Question about Sharp R-930 Oven
Sharp R930AK The turntable revolves even when door is open [will not stop]... need help, please....
  • 413 Answers
Control board has stuck relay or triac ( electronic equivalent of a relay) . Replace control board.
Posted on Jun 03, 2008
Glass broke need to take door off
open hinge locks with door open then partially close the door and grip both sides of the door and lift it up and out. Be careful as the door is fairly heavy. There are screws on the bottom ,sides and near the top that you remove and the door will separate so you can get at the glass. Reverse to put it back together. Be careful inside the door as the edges of some metal is sharp. Good luck
Jan 09, 2014 | Maytag MEW6527DDS Electric Single Oven
Hi the right hand hinge of the door has popped out whilst I was trying to move the oven using the door handle as leverage. The door is now wonky when closed as the hinged has popped out. Help!
All oven door typically lift off the hinges by design. If you open the door to what is referred as the broil position. You know when the door stops about 4 to 6 inches open at the top. Then do the following.
1. Lift the door up completely off the opposite hinge still in place and remove. Set the door aside carefully as if has glass window, you do not want to break.
2. Then set both hinges at the broiler stop position. If one is all the way in to door fully closed position pull it out with your hand or with pliers till it stops @ broiler position. If all the way down as if door was fully open, lift hinge until it stops at broiler position. CAUTION- THE HINGES ARE SPRING LOADED AND CAN SNAP BACK INTO FULLY CLOSED POSITION. You can use a heavy glove or if you have an oven mitten, that can work to protect your fingers. DO NOT GET YOUR FINGERS BETWEEN HINGE AND OVEN OR CAN PINCH FINGERS.
3. Now carefully lift the door over the hinges set at the broiler position. Careful not to bump them when doing so or can snap closed. If does, reset hinge to broiler position and repeat. Works best to hold door at angle that door is when in broiler position. Once you have them started evenly, you should be able to fully slide down back onto both hinges.
4. If one of the hinges no longer has spring tension you have to reattach the spring. You can usually access spring if needed by removing the bottom drawer.
Aug 27, 2011 | Ovens
My GE Profile Advantium Microwave Oven runs (and heats) continuously. The only way to stop it from running is to open the door.
Hi
Sounds like a defective door interlock switch or a broken switch mount. If it's not a problem with the door switch or door switch mount you will need to replace the magnetron and the touch pad as well.This will fix your issue.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 27, 2011 | GE SCB2001FSS Advantium Electric Single...
We are renting our townhouse. It came with a gas Kenmore oven. Someone (maybe even me) has done something to trigger the "LOC" display on the oven, meaning the door is locked, presumably for...
Hi
First press the CANCEL/Delay button for 20 seconds...If this won't work then you can start the self cleaning cycle again and then stop it after 15 minutes, then let the oven cool for sometime and check if the door opens again, if the not then you have to take a screw driver and open the latch. After this the latch mechanism should be replaced as it is bad. Hope this helps...please post back for further assistance.
Daniel
Jan 26, 2011 | Kenmore Ovens
Sharp MW won't shut off
Sounds like it needs a new electronic board or PCB. Although I would consider a new microwave as your microwave is getting on in age and can be a danger to health or dangerous if something blows up.
Jun 14, 2009 | Ovens
Microwave oven works while door is open
no there are three safety switches that control that the one that lets the magnetron run will blow the fuse if its bad you have a stuck door switch but there are recalls on some microwaves check here http://www.recalls.gov/ and here http://www.sears.com/shc/s/nb_10153_12605_NB_CSrecalls?adCell=AF or go to panasonic to find out other than that you need to replace a door switch let me know if i can be of further assistance
Mar 28, 2008 | Ovens
Ovens Logo
198 people viewed this question
Top Sharp Ovens Experts
JOHN LAPIER
Stan Ford
Are you a Sharp Oven Expert? Answer questions, earn points and help others
