Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Trying to replace a trane weathertron with a hunter thermostat model 44272. i have a tan wire and black wire that its not showing me how to hok up. the tan wire was on the T terminal on the trane and the black was on the x2 terminal
Did you ever figure this out? I am having the same issue right now, was hoping to find answer online! Help, please!
Posted on Oct 23, 2010
  • Trip28 Apr 12, 2011
    Hey guys, replaced my trane weathertron with hunter 44272 thermostat. On your old thermostat the letters represent the colors. And you have to follow the wire guide from hunter to trane systems. I connected the T (tan) wire to the L connection on mine. But the black wire on my Heating/Cooling System was actually cut off?? But look to your installation papers they should tell where to connec t the black wire on a trane system to your hunter thermostat
Heat/Cool does not respond after replacing Trane Weathertron BAYSTAT239 with Honeywell RTHL3550
Sounds like you didn't turn the power off and blew the low voltage fuse. Typically a 5 amp blade style (like a car) inside furnace. TURN THE POWER OFF!!
Jul 13, 2017 | Heating & Cooling
Changing From Trane to Honeywell
Color ---> New stat terminal
Blue--------C
Green------G
Yellow-----Y
Orange----O
Red---------R
White------E and Aux.
Tan---------unused, tape and secure it
If there is Rh and Rc or R and Rh, these terminals should be jumpered together.
I used to install Weathertrons eons ago. Whatever you do DO NOT connect the blue wire to the B terminal, you will short out your low voltage transformer immediately when you switch to heat
Jun 13, 2013 | Honeywell RTH3100C - Digital Heat Pump...
Rheem Heat Pump Thermostat Replacement (#41-20804-15)
you need a 2 stage heat and cool t-stat hunter t-stat is not 2 stage
Feb 19, 2013 | Heating & Cooling
Hunter 44272 Not turning on heater
i am recommending you try again to call to the service man. The reason is simple you change it and they have all the wiring diagram for do it quickly. Get support via ONLINE or chat or phone.
Maybe you have some wrong wires connect
God bless you
Oct 08, 2012 | Hunter 44272 5-Minute 5-1-1 Day...
Replacing a trane weathertron with hunter 44132 i have r t o g y x2 b w wires where do they go on hunter 44312
T can be cut and capped, B goes to C (common) and W should go to W2 or E, whichever is present. X2 may be used in multistage heat strips if memory serves, cutting and capping it should be safe but changes in the wiring inside of the air handler may be required to accommodate this thermostat. If you like you can try connecting W and X2 (presumably white and black wires) both to the W2/E on the new thermostat but I would recommend checking the wiring inside of the air handler first. The rest of the terminals should be labeled the same.
Sep 22, 2011 | Heating & Cooling
Wiring Trane/Honeywell TH8320U
use the outside designations for heat pump, and inside for standard, I would assume a heat pump since you have more than five wires attached to it now. Use the colors of the wire to match to the designations, use tan for y2, black for w2 rc and rh should already have a factory jumper. I would have to trace out the "U" and see where it terminates, I have not seen a bare wire on a stat in 27 years of doing this. before powering, verify the tan and black at the indoor unit circuit board and see if they are landed on the terminals designated at the stat. hope this helps
Jul 27, 2009 | Heating & Cooling
Hi I am replacing a trane thermostat it has 8
call hunter fan co. you will have to jump out some term.
Jul 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
Need wiring for honeywell pro 3000 in trane xe1200
the pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
May 16, 2009 | Heating & Cooling
Trane weathertron thermosatat
OK. Here is a Trane Weathertron BAYSTAT240 thermostat wiring picture. This heat pump w/ electric (emergency) heaters is running right now. Notice the G terminal has green wire, the R terminal has red wire, the white wire is jumpered from W to X2, etc. The black wire loop you see in the center hole is unconnected.
This unit is adjusted by leveling the base - loosen the screw to the left of "R" and the one to the right of "F". Twist the base clockwise to RAISE the indicator. This makes the mercury in the switch turn ON at a different temperature. Remember to tighten those 2 screws again.
You will have to experiment several times to make the unit read exactly right. If the tech installed the base exactly level, the unit would read right (it says here).
Mar 20, 2009 | Heating & Cooling
Trane Weathertron XE1000 Thermostat Wiring
Check to see if you have the system switch accidently on em. heat. The way you have it wired is correct except for the having brown on e. disconnect brown wire and cut ofbare end just in case they have the wire hooked up for constant run on roof.
Feb 08, 2009 | Heating & Cooling
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
738 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
