Question about Sony FWD-50PX1 50 in. HD-Ready Plasma Television
X Sustain Board on Sony FWD50PX1
I have been told by a local shop that the x sustain board on my 50" Plasma fwd50px1 is in need of replacement. As usual they would like to charge me an arm and leg to replace it (~$500). I am very technically skilled, and feel that I could replace the board myself if I were to have some basic guidance, and a place where I could purchase the correct board. Do you have this board in stock, or can you get it, and, can you explain to me how I should install it?
Ronak (562) 761-3556
  • 3 Answers
Board is around $289.00 cost, if you can find one, Most likely if your display turns on and has no picture the display is bad time for a new plasma monitor, and it's a Y-SUS board
Posted on Nov 04, 2008
    Scholar:
  • 137 Answers
Goto www.interactiverepair.com
Posted on Jun 19, 2008
I have a Samsung Model HPT5054X/XAA 50" plasma TV. the picture went black but still have audio.I purchased a reman Y sustain board.The Y buffer boards looked good. Now when I reassembled the unit,st
Did it work with the Y-sustain board replaced? Likely if it did not work then there is an issue with the capacitors on the Y-sustain board and the power board. Check these caps for failure and replace them with the exact type. Likely the caps are blown and cause voltage loss in one or both boards.
Feb 01, 2015 | Samsung HPT5054 50-Inch Plasma HDTV
Sony Plasma KE-42M1 -70 volt section is not stable when Y sustain board is
Sounds like the sustain board is damaged. Replace it as as card basis.
May 27, 2014 | Televison & Video
Screen dims slightly suddenly
Hi.
Plasma display suddenly dimming down is usually symptom of a faulty sustain board. Sustain boards and other parts like the PSU must be tested before replacing any component.
Dec 12, 2011 | Panasonic TCP50S30 50 50 Plasma TV
If I have to replace the Zboard LI4101199A what would something like this run? My unit is 7 years old.
if you are replacing the X-Sustain / Z-Sustain Board yourself,
the part is 179.95 + 10-15 s/h
http://www.discount-merchant.com/SAMSUNG-LJ41-01199A-X-Sustain-Z-Sustain-Board-p/1022934.htm
if you are taking it to a shop for repair, it is easily going to be double that.
Oct 07, 2010 | Samsung HPN5039 50 in. Plasma HDTV
My Viizio plasma has soundut no picture.
Problem is in either power supply or the Y-Sustain board.
but the Y sustain board is mostly likely to be the cause.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Good luck......
Jul 30, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Got two popping sound and them no picture and just sound. No picture at all. Was told circuit boards might be blown. Which one usually go, how much do they cost and how hard to install them? Is it worth...
Most likely a fault on your Y-Sustain board & possibly the buffer board (one of the drive IC's may have blown). These boards can cost up to £100. The Y-Sustain board is not too difficult to replace but the buffer board can be tricky to reconnect the flat ribbon connectors. There is some dismantling of other parts to gain access to remove the sustain board.
Oct 26, 2009 | LG 50PX5D 50 in. Plasma HDTV
P50hdtv10a y-sustain and pcb
I had this problem with a different brand plasma and it turned out to be cracked or missing solder on the power board lead to y sustain. I removed the power board, desoldered the connection, clean it up and then resoldered the connection. Everything works great now.
Jan 23, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
LG 50PX2DC 50
The y sustain board and the z sustain board and control board have to be replaced.
Nov 10, 2008 | LG 50PX2DC 50 in. Plasma Television
Part # for a Y Sustain Board Cable Ribbon
why are you replacing it? what went wrong? mine just stopped lst nite and jsut ties to turn on. email res116@comcast.net
May 29, 2008 | Toshiba 50HP66 50 in. Plasma Television
Sony plasma picture is blurry and makes a popping noise
Hello MDay02,
Your problem maybe your X board which is the same as PCB X sustain. Changing the fuse in this case may NOT solved your problem. If you are handy, you may be able to change the board yourself. We have most Sony X board in stock. If you purchase the board from us, we will walk you through the installation process for FREE over the phone.
Mar 17, 2008 | Sony PFM-50C1 50 in. Plasma HDTV
Sony FWD-50PX1 50 in. HD-Ready Plasma Television Logo
347 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
