Suddenly, my digital inputs don't work. All of the rest of the inputs work but I get no picture or sound with digital 1 or digital 2. I replaced the HDMI cable but that did nothing. Everything was fine yesterday...
    Novelist:
  • 153 Answers
If you havent already unplug the ac cord of the tv for about 5 minutes or so. It surprising how many times this will fix hdmi failures.
Posted on Oct 17, 2010
I tried hooking up my laptop to my 37lh20 tv. I connected the avi to the pc input and an audio cable fro the headset jack on the tv. If I put the tv input on rgb pc I get the picture but no sound and if...
Unless you hook HDMI to HDMI, you won't carry sound across the HDMI cable. If you're using a VGA to HDMI converter, you'll get the picture but no sound.
I have a feeling the headset jack on the TV is an output rather than an input. Most TVs accept HDMI, RCA, or a digital audio input (either coaxial or optical). Unless you have a S/PDIF optical output from your laptop (and you obviously don't have an HDMI output), then your only other choice is likely to get a cable that splits a 1/8" headset type connector into two RCA plugs that you'll plug into an AUDIO IN input on your TV.
Jul 14, 2011 | LG 37LH20 37 in. LCD HDTV
6MTH OLD HOTPOINT PLASMA TV SUDDENLY HAS NO PICTURE NO SOUND
Hiya!
Sounds like it's on the wrong input, maybe it's analog tuner. Have you tried changing it's input?
Feb 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
The buttons assigning DVD, TV, VCR, etc suddenly changed their assignments. DVD was now TV, VCR was now DVD, etc. I don't think it all happened at once either. Now I can't get sound from the...
There are facilities to CHOOSE the digital assignment. I've seen where extended power loss will randomly lose custom settings. Open the manual.
Jul 07, 2011 | Pioneer VSX-D912 Receiver
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Sony KP46WT510 picture goes back and fortto horizontal color bars
The pictures show the result of a bad terminal input board. You can verify this by checking the inputs. Connect devices to the board and try different inputs. You will most likely find this problem on the tuner and component input were your DVI and composite video will be ok. If it is the same on all inputs replace the A board
Jun 24, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
No 5.1 surround when adding a Philips upconvert player to the San
Sounds like you are getting analog signals from your componet cables and a true digital input from your HDMI into your tv.
However that unit is Analog audio input x 1 only.
So i dont think your going to get true digital surround sound.
The problem being
Sanyo =
Inputs: Analog Audio x 1 Outputs: Composite x 1 · S-Video x 1 · Component x 1 · Digital Audio Coaxial x
Feb 03, 2009 | Sanyo DWM-2500 System
No sound or picture
Try 2 things:
1. If you have a cable box with the yellow/white/red outputs, use a compatible cord to run the 3 to another input on your TV (ie input 1 vs cable). and/or
2. Do a Factory reset. Hold the "menu" button on your TV then on your remote hit "menu" then "8" then "select" and go to "factory reset". You may have to unplug the TV as it may freeze on "factory reset". Replug it then try it out.
Hope it works.
Apr 03, 2008 | Hitachi 51F510 51" Rear Projection...
Not Supported Mode
Sound as if the digital board has failed, Samsung p/n# Bp94-00385a
Bill
Apr 02, 2008 | Samsung HLN5065W 50" Rear Projection...
NEW SAMSUNG DIGITAL CAMERA SHUTING OFF SUDDENLY AND MAKING NOISE
If you don’t find a solution you may want to try fixityourself123@gmail.com. He was able to give me some great advice and he has used parts in good condition and at a good price. It worked for me.
Jan 19, 2008 | Samsung Digimax S730 Digital Camera
No Sound ... (main input module) ?
the module itself is 56.00 dollars then the labor to install, its hard to find the seperate components the factory has set things so that you have to buy the whole control module to replace one part or board. try and find that component on e bay or used some where thats your best bet to fix it.
Dec 17, 2007 | Polaroid FLM-3225 32 in. LCD Television
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
