Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Handle loose on Refrigerator
The door handle on the freezer is loose and the fridge is only 2.5 years old. I have called Kitchenaide - I have had 3 techs out to fix the loose door handle - I have called the appliance store I bought the fridge from - I have been to 3 different hardware/home stores - no one can tell me what size allen wrench I need. I have lodged 4 complaints with Kitchenaide and they will not help me -
I have same problem. Just called KitchenAid and they told me I needed a T-20 torque key - you can buy it from them or at a hardware store. Good luck.
Posted on Jun 09, 2008
I have a Kitchenaide side by side frig and freezer. The freezer is a model KSCS251 and about ten years old. It has got a loose freezer handle. what do I need to tighten it.
There should be a few more letters and numbers in the model number. I suspect the 1 should be read as an I. Look up your model here: https://www.kitchenaid.com/customer-service/manuals/ .
For the KSCS25INMS03, there are set screw on the top and bottom of the handle for the freezer. The screws are visible from the side of the handle facing the refrigerator section of the side-by-side design. See the freezer door parts diagram for your model. One model parts diagram is here: https://www.kitchenaid.com/digitalassets/MLPDF/Repair%20Part%20List%20-%20W10128953.pdf .
I hope this helps.
Jan 16, 2017 | Refrigerators
How do I do fix the handle of my Matag refrigerator #M1TXEMMW803. It is loose on the bottom.
Maytag Repair - YouTube
? 2:17
https://www.youtube.com/watch?v=KcPy_PWb_Iw
Aug 27, 2013 - Uploaded by hpaiz69
Maytag Side by Side Loose Door Handle Repair. ... RefrigeratorDiagnostic & Repair - Not cooling ...
LG Refrigerator Repair (Part #AED37133117) - YouTube
? 1:01
https://www.youtube.com/watch?v=BXupc6y_wgw
Jul 9, 2013 - Uploaded by RepairClinic.com
The most common reason for replacing the handle is when it . ...Fridge Freezer Door Handle Replacement ...
How to fix a loose Refrigerator Handle - YouTube
? 0:30
https://www.youtube.com/watch?v=4IO60zkMXpw
Dec 12, 2013 - Uploaded by Charles Joyner
How to fix a loose Refrigerator Handle .... Refrigerator Repair - Door & handle, Amana , Whirlpool, Maytag ...
Jan 05, 2016 | Cars & Trucks
Handle is loose on refrigerator,how to tighten the handle
There should be some small Allen (Hex) screws on each bottom side of the handle. Just use a Allen wrench and tighten it up.
Jun 06, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Door handle are loose
get a 2.5 allen wrench and tighten the bottom side of the handle
Nov 15, 2009 | Fisher and Paykel RF201ADUX Bottom Freezer...
The door handle on the freezer of my GE Profile Bottom Freezer Refrigerator came off.
Hi, Please get me the model # from the label inside the refrigerator and I will look this up for you. Most handles have a set screw that tightens down.
Vic
Jul 11, 2009 | General Electric Profile PFSS2MIXSS...
Hotpoint side by side no dispensor door handle loose
Removing the door gasket would probably reveal screws to separate both shells of the door - warning: door gaskets are expensive and may be hard to find on a fridge that old, so be gentle with it.
JOAT
Jun 17, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
GE French Door handle loose
To tighten the screw the first step is to remove the handle. With this model just pull straight up on the handle. It can take a little force but after it finally unclips it moves up an inch or two then pulls straight out. Good luck!
Nov 07, 2008 | GE Refrigerators
Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Nov 07, 2008 | Refrigerators
Loose handle on fridge freezer door.
that handle is just pressure fit on the clips securing to the door. grab hold ad PULL.and i mean PULL the the right. it will snap off just make sure you really PULL it. after that you cantighten the brackets on refig and inside the handle as well
Mar 08, 2008 | Amana AFD2535DES French Door Refrigerator
To fix this you will need an Allen wrench small one there are 2 set screws on the inside part of the handle (on side toward the center) you wil need to tighten these to fix your problem
Feb 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
868 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
