Question about Toshiba TLP S30 Multimedia Projector
I have a Toshiba TLP S30 projector and have just replaced the lamp. However even after following some of the suggestions on how to reset the lamp... Example: ("Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go") ..this does not work for me. Has anoyone actually tried this on an TLP S30 ? or do you know if there is another way of resetting the lamp. Thank you. R
  • Toshiba Master
  • 17,328 Answers
If you let the lamp go all the way out, there is a chance that it took out a fuse when it went out. This would require you to get the unit serviced and it will not be cheap.
Posted on Oct 17, 2010
AFTER REPLACEMENT OF TOSHIBA PROJECTOR TLP791 LAMP IS NOT WORKING . PLEASE SUGGEST THE LAP TIMER RESET METHOD. R K MISHRA SATNA MP INDIA
To reset the lamp hour of Toshiba TLP791, do the following.
1. Turn-off the device by pressing the "ON/STANDBY" and unplug the power cord.
2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord .
3. The lamp operation counter will automatically turn to zero.
4. Check if the lettering "0H" appears on the lamp operation counter in the status display.
5. After the lamp operation counter has turned to zero, turn off the projector by pressing "ON/STANDBY" and unplug the device.
The lamp reset procedure is over.
ok
Jul 16, 2011 | Toshiba TLP 791 Multimedia Projector
Toshiba TLP s30 projector identification part
http://www.nextag.com/toshiba-tlp-s30/search-html
Mar 28, 2008 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP projector identifiation part
You need to check lamp again, it may be not well mounted.
How to reset lamp hours & total time toshiba projector TDP-T95
Supposedly the lamp has a chip that keeps track of the used time. The manual says to check in the instructions that came with the lamp. Others say that LG will not reveal how to do it. Perhaps you could ring LG service and give them your machine serial number and request that as the owner you want the correct information.
Apr 11, 2011 | Toshiba TLP S30 Multimedia Projector
Reset lamp timer
If you go into the info menu you should see lamp hour meter, should be option there to reset it.
only do so if you have put in a new bulb as bulbs can explode if they go over the hour usage time.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Toshiba TLP S30 Multimedia Projector
What bulb is needed to replace in the projector?
three green lights come on then the standby light goes red and remains on when the projector is plugged in. The lamp and fan do not come on when the power button is pressed instead the lamp light comes on red.
Jul 13, 2010 | Toshiba TLP S30 Multimedia Projector
How do I reset the lamp timer?
go into the menu..under tools or setup you should see lamp hours and reset
Mar 11, 2010 | Toshiba TLP S30 Multimedia Projector
I have a Toshiba TLP-S30 and lately the color balance of the projected image is way off. I've tried adjusting the color balance via the menu, but no improvement. Could this problem be fixed with a new...
reset the settings to factory default. sometimes the lamp will burn at a lower temp at the end of it's life and emits a different color. might be the lamp or the ballast. if all else fails, replace the main board.
Oct 18, 2009 | Toshiba TLP S30 Multimedia Projector
Internal fan location in TLP S30, I get an error message about internal fan problem
one of the fans arent working. there should be at least 3- one for the lamp, one for the power supply, and at least one for the lcd panels. you should be able to see the one for the lamp and power supply from the outside. if both are spinning, it's the other one, which you might be able to see from the bottom.
Sep 22, 2009 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP S30 Multimedia Projector Logo
169 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
