Question about Fisher and Paykel GWL11 Top Load Washer
Cold Water coming out very slowly, warm and hot fine
    Sergeant:
    Champion:
  • 226 Answers
Take the cold water hose lose in the back of the washer and you should see a filter inside that little hole pull it out and clean it
Posted on Oct 17, 2010
WI815 Intuitive Eco - no cold water
IW Intuitive Eco.
Water valves have a rubber diaphragm that wares out
after some time,
So yes you are right water valves need replacing.
Apr 21, 2014 | Fisher and Paykel Washing Machines
Water comes up to tub but doesn't fill the tub. Help and when I pull the knob I hear a humming noise
Hi and welcome to FixYa, I am Kelly.
The humming noise your hearing is the inlet water valve solenoid. Before proceeding try switching between warm cold and hot to see if any of those selections give you water. If you get water on either hot or cold then you probably have debris in the inlet screens of the water valve where the hoses connect. Turn off the water. remove BOTH hoses noting hot and cold installed positions and the use a thin knife blade on the outer edge of the screens to lift the inlet screens out of the water valve body. Wash then under slowly running water rubbing them between your fingers. Reinstall the screens. Connect the hoses in their original positions, turn on the water and test your water fill again switching between warm, hot and cold. This should get you going. If your still having problems after doing the above; please respond with MODEL: number and I will help you.
Thanks for choosing FixYa,
Kelly
Feb 17, 2011 | Maytag Washing Machines
Cold water comes out very slowly whereas hot or warm is normal
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 27, 2010 | Kenmore 12502 Top Load Washer
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
I DON'T GET WARM WATER, WHEN SET ON WARM, ONLY GET COLD
If the setting is only hot and cold, there will be no
warm water coming out. At warm setting if it is
present, it should give you warm water.
Sep 23, 2009 | Kenmore 3.5 cu. ft. King Size Capacity Top...
My GWL10 fills really slowly. It starts fine with the hot water, then slows to a trickle when it switches to cold but it doesn't seem to affect it if I change the temperature selection. I normally leave it...
sounds like you have a restriction on the cold water water pipe kinked or a blockage turn off cold water and remove pipe from cold tap then turn tap on and see if water is coming through fast enough if it is then the restriction is in the hose or valve on washing machine if not then the restriction is in the cold water tap
Jul 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Low cold water pressure
Could be sticking plunger in valve, if youn have ascertained that the pressure is o/k,\then I would suggest a new valve is called for.
Dec 08, 2008 | Washing Machines
Hotpoint washer , top load
This sounds like a faulty water valve. Water is coming in the cold water valve when it shouldn't. If the machine has an automatic temp control make sure it is turned off.
Jan 01, 2008 | Hotpoint VBXR1090D Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
