Question about Sony KP-57HW40 57" Rear Projection Television
Red Bowed Lines / Red Hue
I have noticed it more lately that during dark screens or no source screen you can see a series of arched horizontal red lines spanning the entire screen left to right, top to bottom. This is also accompanied by red hue overall!! They are present all the time but only noticable in dark areas or dark screens.. help
  • midbys Jun 25, 2008
    I'm also having the same problem but today it seems like the red and green are both out of allignment. The tv hasn't been moved so I know it wasn't jarred at all and the allignment button is not working.
I tried the solution that was posted for this problem and it worked!
Just remove the Low front panel by removing the two bottom screws that are covered by two screw covers, then remove the second panel (black) by removing the 4 screws then you'll notice a module with 6 adjustment knobs, get a small screw driver, and with the t.v. on, being carefull , and with somebody accross the room looking at the screen begin with the lower left knob and turn left very slowly and ask the person across the room to let you know if the screen is better or not, after this I had to adjust the green as well so, I adjusted the next knob over to the left. Do this adjustment carefully and try to remenber the original position of the knobs in case you have to go back.f
Good Luck,
Posted on Jun 29, 2008
Red arching lines showing up on screen promident when a dark background is present
Red picture tube needs screen voltage adjust. Open fornt or back of TV and look for a black square looking box with adjustment knobs. Look for red screen adj and slowly turn rt or lft until lines just disappear. If screen goes too bright tv will shut down, just turn back on again and retry
Dec 04, 2009 | Sony Televison & Video
Thin red arched lines, when screen is dark.
common problem with sony, focus and picture level need to be adjusted, should be done by a tech. (high voltage) in focus block.
Nov 24, 2009 | Sony KP-57WS500 57" Rear Projection...
Blue Horizontal arching lines, Blue hue at power on
if you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Dec 31, 2008 | Sony KP-46WT500 46" Rear Projection...
Dark screen red arched lines
turn down the red screen control slightly the box is located behind the grille 6 knobs on it look carefully for the screen making on it for red do not adjust any other control best done in a dark room with no source in a video input if the tv will not auto align you have the control backed off to far
Oct 06, 2008 | Sony KP-46WT500 46" Rear Projection...
Faint red lines in a curved arch like pattern
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
My screen have some red lines
I will assume from you description that this is a rear projection crt(picture tube) tv. if this is true I have good news/bad news.
faint red horizontal bowed lines in the picture indicate the screen(G2) voltage for the red tube is too high.Slight lowering of the G2 adjustment will eliminate these lines. I stress SLIGHT because too much adjustment will mess up the gray scale .
The bad news the red crt made be bad. if the adjustment works but in the future the problem reappears then suspect the red crt replacement is probably not economical to repair.
Jun 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blue and red arched lines on screen when background dark
Sounds like you are describing retrace lines that could indicate that your CRTs or something in the drive circuits are bad.. Check the resistors on the CRT sockets to see if they are in tolerance. If they are try turning the red and blue screen adjustments down just a little this should take the lines away. You will however be needing service in the not to far future. Turning the screens down should help if the resistors check out. Let me know if you need anything further.
Jan 31, 2008 | Sony KP-48S35 48" Rear Projection...
White arched lines appearing on dark/black screens.
it sounds like you are seeing the vertical retrace for all three colors together (white). Its possible that all three screen adjustments (red, green, blue) are off, but I suspect a problem with the screen power supply.
there is also a recall on this set
Jan 23, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Green bowed bands
replace convergence ic
Dec 27, 2007 | Toshiba 57H82 57" Rear Projection...
Very fine red lines across srceen
It is an adjustment, but it's an adjustment you may not want to do. It's the red screen control. It's located behind the front panel so the entire front panel has to be removed in order to access it-which will expose you to hazardous voltages. if you like, I can post detailed instructions on how to get that front panel off, it's kinda tricky.
Jun 13, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
98 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
