Question about Refrigerators
General electric refridgerator won't despense water in the door
My general electric fridge won't despense water in the door but will despense ice
  • tappej Jun 26, 2008
    ge profile pss26sgrcss refrigerator won't dispense water.  i changed the filter.  didn't help.
    thanks
Have the same thing happen a few times. The posted solution is correct, but in the mean time you can thaw the line by heating with a blow dryer inside and outside the door, and around the ice dispenser. This should take about 15 mins.
Posted on May 08, 2009
Hotpoint sidebyside refrigerator dispenses ice but not water,
Posted on Apr 27, 2011
You and I are the lucky holders of a frozen internal water line. It's inside the freezer door, and you cannot take the door apart to access the frozen line section. I wouldn't be suprosed if you also had to have the door replaced in the past because of moisture in the door (and the new door is thicker).
The solution is to hire a contractor to verify the problem, and then have them complain to the "moisture team" at GE. If you are lucky, you will get a new door. If you are not lucky, you either have to buy a replacement door, or live without water from the dispenser.
Posted on Oct 17, 2008
The ice maker makes ice and dispense water, but won't dispense ice. Cleaned out ice tray, not ice blocking any discharge area. When you try you can hear the ice dispenser door open, but the motor to...
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
My water despenser on my fridge stopped working. the ice machine is still working what could be wrong with it.
Could be a bad water valve on the rear of the unit or the water line is frozen for the water in the door.
Remove the toekick plate under the front and disconnect the water coupling to water in the door.
Activate the water switch to see if water comes out there.
Aug 04, 2011 | Refrigerators
When ice despenser in door is pushed, power dims, temp guages on fridge side go out and no ice. Water will despense but takes several trys to work. Ice maker works..
You have a supply voltage issue on your main board. This is located at the back of the refrigerator in a small compartment. You can get the part and replace it yourself, just make sure you un-plug the fridge before you start the project. It is pretty simple to do, so give it a shot.
Good luck!!
Jun 14, 2010 | GE Profile PSS26NGS Side by Side...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker does not make enough ice - it doesn't fill up the bin
check for water in ice maker with finger and if no water check water connection and water valve in back of fridg on bottom . you need to pull panel and check valve and water make sure it is on and not leaking...
Aug 12, 2009 | General Electric GFSS6KKXSS Stainless...
Icemaker makes ice but wan't despense, also water wan't despense
i have model mfi2067aeb . the ice maker won't dump the ice. the arm is up that tells when the tray is full. can't get it down.
Jul 16, 2009 | Maytag MFI2067AES Stainless Steel Bottom...
Refridgerated water spout suddenly stopped producing water
Have you changed the water filter. It should be located in the front loer grille of the refrigerator.
Jan 10, 2009 | Refrigerators
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
Refrigerators Logo
244 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
