Question about Kodak ESP 5 Printer
My printer stops in the middle of a print job and displays an error message of 3802. When I tried unplugging it for 5 minutes as directed, it gave me a message that it detected a new printhead and needed to calibrate. (there is no new printhead)
  • phyllisej124 Oct 17, 2010
    Partly because I had no idea how to uninstall my printer, I searched around until I found the Trouble-shooting section of the online manual for my printer. In addition to the usual disconnect directive, they suggested removing and replacing the printhead two times. That seems to have taken care of the problem. Just thought you'd like to know.
  • phyllisej124 Oct 20, 2010
    I actually used a different solution suggested in the printer's Help section. It involved removing and replacing the printhead twice (probably cycling the contact points like in a flashlight battery) After recalibrating, it's been working fine. But thanks for your suggestion.
    President:
  • 3,278 Answers
Hello.
The most common reason for the message is a faulty printhead.
Try replacing.
Hope this helps.
Posted on Oct 17, 2010
  • NinaE Oct 21, 2010
    You are welcome. Thanks for using FixYa.
    President:
  • 4,070 Answers
Hi! The printer may have resetted it's system that's why it shows that there's a new printhead. I strongly suggest that you unplug the machine from power source and so the usb cable. Uninstall the existing printer program then restart the pc. Install a fresh copy of the printer driver and follow the installation process carefully. This can resolve the problem. Hope this helps and thank you for using FixYa!
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
My HP 5500 stops printing jobs on its own. If I hit continue, it keeps printing the same job and not moving on to the next one in line. It also prints all of page one and page two, but I have to pull...
Try unplugging it for 10 minutes to reset it.
also clear out all print jobs on the computer and then try again and let me know what the situation is after following the two directions I gave.
thanks
May 05, 2008 | Office Equipment & Supplies
Error code 0051930 49.bb28 Printer prints old jobs even when it says no jobs stored. I have turn off the printer, unpluged the printer and it is slow or much later or not at all print the job requsted.
A critical firmware error has occurred that caused the processor on the formatter to abort operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations.
In some cases, electrical noise in the cable can corrupt data during transmission to the printer.
Other causes include poor-quality parallel cables, poor-connections, or home-grown programs.
On rare occasions, the formatter is at fault, which is usually indicated by a 79 Service Error.
1. Turn the printer off then on.
2. Press Stop to clear the print job from the printer memory.
3. Turn the printer off then on.
4. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message displays only with a certain software program or print job, contact the software vendor for assistance.
5. If the message persists with different software programs and print jobs, disconnect all of the cables to the printer that connect it to the network or computer.
6. Turn the printer off.
7. Remove all memory DIMMs or third party DIMMs from the printer. (Do not remove the firmware DIMM.)
8. Remove all EIO (JetDirect Cards) devices from the printer.
*Remember to protect from ESD
9. Turn the printer on.
10. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and on again as you install each device.
Apr 26, 2010 | HP LaserJet 4700 Printer
0xc18a1002 error message on HP Photosmart C-7180 Printer
Resetting HP Photosmart C6180 & C7180 "system failure" errors:
(might work on other similar models as well)
1) press * and # at the same time
2) press 1, 2, 3 and “support R0632M” should display
3) press > and “information menu” should display
4) press > and “configuration menu” should display
5) press OK and “hardware failure status” should display
6) press OK “failure status: clear”. Press OK to clear
7) press CANCEL
8) press CANCEL
9) press CANCEL
10) turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
Feb 03, 2010 | HP Photosmart C7180 All-In-One InkJet...
Error 49 4CO2 Service Error on a HP Laser Jet Printer 5500 DTN
This is related to the JetDirect Card and the specific print job attempting to print. If JetDirect is 615 or lower slide out JetDirect card and power cycle printer once it comes up o.k power down and
slide JetDirect card back in once the printer is back up look on the display for processing job which may take 5 minutes but it is the offending job trying to print again as it is still in the print que. If you are quick enough you can hit cancel on the display panel to cancel the corrupt printjob and if you are successful then the other print jobs stacked behind it should start printing away with no problem. Hp blames the 49 error on a plethora of problems though mine are usually related to documents using different versions of Adobe and also PowerPoint printjobs that are excessively large as the print spooler cannot handle them but it is always a corrupt print job and once that is cleared no problem. Occasionaly replacing the JetDirect card is required to solve the issue. With the 620 Jetdirect card no need to remove it just unplug the network cable same procedure as above.
Oct 22, 2009 | HP LaserJet 5500dtn Color Printer
I have had error message 3802 come up many times. I re installed the cartage holder and now black in will not print. What do I do? The printed used to work fine
im getting this same error, i suggest turning to the kodak 5*00 troubleshooting for advise, they use the same print mechanism
it seems that 3802 is related to a blocked or dirty print head... try taking it out and wiping it softly with tissue (dont apply too much pressure, and stroke only along the lines, not across them)
this seemed to do the trick for me.
the 5 series kodaks used to respond well to a 92% ethanol solution being used to clean them, if you need to do that, just make sure its dried off before putting it back in the printer
Jun 30, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printhead Error 3802 I have the Kodak ESP 5 all in one printer. It started printing blank pages a little while ago. Sometimes if I tried to print a couple of times it would eventually come out, so I knew...
3802 Mean Printhead Failuer
All You need to do is turn the printer Off and On
And if the problem still there
Remove the ink cartridges and the printhead
Do it that again for (5x)
Tell this to kodak support
And tell the troubleshooting steps you did.
Mar 22, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printing status frozen and won't delete or print
Have you tried unpluging your printer from the computer as well as unpluging the printer from the electrical? If that doesn't work you should start from scratch... that is remove the printer from the computer memory, delete it, turn off the computer, turn on the computer and go through the installation process as if you just purchased the printer. Barring any mechanical problems as in jams or the such, the printer should return to operational status.
Oct 07, 2008 | HP DeskJet 5150 InkJet Printer
Kodak 5300 first said error 3802 now says print head missing or loose
I got the same Problem as listed above. This is the way how I was able to solve it:
  • Remove the color and black ink cartridges and the printhead. (the 5300 Printhead can be removed by pressing a button on top of the carriage and a slight pull --> for better instructions use this official Kodak PDF)
  • Try to clean the printhead and the carriage with a slighty wet cloth from ink. CAUTION!: better not touch the green electronic chip! Be carefull while cleaning.
  • Reinstall the printhead and the ink cartridges.
  • If the printer detects a 'new' printhead just do a calibration and your are done. If not try to print a test page.
Hope this solves the Problem. Best wishes
May 20, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak ESP 5 Printer Logo
398 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
