Question about Acer Computers & Internet
NTLDR is missing Press Ctrl Alt Del to restart
  • CPCI
    CPCI Oct 17, 2010
    what OS are you using ?
    get your recovery Cd ready ,, its a simple fix
    NTLDR is Missing.
    Issue:
    NTLDR is Missing.
    Related errors:
    Below are the full error messages that may be seen when the computer is booting.
    NTLDR is Missing
    Press any key to restart
    Boot: Couldn't find NTLDR
    Please insert another disk
    NTLDR is missing
    Press Ctrl Alt Del to Restart
    Causes:
    1. Computer is booting from a non-bootable source.
    2. Computer hard disk drive is not properly setup in BIOS.
    3. Corrupt NTLDR and/or NTDETECT.COM file.
    4. Misconfiguration with the boot.ini file.
    5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
    6. New hard disk drive being added.
    7. Corrupt boot sector / master boot record.
    8. Seriously corrupted version of Windows 2000 or Windows XP.
    9. Loose or Faulty IDE/EIDE hard disk drive cable.
    10. Failing to enable USB keyboard support in the BIOS.
    Solutions:
    Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
    Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any type of card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer.
    If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
    If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
    Second, when the computer is booting you should receive the below prompt.
    Press any key to boot from the CD
    Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
    Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive. Additional information about checking the CD-ROM drive connections can be found on document CH000213.
    Verify that your computer hard disk drive is properly setup in the BIOS / CMOS setup. Improper settings can cause this error. Additional information on how to enter the BIOS / CMOS setup can be found in document CH000192.
    Windows 2000 users
    Windows XP users
    Windows XP users
    1. Insert the Windows XP bootable CD into the computer.
    2. When prompted to press any key to boot from the CD, press any key.
    3. Once in the Windows XP setup menu press the "R" key to repair Windows.
    4. Log into your Windows installation by pressing the "1" key and pressing enter.
    5. You will then be prompted for your administrator password, enter that password.
    6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
      copy e:\i386\ntldr c:\
      copy e:\i386\ntdetect.com c:\
    7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
    if this helped you , please issue positive feedback for me
    Master:
  • 397 Answers
The issue is your system is not loading off of the boot drive- check for usb keys, floppies, even sometimes cds can cause the issue. If that does not work, you'll need to get your copy of windows, boot to that disk, and run a chkdsk /r in the repair option. If that does not work, you will need to reinstall Windows.
Posted on Oct 17, 2010
  • 31 Answers
In my experience, NTLDR is usually caused by a failing hard drive, however sometimes other factors are at fault.
There are various fixes for the different operating systems that Microsoft offers. Since you don't state your operating system I'd say start here and read.
http://www.proposedsolution.com/solutions/ntldr-is-missing-press-ctrl-alt-del-to-restart-2/
Then there's always microsoft's take on it here:
http://support.microsoft.com/kb/320397
4 Suggested Answers
  • 47 Answers
SOURCE: NTLDR is missing
it means press ctrl+alt+delet at the same time and then you can turn of things from there
Posted on Jun 23, 2009
ginko
  • 19396 Answers
SOURCE: NTLDR is missing..how can i log-in to the windows?huhu..pls help
When NTLDR is missing it means that the system files had been damagaged.
You need to use recovery CD, or Windows install disk to reinstall the system on your laptop.
If you do a partial recovery (with recovery CD) or an upgrade installation (with Windows CD), and you chose not to format the system, then your data should still be inside the hard drive after setup.
Posted on Aug 28, 2009
  • 31 Answers
SOURCE: NTLDR is missing Press Ctrl Alt Del to restart
NTLDR is missing press CTRL ALT DEL to restart.. How to fix wothout windows xp install or program disk
Try pressing F8 just before it tries to boot, you may be able to get into your system and back up your data. Then check out flea bay for a copy of XP.
Apr 09, 2014 | Dell Computers & Internet
NTLDR is missing Press Ctrl+Alt+Del to Restart hmm..there's still no effect even if i press Ctrl+Alt+Delete..what should i do?
1. Try the repair options, if using Windows 7.
or
2. Try to repair the startup with your original windows install DVD.
Oct 07, 2011 | Computers & Internet
My Averatec 3200 series won't boot up. It says "NTLDR is missing Press Ctrl+Alt+Del to restart" Pressing ctrl+alt+del doesn't help. What, if anything can I do?
The NTLDR is the boot loader of Windows - if it's missing the OS can't boot. The only reliable and easy way to fix that is to do a Repair install - everything will be kept and the missing files reloaded.
Nov 27, 2010 | Averatec 3200 Notebook
Aug 28, 2009 | ASUS Eee PC 1000H Laptop
NTLDR is missing
Jun 23, 2009 | HP Compaq Evo n400c Notebook
NTLDR Missing, Press Ctrl+Alt+Del to restart
What happened is when you changed the drive letters you switched one that should not have been changed.... You need to change it back so the original C: is C:
Because the original NTLDR file was on the C: drive which is the Windows XP Boot Loader and when you swapped it it couldnt find the ntldr on the new C:
From my opinion the only way to switch it back is to reinstall the OS onto the drive you want to be C:
Dec 18, 2008 | Microsoft Windows XP Media Center Edition...
NTLDR is missing. Press CTRL-ALT-DEL to restart
NTLDR MISSING PRESS CTRL+ALT+DEL TO SESTART. WEN I DO THEN WINDOW WITH ALL THE SET UP COMES. PLEASE HELP!!1
Apr 24, 2008 | Compaq Evo D500 PC Desktop
Computers & Internet Logo
251 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
