Question about Porter Cable 59370 Door Hinge Template
Lost instructions for plastic hinge jig - Porter Cable 59370 Door Hinge Template
  • 2,100 Answers
This is a home owner's jig for mortising **** hinges, It will not do production runs , that's for sure. It has to be layed out to start, but great for cutting one door. Do you have the router guide for it? Your hinge sticks out of the door on the side that it swings on, and it leaves about 1/4 inch of door on the other edge, the top and bottom are measured from the top and bottom of the door and you have to figure the thickness of the guide and make a test run on a scrap. The depth should be flush with the hinge. The standard way of measuring is, 7 from the top, 11 from the bottom and center in between the 2, they don't do that anymore, they just slap them in a pre-hung jig that mortises upside down, backwards, up, down, doesn't matter. all the same now days, only problem is you can't get a punch under the hinge to pop out the hinge pin if you have to. The card you have might have the dimensions on it for holding off the line. Hope this helps.
Posted on Oct 17, 2010
How to install new door lock
For a residential door, you may choose either 2 3/4" (70 mm) backset or 2 3/8" (60 mm) backset. Some locks are not adjustable.
Choose the backset required for the lock. Check the thickness of the door. Standard installation height is 35-36" above the floor.
Bore a 1" diameter hole into the edge of the door and a 2 1/8" hole through the face. A drilling jig helps align these two holes. If you measure and mark the holes carefully and drill accurately, it can be done without a jig, but for about $20.00 the jig helps avoid lock alignment problems or possibly trashing a door. Follow the instructions for the jig and the lock manufacturers instructions.
Jul 09, 2014 | Ace Hardware Ace Door Lock Installation...
Broken door hinge on Stoves 900dfa oven
STOVES 900DFa - how can I download the USER MANUAL and the TROUBLESHOOTING and MAINTENANCE MANUALS
Dec 30, 2012 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Need instruction Manuel for delta tenoning jig
Go to the Dewalt Service website at http://servicenet.dewalt.com/ and put your model number in the Find Parts box. Hit search and you'll be presented with a page where you can view or download the parts breakdown or the instruction manual.
Jul 31, 2012 | Delta 34-184 Universal Tenoning Jig
How do I change the blade on a Black & Decker JS500 jig saw?
Go to Dewaltservicenet.com and type in your model number and you can download the instruction manual for this tool with detailed instructions on how to change the blade. It is 8 pages long.
Oct 03, 2009 | Black & Decker Scroll Jig Saw Blade
Instruction manual for Bosch Jig Saw 1587AVS
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00061v-1.pdf
This is the Owner's Manual for the Bosch 1587AVS Jigsaw.
Mar 31, 2009 | Saws
I want to rout out for hinges with a freud trimmer will adding a block to the bottom of base plate work? will i be able to see the area i need to rout
You might be better off replacing the plastic base with a piece of 1/4" clear lexan (plexiglas). you'll be able to see through that.
Otherwise, you can make a simple jig that stops the trimmer at both ends (at the length of cut for the hinges) and controls the depth of cut by registering against the edge of the door. Make the jig base itself of 1/4' MDF or some such and longer than you think you'll need it to be so you have a way to clamp it or pin it down to the door.
If that sounds too complicated, try measuring the distance from the edge of the bit to the edge of the trimmer, in both directions, and marking the corresponding length away from the hinge position with a piece of blue masking tape or something, so you'll have an easily visible reference line when routing. You can mark it a little short and clean up the end of the cut with a sharp chisel.
Finally, run a test on a piece of scrap before you try to fit the hinge to your finished work.
Mar 12, 2009 | Freud FT750T Laminate Trimmer
Lost instruction sheet
Try this link: http://www.accesstoretail.com/uploads/partinfo/686870.pdf
It should have exactly the information you're looking for.
If I've managed to answer your question or solve your problem, please take just a moment to rate this posting...thanks!
Jan 25, 2009 | Saws
Need instructions to use Worktop jig
Screwfix were happy to send me a copy of the instructions for their jig which adapted perfectly.
Sep 29, 2008 | Tools & Hardware - Others
Porter Cable 59370 Door Hinge Template Logo
185 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim London
Jim London
Ed Mac
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
