Question about Apple 160 GB iPod Classic (Silver) + Deluxe Accessory Kit (MB145LLA/K2)
Hi my Ipod 160 gb keeps restarting by itself. I've tried to restart it manually but it never gets past the logo page until it turns off and then turns on again. When I go into diagnostic mode I can enver get past the plug in the fw as I don't know what the fw is. When I go into disk mode and plug it into my computer it doesn't show up in itunes. Also it shows up it My Computer but when I try to open up the folders in it, it says to plug a device into the drive. Can anyone please help me?
jazzyboy11
  • 728 Answers
SOURCE: My Ipod 3rd gen. wont work other than when its pluged into the pc
Your battery is most likely dead to the point where it can no longer hold a charge, which is the reason that when you unplug it from the computer, it dies instanly. Batteries are pretty cheap going up to about as high as $25 and if you get it done at a ipod place, installation should not be that much.
Posted on Aug 05, 2009
Bowmans IT
  • 85 Answers
SOURCE: Ipod 30 gb
Reboot your ipod in Disk Mode then try itunes again. Also make sure your itunes is setup so it boots up when it sees it. (that way you know it sees the device)
As far as seeing it "usb mass storage" that is a good sign. You maybe able to recover items with a good friend called LINUX which is compatable with apple software.
Disk Mode:
Hold the select and menu button and once the device turns off hold the select and play button and hold it until it says Disk Mode.
Once booted in Disk Mode try to connect via usb.
Posted on Nov 13, 2007
SOURCE: ipod not recognized by computer or itunes
contol panel / administrative tools/services/ press stop on apple mobile devices and then start again this should work.
Posted on Jun 15, 2008
Bubbabear64
  • 2794 Answers
SOURCE: PARENTS WILL KILL ME CAUSE OF IPOD FREEZING
Press and the center button while pressing down on the menu button. That will reboot your Ipod.
Posted on Aug 28, 2008
mneilsen2084
  • 342 Answers
SOURCE: IPod froze up
Have you attempted to reset the iPod yet? If so and it failed you should attempt to force the ipod into disc mode and restore using iTunes. Below is a step by step on all three parts of the resolution. If for any reason your issue is not resolved after completing; please do let me know. :)
Learning how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod. The screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center. --------------------------------------------------
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Posted on May 14, 2009
How do i reboot my i phone
Hi Kevinjones, there are several ways to reboot your iPhone.
Visit the link below for more help on restarting your device:
How to restart
  1. Press and hold the Sleep/Wake button until the red slider appears.
  2. Drag the slider to turn your device completely off.
  3. After the device turns off, press and hold the Sleep/Wake button again until you see the Apple logo.
How to force restart You should force restart your iPhone, iPad, or iPod touch as a last resort, and only if it's not responding. Follow these steps to force restart your device:
  • On an iPhone 7 or iPhone 7 Plus: Press and hold both the Sleep/Wake and Volume Down buttons for at least ten seconds, until you see the Apple logo.
  • On an iPhone 6s and earlier, iPad, or iPod touch: Press and hold both the Sleep/Wake and Home buttons for at least ten seconds, until you see the Apple logo.
Restart your iPhone iPad or iPod touch
turn-off-iphone-56a534795f9b58b7d0db7c05-iimipzg2co5ayivpzukcscbp-5-0.jpg -josh
Mar 22, 2017 | Apple iPhone Cell Phones
Ipod has locked up with a blank grey screen
how old is the battery it might need to be replaced
Charge the iPod
If your iPod touch suddenly goes blank while you are using it, the culprit could be a low battery.
Prior to the screen blanking you may see a low battery indicator.
If the screen is completely blank, try plugging the iPod touch into a power source and letting it fully charge before attempting to use it again.
Restart the iPod
If you've got a white or gray screen, try to restart the iPod.
Sometimes a simple restart will solve the problem that initially caused the white or gray screen, and the iPod will work as expected once you have turned it off and on.
Reset the iPod
Resetting the iPod Touch goes a step further than just restarting, and it is a good option if you've charged the iPod and restarted and you're still seeing a blank, white or gray screen. Press on the "Sleep" and "Home" buttons simultaneously for at least ten seconds before releasing the buttons. At this point, you should see the logo or a battery icon, if the phone needs to be charged.
Restore the iPod
If nothing else has worked to remedy the malfunctioning screen on your iPod touch, try restoring the device. Connect it to your computer and open iTunes, then click on "Restore" which is found under "Summary." Be sure to back up your files when prompted, because the restore will change all of the settings on your device back to the factory default.
If even this does not work, you almost certainly have a hardware issue, and will have to take the device to an Apple store for examination and possible replacement.
hope this helps
Oct 06, 2012 | Apple iPod touch 4th Generation MP3 Player
How do I unlock a locked up ipad?
If you've got a locked up iPad app or otherwise misbehaving iPad, and want to reboot / reset your iPad, simply hold the sleep and home buttons together until the iPad restarts.
