Question about Refrigerators
Fridge freezer my fridge freezer has been leaking and I had to defrost it repeatedly, once a week. it had ice clogged up at the bottom of the freezer. I have now undone 2 pannels from inside the freezer and indeed it is some ice there at the bottom, but there is no drainage whole, as far as I can see. where is this drainage tube that I should unblock? what do I need to do?
  • Anonymous Sep 07, 2008
    freezer leaks ,ice forms on food in freezer sometimes puddles outside refrigerator on freezer side how to fix it or just shut off the water to the freezer
  • 871 Answers
Hey stressy,
i would suggest that if you want to do this yourself. you can improvise. but if you do have the time, i would suggest you check out the manual for the location of the drainage for the water of your freezer. you can also visually inspect the inside of the ref.
Posted on Jun 03, 2008
My fridge is leaking, water drips out once day from the left side where freezer side is.
Not sure what model you have or the age, but it could be the door gasket. It could also be the door closure at the bottom of the hinge side being worn down and not closing the door all the way. These normally last about 15 years.
Nov 02, 2017 | Refrigerators
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Leeking water inside fridge from top
Defrost drain is clogged. This accessable thru the back wall of the freezer. Also depending on your model some also have removable Bottom floors of freezer that also get ice accumulation. When the defrost drain gets clogged water from the defrost cycle has no where to go so it stays and accumulates ice till eventually it leaks into the fresh food section. Clear the drain completly and you will have no more problems.
Feb 02, 2010 | Freezers
Water leaking from door: top left door of my french door fridge (with freezer on bottom)--water leaking from the very bottom right corner of that left side door
your drain is clogged. if ice isbuilt up in the freezeer floor. when the freezer defrosts and the drain is clogged it has no where else to go other than ouot the front. pull everything out of the freezer and check twards the rear at the bottom. remove as much ice as possibile let set unplugged and door open for 3 hours. then take a cup of boiling water and pour it back there. if it dont drain repeat that process with the water-have a towel ready because if the water stays back there long enough it will get cold. you need to keep the water HOT. ice could be built up in the drain. hope this helps
Oct 28, 2009 | Refrigerators
The freezer part of the fridge fills with ice and leaks so there is a small puddle of water on the floor periodically.
It sounds like you have a clogged drain. When the freezer defrosts the water goes out a drain in the bottom of the fridge. Something probably fell into the drain and now the water has no where to go but onto the floor. The freezer defrosts regularly so unless you clean out the drain it will only get worse. Hope this helps
Oct 21, 2009 | Refrigerators
Freezer moisture overflowing into refrigerator
your drain is clogged, defrost the freezer and locate the drain either on the back or in the bottom of the fridge and clean it out. the water is coming from when the fridge goes into defrost
Sep 24, 2009 | Refrigerators
Fridge wasn't cooling but freezer was working, now both aren't
Hi,Your husband did good job, after cleaning and vacuuming, did freezer (bottom) have excessive ice?, if there's excessive ice in bottom, after cleaning, you have a defrost problem, but if there're no ice in freezer after cleaning, you got freon (gas leak) , there's a condensate loop, that passes through ref. body, from compressor that naturally develop, freon leak after few years, by rusting, normally it can be by- pass. vacuum and refill with freon, if there's no freezing, but compressor running, you'll need a mechanic, you got a freon leak. good luck.
Aug 10, 2009 | Amana ABB1927DE Bottom Freezer...
There is a lot of water under the bottom drawers in the fridge and the motor just went off. The light still works. Is there a problem?
HI,
your drain is clogged. you may have a catch for your drain where you see leak coming from. that may pull off and you can see if their is trash build up in it. you are going to need to take the panel off the back of freezer. inside back of freezer you will see screws. they will need to come out, If you have ice maker that will need to be removed also. once back panel is off you will see your coils beneath the coils it will most likely have a sheet of ice. turn machine off and take a hair dryer and defrost the ice. once ice is gone take a cup of hot water and run thru drain to see if unclogged. repeat if drain is not clear. the ice in drain tube will eventually un clog. use a steamer. much quicker.
any further question let me know,
thanks,
Mar 22, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice build up in bottom of freezer
Check the ice maker. sometimes they get cracked a will leak water into the freezer compartment. Also check the ice maker fill tube for leaks or someone could have spilled something. Although this is tipical of a clogged drain. What happens is when the fridge go into derfost, it will melt all the frost that is on the evaporator, turning it into water. The water drains down to a trough under the evaporator and down a drain hole in the trough ( this trough is behind the evaporator cover ) Removing the melted frost from the freezer. If that drain is clogged, the water cannot leave the freezer. Then when the fridge starts back up ,it will freez the water that was not drained. After repeated defrosting the water will fill this trough and run off into the bottom of the freezer to be frozzen when the fridge starts to cool again.
Nov 16, 2008 | Refrigerators
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
