Question about Sony Grand WEGA KF60DX100 60" Rear Projection Television
How to fix tv shutting off and the constant blinking standby light
  • Sony Master
  • 5,138 Answers
Lamp. Mats has them for $99.00 1-800-628-1118
Posted on Oct 17, 2010
Sony LCD TV Red LED light constantly blinking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Dec 06, 2015 | Sony KLV-32S550A 32 inch Multi-System LCD...
My Samsung LCD smart tv model UN46D6000SF has no picture, and the power light just flickers constantly. I know it's not the compacitors they are in great condition not defective, even when I unplug the...
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 28, 2013 | Televison & Video
Sony kp41s5u rear projection tv constant blinking standby
Power supply or set is not allowing set fully on as a problem in any of a number of areas in the set. Try unplugging set for a while to see if that helps or have a tech look at it.
Dec 23, 2012 | Televison & Video
Tv will not stay on standby timer light flashing
On Sony the standby or red is for shutdown---
If you unplug the set and plug it back and turn it on and it repeats this look to see if the light is either constantly blinking or blinking a specific number of blinks---specific number would be an error code.
Apr 29, 2012 | Televison & Video
Hey there, I have a Sony TV and everytime I turn it on it will turn on for approximately 10 seconds with no picture but with sound, but then after that it automatically shuts off. The standby light is...
Hi slittle, my name is John. Welcome to FixYa. You have a power failure in one or more of the circuits. When you turn it on, it goes into standby mode, (safety mode), (protection mode). Sony has a blinking code they go by, depending on how many times the light blinks. Its called a Self Diagnostics Test. The TV will shut off to protect it from further damage. Count the number of blinks. Thanks for choosing FixYa...John
Dec 09, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony Trinitron shut down last night. I
4 times standby light blink shows that tv got problem in vertical deflection section and probably vertical output IC got defective, need to be replaced.
Replacement of parts in circuit board requires soldering work and expertise so call local tv repair shop guy if you are not familiar with soldering work.
Thanks.
Jul 25, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony Grand WEGA KF60DX100 60" Rear Projection Television Logo
117 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
