this some PC , there are no spare parts now. if too old
and on some only ,used parts that tend to be bad too.
if you ask HP what to do they will ask you the same question.
Posted on Jun 29, 2017
  • 709 Answers
SOURCE: Black Out
Hi Detrix, Check with if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Posted on Oct 10, 2007
SOURCE: brand new Vizio 42 in from Sams has a 5 inch vertical grey stripe from top to bottom-any help removing it?
take it back!
Posted on Jan 22, 2008
SOURCE: Vertical blue line from top to bottom
I was told by one of you that the reason was bad drivers and to remove the software and reinstall it again. Bad advise. The blue line is a sign of dust. We cleaned the unit and the blue line dissapeared. I wasted $15.99 for bad service.
Posted on Nov 13, 2008
Niraj Limbu
  • 183 Answers
SOURCE: display shows pink color lines in white areas of the screen
Reinstall your VGA driver and i assume, it should be fixed if not you need to think about *********** board.
Posted on Dec 27, 2008
SOURCE: LCD monitor problem
I have a LCD flat monitor and it has a black vertical band on the right side of the screen about 2 inches wide, which hides some of the texts of the web sites. Unable to fix it with the monitor screen control, the problem is obviously nmore complex. Please help.
Anton G.
Posted on Oct 29, 2009
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Feb 24, 2017 | Samsung Televison & Video
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Vertical line 4"-6" distorting the picture appearing on the bottom of the screen on my Sanyo 37" LCD television
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 04, 2014 | Televison & Video
Horizontal vertical lines on Laptop screen
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
windows 7
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Color and Appearance.
Under Window Color and Appearance, click the color you want, and then click OK.
If you see the Appearance Settings dialog box instead of the Window Color and Appearance
window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
hope this helps
Aug 04, 2012 | Lenovo IdeaPad Z560 Laptop Computer -...
Vertical color lines on the display
this is due to fault in the screen take it to the technician
Sep 02, 2009 | Fujitsu Siemens LifeBook N6200 Notebook
Green line on each side of the plasma display.
Anybody knows how to reapair about vertical color- stripped lines appeared on screens and some trace of greenish images exist after each images changing, my TV is Toshiba Plasma Color 42HP83, I appreciate , thanks
Jun 05, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
NEC MobilePro 900 lines in display
The problem is most likely the LCD is dying
May 30, 2007 | NEC MobilePro 900 Handheld
Blue Vertical Line
It is sounding like when the laptop is turned on and heats up a bit, the line appears? Sounds like one of the panels is going bad or atleast has developed a problem. below are some tricks you can try to lessen the annoyance of the line. Dual-Scan STN displays are composed of 2 panels behind a single protective panel or screen. Because you are looking through the protective screen the display appears to be one large panel even though it is not. There is a physical separation line (gap) at the point where the two panels meet. When the computer is on and being viewed it is not unusual to see the visible separation line with the Dual-Scan STN displays. The line, actually the fine gap between the display panels, appears because the color and light pixels cannot run along the very outside edges of the panels. This line (gap) between the panels can be seen as a fine gray line and is most noticeable when viewing on a screen with a white or light background. Note the line may not be as noticeable when the screen is displaying certain colors or darker backgrounds. SUGGESTIONS: It is not possible to completely eliminate the line but there are some things you can try to reduce it's visibility. 1) Lower the display brightness/contrast. The brighter the backlight the more noticeable the line. 2) Use Wallpapers and Screen savers that use darker colors. 3) In the Control Panel/Display applet under appearance try different combinations of color schemes for your Window and Background choice Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Toshiba Satellite P35-S609: Pentium 4-3.2...
White Horizontal Lines near the top of my Screen
this symptom is what we called vertical fold-over. vertical fold-over is characterised by a white horizontal bar on the bottom or top of the raster due to the concentration or compression of the trace lines. it an image is present, the bottom or top portion is fold over. this is caused by a vertical deflection current with poor linearity, which compresses the trace lines at the bottom or top of the screen. this symptom is is caused by a defective sawtooth wave genetator circuit, or improper biasing or defective feedback circuit of the vertical drive or vertical output transistor/ic. the negative feedback circuit in vertical deflection circuit compensates for the linearity of the trace portion of the sawtooth wave. a decrease in the capacitance of the sawtooth generator capacitor is usually the trouble. but if you do not understand anything what i have written here, better bring it to a qualified tv technician for your own safety also. good luck!
Mar 01, 2007 | JVC TM-2703SU 27" TV
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
