Question about HP Pavilion dv7-1245dx Notebook
I press the power off button and it doesn't power off
    Master:
  • 397 Answers
Hold the power button down for about 10 seconds- that will force the system to shutdown. The issue is caused usually by a background running program or driver preventing the system from fully shutting down.
Posted on Oct 17, 2010
    Problem Solver:
  • 16 Answers
You should never power down by pressing the power button unless your system is deadlocked and won't respond to any other actions. Powering off in this fashion can cause you to lose data, corrupt files, and improperly shut down Windows.
Nonetheless, if you are in need of shutting down the laptop in this fashion you must hold the power button instead of only pressing it. You'll find this in the power settings of the device. Honestly, the power button may even be set to do nothing, which is possible.
To properly shut down your new Pavilion laptop, which should be running Windows 7, follow this process: Click Start > Shut Down
Start is now simply a circular Windows icon in the bottom left corner of the screen and shut down has an arrow pointing down next to it. Click the words shut down instead of the arrow which will bring up other power save options.
Kindle Fire
Press and hold the power button for fifteen seconds or so. If it prompts whether you want to shut down, ignore it and keep the power button pressed until it shuts off. Release the button, then press and hold for a second or two until it starts to reboot. Does it reboot and operate normally now?
Jun 11, 2013 | Tablets & eReaders
Engine doesn't crank over, blown fuses and certain things not working?
sound like dead battery.no power to fuses if battery dead use digital voltmeter check battery volts should 12.6 volts if not have battery charged tested.if battery 4 or 5 years old battery could be faulty.
Apr 29, 2013 | 2010 Mitsubishi Lancer
HP DC7800 doesn't wake up (and power switch does nothing!)
Bad setting. If you press and hold the power button, the computer will shut off. That will keep you from having to unplug it.
Jan 28, 2013 | HP dc7800 Business Desktop Small Form...
Laptop is a sleep
press any key to wake it up, if that doesn't work for some reason press the power button once. it should wake up. if all else fails hold the power button down for 5 seconds until it shuts off and reboot it.
May 05, 2012 | IBM ThinkPad T30 2366 Notebook
How can i bypass my forgot admin password on my compaq armada e500
With the older Compaq Armada E500 Notebook PC, I believe;
1) Remove the CMOS battery.
2) Leave it out for 30 minutes.
3) Press the Power On button, and hold it for a count of 10 seconds. Let go of the Power On button.
Press it again. If the Power On light comes on, hold the Power On button in, until the light goes out. Keep pressing, and holding the Power On button in, until the Power On LED light does Not come on anymore.
Reinstall the CMOS battery. WAIT 1 minute, turn the laptop on.
If this doesn't do it, there is a capacitor inside the laptop keeping residual power. There may be two copper pads that are briefly touched across, to dissipate this residual power.
Perform the removal of the CMOS battery first. If this doesn't work I'll try to find info on the copper pads. (They are usually under the Wireless Card, and a small piece of Mylar plastic sheet)
Post back in a Comment as to your findings.
Regards,
joecoolvette
Jan 22, 2012 | Compaq Computers & Internet
Neo Notebook model no. LC89-black screen only.
  1. All Operating Systems
    • 1 Remove any discs in the computer.
    • 2 Hold the power button down until the computer turns off.
    • 3 Press the power button to turn the computer on. If this doesn't work, proceed to step four.
    • 4 Remove the battery and unplug the netbook. Wait 30 seconds.
    • 5 Reinstall the battery and plug in the netbook.
    • 6 Press the power button for ten seconds. If this doesn't work, proceed to step 7.
    • 7 Insert the end of a paperclip into the reset button to reset the netbook. The reset button is a small hole that usually appears next to the USB and other ports.
    Windows 7
    • 1 Create a new Notepad file.
    • 2 Type this code:
      taskkill /F /IM dwm.exe
    • 3 Save the file as displayfix.bat in the following location: C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
    • 4 Restart your computer.
Sep 20, 2011 | Computers & Internet
When I want to print it says error 6C10 switch off switch on. Doesn't work!
that indicates full waste ink pads/absorbers. to reset the counter try this:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
any way if the absorber/pad is full, it have to be cleaned!
Sep 20, 2011 | Canon PIXMA iP4600 Color InkJet Photo...
My mp250 printer shows error p08, I can't use it in any way. I replaced the black ink tank with a new one and tried resetting the printer and it doesn't solve the problem.
Follow the instructions step by step
  1. Turn off printer, cable power still plug in,
  2. Press Stop/Reset button don't release
  3. Press Power Button don't release and than release Stop/Reset button
  4. Press Stop/Reset button 2X , wait until service mode to " 0 "
  5. Turn off printer, cable power still plug in
  6. Press Stop/Reset button don't release
  7. Press Power Button don't release and than release Stop/Reset button
  8. Press Stop/Reset button 4X , wait until service mode to " 1 "
  9. Turn off printer, and loose cable power, wait one minute.
  10. Connect cable power, turn on printer again, now this printer ready to use.
Jul 06, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I have dish network need code to record to vcr . three diget code. wv206a
You may want to try a method called a Power Scan to program this. The steps are included below:
Power Scan DVD VCR:
1.) Press and hold the correct VCR button (about six seconds) until all mode button backlights come on, then release.
2.) Press 500 pound (#) then record three times.
3.) With the desired equipment on, press and hold the VCR/DVD button until all mode button backlights illuminate (about 3 seconds), then release.
4.) Press and release the Power button.
5.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
6.) Press the POUND (#) button
If this doesn't work repeat steps 3-6 if the lights at the top of the remote blink rapidly then you have tried all codes possible.
Daniel Busa
DISH Network
Customer Service
Apr 23, 2011 | Funai TruTech DVDVCR Dual Recorder
HP Pavilion dv7-1245dx Notebook Logo
399 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
