Question about Kenmore HE2 Plus Front Load Washer
My Kenmore front loader washer is not draining how do I fix the it?
  • 11,896 Answers
When a machine won't drain, it is caused by either a plugged drain and/or drain screen, or the pump is jammed or loose or broken.
Posted on Oct 17, 2010
Check drain light keeps coming on how do I fix it
I'm not sure about your specific model, but in a Kenmore HE3 front loader, the lower front panel is removed, and it reveals the screw-on drain cover, which can clog up with debris. Also, on the lower part of the seal for the front loader door, you can pull it back a little to reveal a drain hole. I've found socks covering it before. It is most likely the drain in the lower section hidden by the lower front panel, though.
Bruce
Jun 09, 2014 | Miele W310 Front Load Washer
5d error code kenmore he2plus
Here's a video prem mathew suggested as a solution to your problem from YouTube:
Kenmore He2 washing machine washer drain problem fixed
Apr 26, 2013 | Kenmore Washing Machines
Front loader stuck in final spin - not draining
Very likely the reason your washer isn't draining is because the filter screen on the drain pump is blocked so it cant drain, its a fairly common thing wrong with those type front loaders soi have written this tip covering how to clean that filter, http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 06, 2011 | Kenmore Elite 45986 Front Load Washer
I have an HE2 Plus Front Loader. When it drains,
Sounds like there might be something in the pump that got past the button trap. You will have to remove the pump to check it.
Dec 31, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore washing machine
Whether this is a TOP LOADER, or a FRONT LOADER, the drain pump is located directly below the wash tub in the front of the washer. Accessing either one takes, different procedures, however.
To access the pump on a TOP LOADER, you must remove the exterior washer casing. Follow the steps provided in this link:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
If this is a FRONT LOADER, you must remove the lower toe panel directly below the door. Follow the steps provided in this link:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
The Kenmore Oasis is a different configuration from the two I've mentioned. There are two pumps on the Oasis. One is a drain pump, while the other is a recirc pump. Both are accessible by removing the rear panel of the washer.
If you require further assistance, please post back with a complete model number so I can determine how your washer is configured. I hope you find this information helpful.
Dec 22, 2009 | Kenmore Washing Machines
Kenmore front loader washer model 11042822201 won't drain and spin
As I have not received a response, I'm assuming these hints have taken care of your problem. If you have any more troubles, feel free to drop me a note back.
Jun 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader trouble
If it is shutting off after a few seconds is the washer filling with water. If not you may need a water valve. If it fills with water then stops you may have a bad control and $350.00 is not really to bad for that repair. Besides if he is wrong he is stuck with the part not you. If he is correct then your washer is fixed and $350 is alot better than $1200.00 for a new one, so check that water and good luck to you. Mike
May 07, 2008 | Kenmore 44102 Front Load Washer
First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
Jan 25, 2008 | Washing Machines
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
the drain pump on this unit has a clean out. There is probably debris in the pump. remove the lower front cabinets. There are three screws almost at floor level that hold it in place and open the drain pump it has a handle on the drain pump that you can twist to remove.
Nov 04, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
50 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
