Question about RCA HDLP50W151 50" Rear Projection HDTV
Shuts off on own, problems starting - RCA HDLP50W151 50" Rear Projection HDTV
  • RCA Master
  • 5,138 Answers
Lamp, Mats has them for $99.00 1-800-628-1118
Posted on Oct 17, 2010
How to diagnos Overcrank light
I don't think the over crank is a problem.
Why is it shutting off?
Find the owners manual to find out if there is some fault that will shut it down or it may be an engine problem like the choke not releasing after starting.
To find a manual online you will need the make and model number of your generator.
Aug 20, 2014 | Electrical Supplies
What's your problem?car runs got till it gets up to opertional temp then shuts off and wont start for 4 hours later
I had the same problem it was 2 bad injector they where shorting out it would run for awhile shut off and not start for 2 hours
May 07, 2012 | 1990 Chevrolet Cavalier
1997 f350 (shuts off when warm then will start up straight away)
Your problem is the Crankshaft sensor Ford had some problems with these it is located on the front of the motor by the Harmonic balancer
Nov 20, 2011 | 1997 Ford F350 Crew Cab
Starts then it wont start back up
if it starts and warms up does it shut it self off or do you shut it off an then won't restartif it shuts self off may be runnining it self out of gas wwhen it shuts off try spraying a little starting fluid in breather and see if it will recrank if it does you have a fuel problem if it does not start you have an electicly problem such as a bad coil poss
Jul 29, 2010 | 2005 Yamaha YZF-R1
I just replaced the Battery on my 1995 VT600 Shadow Motorcycle thinking it would help solve the problem of it not starting. Today will I was ride the bike shut of and would not start. What else might stahl...
Carb problems, ignition problems due to heat soak, and a few other things.
If it only starts when cold, and shuts off when warm, or just randomly shuts off, it's probably one of those two things.
Jul 21, 2010 | 1995 Honda VT 600 C Shadow
My 1993 honda accord shuts off after starting
main fuel inection relay is going bad. it is located under the driver side dash
Dec 26, 2009 | 1993 Honda Accord
99 buick regal 3.8 starts for 3 seconds and shuts down,
Had the same problem drove me nuts until I tried disconnecting Mass Air Flow Sensor, the car should drive normally but with a "Service Engine Soon Light" on. Mass air flow can run from $140 up, picked one up at recycler for $40.
Worth a try.
Mar 01, 2009 | 1999 Buick Regal
Vehicle shuts off after remote start
I will need to know the make and model of your car to answear this possitively but this sounds like a problem with your bypass module. That is if your car has a immobility system. an easy way to check this is stick your key in the ignition "Do not turn the key" just insert it in the ignition then hit the remote start. if the car does not shut down that is where your problem lies. if the car still shuts down then your problem is due to either a bad brain or faulty wiring.
Hope that helps,
Luis
Nov 25, 2008 | Car XR9000 Two-Way Confirming Remote Start...
RCA HDLP50W151 50" Rear Projection HDTV Logo
24 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
