Question about Vivitek Televison & Video
Last night tv would not shut off so I unpluged from back. To day I pluged it in but now it has no power and the blue light will not come on. There is power at the set. I tryed the button on the side of the screen and the remote control,. The model I have is a LT32pl1-A. It has very little use and only for movies. maybe 1 time a month.
  • whpttrson Oct 17, 2010
    Where would you suggest I take this to get it fixed I am Denver, Colorado. About how much would I expect it to cost???
    What would you expect this kind of repair to cost and who would you suggest that I take it to In Denver, Colorado
    Is this a usual type of failure and the set is just over three years old and the warrenty has ran out
    Is it worth the effort to fix it, the thing is hardley used.
  • Vivitek Master
  • 17,130 Answers
First of all you must switch ON the TV much more frequently specially if there is dust or moisture accumulation in your place. This will keep the electronics of the set in good shape.
If the set does not power up , the fault can be failure off the SMPS units if there is no trace of voltage or any indication in the panel. If so I would like you to take some tips from the following site for servicing the SMPS Unit.
log on to :
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
However if the +5 does come into the main panel then you must check the microprocessor for faulty condition. The crystal and the oscillations in the terminals must be checked to prove the processor is working. Use a good multimeter to check the voltages, however in most cases a signal test with an oscilloscope might be necessary. Hence attempt according to your availability of tools and expertise.
Finally check on main panel for visible failures, shorted capacitors, shorted drivers or open fusible links or resistors.
The advice/tip given is with the belief that you are competent. You must attempt to do it yourself only if you are technically/logically able, especially when dealing with delicate devices, damaging while trying to open, Probing electrical/electronic circuits with high voltage or delicate components. Since the advice given by me is with the inputs provided and not based on a visual inspection, there can be further reviews required in some cases.
Posted on Oct 17, 2010
  • Donald DCruz
    Donald DCruz Oct 17, 2010
    If you can get a technician to have a look into the set with a first hand information of the estimation, it will be worth as the estimation provided can help you to decide.
    Sometimes it can be very basic and the set might serve you much longer.
    If there is no power remove plug and check if the fuse has gone inside.. just to start with.
Jvc no power when plugged in
you tube might have blown ouy that's a big problem.Next time make sure you plug your TV in a surcharge protector
Nov 12, 2012 | JVC LT-37X898 37 in. TV
Blue light remains lit but lose picture. no other indicator lights flash. if i unplug the tv it will restart but lose picture again after half hour
I have a toshiba 50hm67 tv and with mine the blue light would come on and I would hear sound first and then the picture would finally come on... this happend for about a month.... next the yellow and blue light would come on but the pic still wouldn't come on until it clicked off and on by itself for about 10 min this went on for about a week. All of a sudden last night the red lights by the power light started blinking. No tv now and when the tv shut off it said lamp not working.
Sep 17, 2010 | Toshiba 56HM66 56" Projection HDTV
My Sony Trinitron shut down last night. I
4 times standby light blink shows that tv got problem in vertical deflection section and probably vertical output IC got defective, need to be replaced.
Replacement of parts in circuit board requires soldering work and expertise so call local tv repair shop guy if you are not familiar with soldering work.
Thanks.
Jul 25, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Power button
I agree with DickCanFixIt, also if you've added any hardware to your PC recently it could be drawing more power which has resulted as this issue. If this was the case you could try removing the added hardware to see if that changes anything. If this was the case you would simply need a new power supply with a higher wattage.
Apr 16, 2009 | Computers & Internet
TV SHUT OFF WHILE WATCHING. UNPLUG AND THEN PLUGED BACK IN. RED LIGHT CAME ON IN FRONT FOR A SECOND AND WENT BACK OFF. TV WILL NOT COME ON.
power in the tv has nothing related with the DVD. The tv has to have raster (white screen) even without signal (cable, DVD, others) if the tv alone is just having the led flashing and neither sound nor video (black screen) The tv has a short circuit in some of the boards that are part of the tv system. the blinking is part of a protection when the tv was created in the factory. Refer to the technician to repair this problem.
Apr 14, 2009 | Hitachi 61SBX59B 61" Rear Projection...
Tv no pic or sound
If you hear the high voltage try to come up and set shuts down in 2 secs it could be your FBT also these sets have alot of poor connections chassis should be resolder.
Apr 06, 2008 | Televison & Video
Element flx-3210 lcd tv
I have an element lcdtv 32inch. The tv is less than a year old, i was watching the tv and it just shut off. The red light is on, when i go to power it up, the blue light comes on for a second then blinks, and goes back to red. I know its not a brand name tv, but for 600 bucks, it should last for more than 8 months. Anyone have any advice ?
Feb 24, 2008 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
