Question about Garden
We just purchased a Husky 60 gallon air compressor that uses 220, but is not wired with a cord. We have 4 wires coming from our sub panel, 3 wires in the cord we're attaching, and 3 wires coming from the compressor. Do you have a wiring diagram, and can you tell me the appropriate size and type of plug to use? The wiring diagram in the owner's manual does not address our issue.
    Problem Solver:
  • 4 Answers
The red and black are the hot legs of the connection. the white is the neutral, and the green is the ground. the ground and the neutral in your cae can be pigtailed. you will need to know what the starting and run amperage is in order to determine the wire size. My guess would be a 12-3 with ground would be adequate with a 25 amp breaker.
Posted on Oct 17, 2010
I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
Free Husky Air Compressor User Manuals ' ManualsOnline ...
powertool.manualsonline.com > ... > Husky > Power Tools Husky
Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
Sep 04, 2015 | Air Tools & Compressors
Husky 60 gallon compressor switch from 220 to 110
Try here, very good for asking problems http://www.about-air-compressors.com/husky-air-compressors.html
Jul 28, 2012 | Air Tools & Compressors
What size wire need to used for hook up elect 7hp 60 gallon g5396
Hi GCHEVY,
CH recommends their power cord part# EC012902AV. This is a three wire cord, using 10 gauge wires. (1) Black, (1) White, (1) Green or Bare. See CH video here for additional setup tips:
http://www.youtube.com/watch?v=iWtNdr_-7Iw&feature=player_profilepage
The wiring instructions are toward the end.
Bruce
Jun 26, 2011 | Campbell Hausfeld G5396 7 Hp 60 Gallon...
Have a husky 19 gal 1.5hp it kicks on when first start to work and when it builds up air and i use it and when it wants to kick back on it wont i have to wait till it cools down.
Is there an option for you to run this compressor on 220 volts vs 110 volts??? If so, you may want to convert it by following the re-wire instructions on the motor or wire access plate/instuction book. The reason your compressor won't fire up again after building pressure is the head pressure is to great at restart and 110 household current is not enough to give the power needed to turn the piston. You'll need to replace the plug and have someone run a 220 volt circuit once the conversion is completed.
Jan 18, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
The wiring is incorrect on my Rand 4000, the red wire is cut off
Does it have a 220 plug on it,if so it is set up for 220,if not it is 120volt.The red and the white are hot/120 each,black is common and green is ground to metal.
Aug 07, 2009 | Coleman Powermate 60 Gallon Air Compressor
I need a wiring diagram for a kobalt 60 gallon air compressor
If it's a 220 volt motor, hook l1 and l2 (220 volts) to the line terminals. If it's a'dual voltage' motor (120 or 220)and you want to use 120, hook 120 to the terminals marked 'line'. Make sure the motor is connected for the voltage you're using if it's dual voltage.
Jul 21, 2009 | Air Tools & Compressors
I have a Coalman Powermate 6.5 Hp 60 gal. compressor model C650C600VIB103. I want to know to connect the elect. cord correctly.
Does the unit have a starter or just a pressure switch , if just a pressure switch it should be marked with line and motor , the wires on the motor should go to the motor terminal and the line terminals are the power supply , if the unit is 110 volts make sure you put the wires on by color , the white wire goes to the motors white wire and the black to the motors black wire , if this is 220 volts it does not matter which wire connects just put the two black wires on the line terminals. One wire per terminals please.
Jul 17, 2009 | Coleman Powermate 60 Gallon Air Compressor
Need wiring diagram for a kobalt 60 gallon 3.7 hp air compressor.
I have a Kobalt 60 Gal 3.7 hp air compressor. Send me your email address and I'll make sure you get your schematic. Hope this helps! MichaelGG@health.ok.gov
Jun 16, 2009 | Air Tools & Compressors
Wires on Compressor motor disconnected.
Some compressors come unwired so the purchaser can wire for 110 or 220 by their choice. This I would think would be possibly your case. Was this purchased new? In any case, here is a site where you may be able to obtain a manual,
http://powertool.manualsonline.com/manuals/mfg/coleman/coleman_air_compressor_product_list.html
and here is one with a similiar description but a different brand compressor.
http://www.thestuccocompany.com/maintenance/240-volt-air-compressor-wiring-advice-from-Campbell-Housfeld-25469-.htm
hope this helps. copy and paste short cut, in case you may not know, highlight text you want to copy by holding down left mouse button and moving pointer of mouse over text desired,while cursor is still over the high lighted area release left button and right click mouse, select copy, then put cursor in the box you want to paste, right click and select paste
Nov 25, 2008 | Coleman Powermate 60 Gallon Air Compressor
Garden Logo
152 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
