Question about GE Profile WPRE6100G Top Load Washer
There is a tube coming from the top of the tub and wash water squirts out of the bottom of the tube and soaks the floor. Is this tube supposed to have a plug in it so the water don't come out?
    Sergeant:
    Champion:
  • 226 Answers
No should hook back at the top and to bottom
Posted on Oct 17, 2010
Hotpoint wf320p washing machine leak
pull the plug
check the pipes from the soap dish to the tub
Feb 09, 2014 | Washing Machines
Is water supposed to enter the tub during the first half of the final spin cycle (not rinse cycle)?
no spin cycle don't have water it could be the pump is not getting the water out fast enough, could be clogged or the rear drain pipe is blocked or bent. failing them to problems it could be the valve its self.
Aug 04, 2017 | GE WBSE3120B Top Load Washer
My Maytag LAT2600AAE will not stop filling once it has a full tub to begin a cycle, it flows right into the overfill and right down the drain.... so it never starts a cycle... How do I fix this???
Easy fix, no parts needed! The small hose that comes from the bottom of the tub up to the water level switch is supposed to be air tight. As the water rises in the tub the pressure builds in that small tube.
The pressure in the tubing shuts down the switch. So what goes wrong? Sediment builds up in the tubing OR a hole gets in the tubing OR vibration simply makes the tubing fall off the switch. Blow out the sediment (use them lungs). Reattach the tubing , pump out the water so that the pressure can build in the tubing once more and retry. The possibility of the switch itself being bad is slim. themobilian_2448.jpg
Jun 14, 2011 | Maytag LAT2600A Top Load Washer
Top (upper rack) of dishwasher does not wash. bottom does mediocre job
Make sure top rack is backed up into water entry in back of diswasher. Also check to make sure holes are not plugged in rotating wash arm. You may have to wash your dishwasher..take out the racks and look to see if they have food gunked up on them, if so wash them off in the sink. Take out the top rack clips and wash the rails inside the tub if they are dirty. You can use a squirt bottle with warm water. Do this after you run a rinse cycle so that dried food gunk is softer. There are alot of places in this machine for food to stick then resurface later. you may try also adding vinegar and baking soda to a rinse cycle and then leaving in it soak before restarting it.
Feb 10, 2011 | KitchenAid Dishwashers
What does LF mean on the washer? When I start my load it pops up as LF and stops washing. What do I need to do or what is wrong?
LF (F30)
LF flashes when the control don't sense any water coming in like it is supposed to do. Things to check:
Hoses connected; water turned wide open.
Is water siphoning out due to having the drain hose too low? (30 inches above the floor)
Pressure hose from tub to control loose, pinched, hole, Sediment in tub? themobilian_1135.jpgthemobilian_1136.jpgBlow that tubing out and re-secure; retry with water OUT of tub so the pressure can properly build in that tubing. themobilian_1137.jpg
Bravos codes and service manual HERE
Jan 29, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
I used the washer after several months of non use. Water flooded the floor! It did drain when I put it on spin.
The water level is controlled by a switch that attaches to a tube coming from the bottom of the tub. If that tube is compromised by a hole or simply fell off the switch then the water pressure won't build in the tube and shut down the switch.a329de6.jpgThe switch above is not exactly like yours. But it has a tubing going to it like that. Blow through the tubing to remove sediment then reattach the tubing securely. Pump out the water and then retry. No parts needed.
Rate it or hate it:1a2b3d0.jpg
Aug 02, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Gcxrpo9odoww GE washer .. On fill up, it over flows onto floor?
Fill switch could be bad, or fill tube could be plugged making water not stop and it keeps filling. The fill tube goes from fill load selector switch to bottom of tub. Remove from top and blow it out. If this doesnt work replace water load size selector switch.
Jan 17, 2010 | GE WBSR3140DW Top Load Washer
GE Top-loader Leaks Water from Vertical Tube Behind Tub on X-Large Loads
it sounds like the basket is not locked when it is agitating, if so the water will climb the wall during the wash cycle and leak out of the overflow (which is the plastic tube you described). if this is the case, it is a transmission brake problem. it can be fixed by a professional, but you might want to look into buying a new machine.
Jun 18, 2008 | GE WHRE5260E Top Load Washer
Kenmore elite calipso was motion
calyso is a low water use machine similar to front loads only enough water enters machine to get clothes soaking wet water is recirculated through tube on back right corner of tub to insure clothes are soaked if pressure switch determines minum water level not reached it will add more
Apr 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
