Question about Lexmark Office Equipment & Supplies
How to set up my printer - Lexmark Office Equipment & Supplies
  • 146 Answers
I will probably need more information like the model number of your printer, how it is connected to the PC (USB, Parallel, Wi-Fi, or ethernet), if you have any driver disks, what operating system you are using, etc.. to be able to provide a solution to your problem. Could you please elaborate on these items?
Posted on Jun 03, 2008
Print multiple copies
Please check printer setting if you are any other printing setting then this types of issue create. If you are not set then Go to Printer icon and right click and property option and set default setting option. your printer also set auto. then you check it is not solved then reinstalled old printer driver and again installed printer driver i hope solved your issues.
Thanks,
HP Printer Support
Apr 03, 2014 | HP LaserJet 1600 Printer
Hi , I have a problem with zebra 105sl printer , everytime i print somthing i have to make changes to the settings , eg. make it darker .When i save the settings permenent next time i go tto print i have...
The settings in the printer driver are overriding the saved printer settings.
Do this:
1. Correct the printer settings and save them permanently.
2. Print saved configuration for future reference and to see if it changes.(Power on while holding cancel)
3. Print a label from computer.
4. Print configuration again (Power on while holding cancel).
5. Compare the 1st and 2nd printouts. If they are different then the printer driver is changing the printer settings. In other words the printer settings and the driver are different and the driver settings will override the printer settings before printing.
6. Change the driver settings and this won't happen. Increase the darkness setting in the driver.
Aug 13, 2011 | Zebra 105SL Thermal Label Printer
How can I alway print in black. I do not want to print in color
Open the printer settings from the control panel and set the printer preferences from there.
You can also click start menu, then click printers and faxes on the computer onto which the printer is installed. When the list of printers are shown, right click on the printer whose settings you want to change. Select printing preferences. Select the printing color settings set appropriately.
Apr 22, 2011 | Dell 1320c Laser Printer
I have an HP Photosmart C7280 Printer wireless connected. The Pause Printer and Use Printer Offline are always checked on. How do I change the default status on these 2 items to default off. Whenever I...
To change the default printer settings or to restore the settings in your printer, click on the start menu, select Settings, and then select "Printers" from the menu that appears. After that you could right-click the printer that you would like to change settings for, and then select "Properties" from the menu that appears. This would open up a tabbed window that would display many settings that you can change. You could change the settings you need to change or there is another option that you would find to restore to defaults, this would allow you to set the default settings on your printer.
Jan 06, 2011 | HP Photosmart C7280 Printer
How to set printer as default
  • Click on the Start menu and click on Settings, then Printers.
  • A window will appear showing the icons of all the printers that are installed on your system. Right-click on the icon for the printer you want to use as the default. A menu will appear.
  • Click on Set as Default
  • To make sure the correct printer is now set as the default, right-click on the printer icon again. When the menu opens, a check mark should appear before Set as Default.
  • Read more: How to Change the Default Printer ' eHow.com http://www.ehow.com/how_6097_change-default-printer.html#ixzz14tGsLTEN
    please leave feedback if this helped you :)))
    Nov 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
    How do I configure a Zebrazm4 Plus printer for a
    Usually the easiest way to do this is to make sure the printer driver you're using is set for continous labels. This setting will vary depending on the driver / software being used to print labels. You can also go into the SETUP mode on the printer and make sure MEDIA TYPE is set to continous. Be aware that most printer drivers will override the setting in the printer. You may set to continous in the printer but if the software is set for die cut labels, then the printer will act for printing die cut labels when a format is sent to the printer.
    Mar 25, 2010 | Zebra Z4Mplus Label Printer
    How do I set the printing preference for my smart label printer 240--I have windows xp
    Go to the Start, Settings, Printers. Select your printer, the set it as your default printer.
    You can also get to the printer by way of the Control Panel.
    Dec 30, 2009 | Seiko Smart Label 240 Thermal Printer
    I would like to know how to reset the Lexmark E260dn to factory defaults. The printer was set with a static IP address and no longer exists on THAT network. I need to set it up as a DHCP client again to...
    Restoring the factory default settings
    Do one of the following:
    • If your printer is on a network, access the Embedded Web Server:
    1 Type the printer IP address into the address field of your Web browser.
    Note: If you do not know the IP address of the printer, print a network setup page and locate the IP address in the TCP/IP section.
    2 From the Settings screen, click General Settings.
    3 Under Factory Defaults, select Restore Now, and then click Submit.
    • If your printer is connected to a computer by a USB or parallel cable, use the Local Printer Settings Utility for Windows or Printer Settings for Macintosh.
    1 Open the utility.
    2 Do one of the following:
    – From the Local Printer Settings Utility menu bar, click Actions Restore Factory Defaults.
    – From Printer Settings, click Factory Defaults.
    Warning—Potential Damage: Restore Factory Defaults returns all printer settings to the factory default settings except Network/Port menu settings. All downloads stored in RAM are deleted. Downloads stored in flash memory or on a printer hard disk are not affected.
    Or please download the user guide from this link and follow the instructions
    http://static.tigerdirect.ca/pdf/Lexmark-E260D-Series-Mono-Laser-Printer-Manual.pdf
    Hope this will help you
    thanks
    Oct 01, 2009 | Lexmark E260dn Laser Printer
    Page alignment
    Hi rene_schuste: This info may help you with your problem.
    If you used an older or different HP LaserJet printer driver (printer software) to create the document,
    or if the printer Properties settings in the software are different, the page format might change when
    you try to print using your new printer driver or settings. To help eliminate this problem, try the
    following remedies:
    ● Create documents and print them using the same printer driver (printer software) and printer
    Properties settings regardless of which HP LaserJet printer you use to print them.
    ● Change the resolution, paper size, font settings, and other settings.
    Graphics quality
    The graphics settings might be unsuitable for your print job. Check the graphic settings, such as
    resolution, in the printer Properties and adjust them as necessary.
    Apr 08, 2009 | Office Equipment & Supplies
    Printer Defaults
    try setting up your sizes etc on the required printer in" printers and faxes" first and then access your print system , when you then select the "print" function you will find the sizes etc that you have set up in printers and faxes are already set for you , unfortunately it will only save for a few prints and then will default ,however it defaults to the settings you have already set up in printers and faxes
    Jan 27, 2008 | Zebra Printer 140-751-00000
    15 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
