SOURCE: Innovage products jumbo universal remote - cable box code
Did you try the above method frim the manual
SOURCE: Programming codes
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC6131
just right click and save as on the download links.
if this does not work you can try the search method,
you do
this by either holding down the device button eg: TV or if you have one
the "magic" button for three seconds, a light should then flash twice
to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For replacement remotes visit www.sparky-uk.com)
SOURCE: Innovage Jumbo Universal Remote and Comcast Cable
I do not see Comcast cable codes in the manual, so I recommend using the auto-search function for both CABLE and SAT to find one that works for you.
To have the remote try each CABLE or SAT code it knows one at a time, follow these steps:
I hope that helps.
SOURCE: Need code-Innovage Jumbo remote for Motorola cable box & GE tv
The codes for a GE TV are: 000, 021, 053, 063, 115, 117, 120 & 134.
To program your remote by entering a code, follow these steps:
To find the right code for the Motorola box, I recommend auto-searching through the CABLE and SAT code lists.
I hope that helps.
