Question about Garden
Manual for Ryobi RHT160D hedge trimmer - Garden
ctf1800
  • 4402 Answers
SOURCE: i have a black and decker hedge trimmer g25?
just take it to a electronics service shop that can resolder it for you
Posted on Aug 05, 2008
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
Posted on May 24, 2009
SOURCE: I am looking for the
I will advice you check manualsonline.com to search for the manual of your device as requested.
Take care.
Posted on Aug 26, 2010
vincob
  • 718 Answers
SOURCE: ryobi rht2660da hedge trimmer starts
If it brand new take it back to where you bought it, it's probably still under warranty. Why try to fix something you don't need to???
Posted on Aug 30, 2010
saailer
  • 1871 Answers
SOURCE: poulan-pro gas hedge trimmer ,
Hello! I have the manual but need model # to be sure...Send a comment...Guru...Saailer
Posted on Oct 29, 2010
I need a manual for a Ryobi RHT500R Electric Hedge Trimmer 500 Watt - 55cm
I found the manual for the Ryobi hedge trimmer here: fr.ryobitools.eu/local/uploaded/catalog/e_RHT500R-600RL_UM_UK_v1.pdf . The bolts you describe hold the blade to the hedge trimmer's motor. They shouldn't have come loose. However you can check if any of the bolts are loose or have backed out of the motor.
I would suspect either a part of the branch is stuck between the blades. I have one of the small edge trimmer which gets noisy when I get a woody weed stuck in the unit. Unplug the trimmer and look at the blade for some bark stuck between the layers. On each side there are multiple blades that overlap at parts of the cutting cycle.
A parts diagram for the RHT500R is available here: http://www.magic-parts.co.uk/acatalog/Ryobi_RHT500R.php .
II hope this helps.
Aug 23, 2012 | Ryobi Garden
I am renting a house which has a Ryobi RHT160D hedge trimmer and there is no user manual. I have plugged it in and tried starting it by pressing the 2 handles one after the other but it won't start. How do...
Hiya
The Ryobi website has a lot of current models for viewing, and many of them also include service manuals.
The website is promising to make available an archive of the service manuals of discontinued products.
I have found that online directories promising quantities of service manuals for download, require membership, membership payment and then informs me that the model I am looking for a service manual for is one of the few that is not in their extensive collection.. Each model I am looking for is not in their extensive collection.
I would recommend that you view the available service manuals from Ryobi and see which is a closest match for your product and see what they advise. The manuals appear to be quite simple, and do not promise much in the way of servicing information, other than regular oiling of moving parts such as blades.
I hope that this helps.
Feb 25, 2011 | Ryobi Garden
When in operation the Ryobi S430 string trimmer leaks oil continuously. How can I fix this problem?
Ryobi told me the unit can't have the s430 trimmer bottom end raised higher than the engine at any time, or it will leak. Apparently they released a product to compete with other companies for cheap 4 cycle trimmers without much care for the end user.
Nov 29, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
I have a ryobi hedge trimmer p2601 and the plastic handle broke. Is there a way to get a stronger handle or just a replacement?
May 29, 2010 | Ryobi 18V Hedge Trimmer
How do fit a hedge trimmer attachment to a rbc 40 sb brushcutter ? thanks
This unit was not made to have interchangeable heads. Ryobi makes a hedge trimmer attachment for some of its units that are quick connect.
Otherwise, you may buy this attachment and see if you can interchange the head from the brushcutter to the hedge trimmer. You may find it more work than you want to tackle.
Sep 26, 2009 | Ryobi Garden
Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Carbon brushes needed for Ryobi Hedge Trimmer Model RHT 618, 460
check with a small engine shop near you to see if they can get these parts for you.or you might fine them at www.partstree.com.
let me know what you fine out.ok
Jul 23, 2009 | Ryobi 26CC, 22 In. Hedge Trimmer
What is the gas & oil mixture for ryobi 26cc 22in hedge trimmer
If it is a 2 stroke engine, a 50:1 ratio should work. That's 50 parts gas to 1 part oil.
Dec 10, 2008 | Ryobi 26CC, 22 In. Hedge Trimmer
Garden Logo
193 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
