Question about Tappan TGF657 Gas Kitchen Range
I just recently bought a house with a Tappan Gas Stove model TGF657 and I am having problems lighting the oven. I have never used or seen a gas stove before.
    Sergeant:
    Champion:
  • 226 Answers
Will be very careful went lighting the poilt ligth.ok make sure the gas it on and the knob on the sotve is off raise the hood you should see the poilt ligth between the burners ligth it with a matche in each one go to the bottom open the door there a poitl ligth at the back to the top ligth it
Posted on Oct 17, 2010
Burners work properly. Stove won't heat. Pilot light is out. Won't re-light with a match. When the stove is on the rectangular flint block heats up and glows orange.
Hi, Jus because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 14, 2010 | Tappan TGF657 Gas Kitchen Range
I have a Tappan gas stove that takes forever to heat up (oven) and I smell gas before it starts to heat. Help?
Thanks for answering my questions. It sounds to me like your oven's safety valve is going bad. There have been many times when I am at a customer's house and it has been a while since they used the oven, and it seems to take forever to light the oven. Just tapping the oven safety valve with a wrench or handle of a screw driver is all that's needed to open the valve and light the burner. As long as your oven's igniter glow bar is lighting, (glowing orange or sparking), then the oven safety valve is your problem. It is a silver rectangular valve in the far back bottom of the oven with the orifice on top of it and the burner tube coming down over the orifice. Try tapping it and see if that works. Otherwise, just have it replaced. Douglas
Jul 03, 2010 | Tappan TGF657 Gas Kitchen Range
Ove burner
heatman101
May 21, 2010 | Tappan TGF657 Gas Kitchen Range
Modern maid double built in oven. gas stove. pilot light won't stay lit
it"s a built in range top, and started making clicking noises randomly
Dec 13, 2009 | Tappan TGF657 Gas Kitchen Range
My oven door will not close all the way.. Help
In order for you to give me the solution I have to pay for it.... You are asking me to give you my soultion free?????
Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
Jun 27, 2009 | Tappan TGF657 Gas Kitchen Range
Oven will not light
Your ignitor is going out and is to weak to open due to saftey. Replace the ignitor for the fix.
Phil
Apr 11, 2009 | Tappan TGF657 Gas Kitchen Range
Oven door
replaced oven igniter without removing oven door
Jan 08, 2009 | Tappan TGF657 Gas Kitchen Range
Tappan oven
Remove the burner grates. Below that are 'trays' that can be lifted out.
Dec 12, 2007 | Tappan TGF657 Gas Kitchen Range
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan TGF657 Gas Kitchen Range Logo
140 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