You'll see the shutoff slider come up first, but just keep holding. The screen will go blank and the Apple logo will reappear as the iPad reboots.
Note: this does not reset any data on your iPad. This is just a restart, equivalent to rebooting your computer.
Aug 18, 2012 | Apple iPad 64 GB 3G Tablet PC
I've switched of my ipod....later ven i tried to restart,it had frozen.....plz give me a solution to restart it
if it is an iPod touch, Hold down the sleep button and the home button together until the screen flickers and you then see an apple logo. If it is an iPod classic ,nano (except the latest), mini, hold down the select and play button together until the screen flickers and you see an apple logo.
Jun 08, 2011 | Computers & Internet
Screen shows usb and Itunes but computer doesnt recognize ipod.
1. Verify if your pc passes the system requirements.
(a) usb 2.0 port
(b) You are running the latest version of itunes
2. Recharge your iPod Touch
3. Check USB connections. Use a USB port that is built into the computer instead of using an external usb hub.
4. Restart iPod Touch. Do the following steps: To restart iPod touch, first turn iPod touch off by pressing and holding the Sleep/Wake button until a red slider appears. Slide your finger across the slider and iPod touch will turn off after a few moments.
Next, turn iPod touch on by pressing and holding the Sleep/Wake button until the Apple logo appears.
Is iPod touch not responding? To reset iPod touch, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds, until the Apple logo appears.
5. Restart your computer then reconnect your iPod Touch
6. Try reinstalling iTunes. And if this doesn't resolve the issue, you can also try uninstalling iTunes then reinstalling the latest version.
7. Check if there are third-party software that might prevent iTunes from recognizing your iPod touch. Such software may be security software, anti-virus software and webcam drivers. What you can do is adjust the software settings or you may also temporarily disable the software.
If you find this helpful, kindly click the thumbs up button. Thanks! :)
May 23, 2011 | Apple iPod touch
My Ipod touch screen suddenly began to display everything huge. What happened?
Hi mariaelenaga,
To set a minimum font size for messages:
Choose "Mail, Contacts, Calendars" > Minimum Font Size, then choose Small, Medium, Large, Extra Large, or Giant.
Also, you may need to try the following:
Restarting and Resetting iPod touch
If something isn't working right, restarting, force quitting an application, or resetting iPod touch will likely solve the problem.
Restart iPod touch: Press and hold the Sleep/Wake button until the red slider appears.
Slide your finger across the slider to turn off iPod touch. To turn iPod touch back on, press and hold the Sleep/Wake until the Apple logo appears.
If you can't turn off iPod touch or if the problem continues, you may need to reset. A
reset should be done only if turning iPod touch off and on doesn't resolve the problem.
Force quit an application: Press and hold the Sleep/Wake button on top of iPod touch
for a few seconds until a red slider appears, and then press and hold the Home button
until the application quits.
Reset iPod touch: Press and hold the Sleep/Wake button and the Home button at the
same time for at least ten seconds, until the Apple logo appears.
This information was sourced from the iPod Touch official user guide at:
http://manuals.info.apple.com/en_US/iPod_touch_3.0_User_Guide.pdf
Hope this helps.
Best regards,
CellPhBuddy.
Mar 17, 2011 | Cell Phones
Hi my ipod video 30 gb wont play music anymore just gets stuck at 0.00 i tried restoring and restarting it but nothing worked
Have you tried this with the device unplugged?
Mar 15, 2011 | Apple iPod MA446LL/A MP3 Player
My ipod 80 gb is frozen in fast forward is their a way to reset it??
try resetting it. Press and hold the center button and the top button of the scroll wheel until it turns off and then retry it.
I hope this works.
Nov 11, 2009 | Apple iPod MA446LL/A MP3 Player
I cant get my ipod to sync. the message i get is, "the ipod jeremy cannot be synced. the required disk cannot be found." At the same time, i see the device on itunes
Something has corrupted so you need to reinstall iTunes, restore the ipod then resync it.
Download the very latest version of iTunes from the Apple site. This will update all the drivers on your PC, so install that.
Once installed, before connecting you ipod, press and hold the Select and Menu buttons on the ipod until the apple logo appears, then press and hold the Select and Play/pause buttons until it displays 'ok to disconnect'. Now connect it to the pc - this puts it in disk mode. When it appears on itunes click the 'Restore' button on it's main page.
That should, once it's updated, restarted (let it do this itself) and resynced, have you up and running again.
All the best
Sean
PiDigital
Dec 31, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Continious restart
when it restarts, does it immidiately restart again? like a cycle? that happened to my old compputer, the hard drive was shot. mabe that's what happened to you. a new hard drive for apple classic 80 gb ipod i found was around $150-$170 ouch. take it to apple, ask them to run diagnostics, tell them you think your hard drive is worn out or something.
Nov 18, 2008 | Apple iPod classic MP3 Player
Apple 160 GB iPod Classic (Silver) + Deluxe Accessory Kit (MB145LLA/K2) Logo
396 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
