Question about Motorola Mobility RAZR V3
Blank Screen My screen went out, it's not the screen that's damaged but i'm pretty sure the wiring is loose because i threw it to keep it from getting wet when i was being thrown into a pool ... it worked for the day and then that night the screen went blank and wouldn't come back... no external damage to the screen or phone is very prevalent. I read your post which seemed very helpful on this topic, however, i do not know how to go about opening the top of the phone where the screen is at and how to go about removing the cover, etc. could you describe this in more detail if possible because i am thoroughly confused and i know i can fix it, i just dont want to go pulling things off that i don't know how to put back (especially if i'm not sure that's what i should be taking off) if you could help, please email me a response to cassgunderson@gmail.com as soon as possible. thanks! cass
  • 94 Answers
With t6 screw driver u can open its lcd portion its very easy. just try it and press the jack which comes from keypad. i know u can do it. reply me
Posted on Jun 05, 2008
Partial Display Screen Damage
The screen will keep malfunctioning since it fell and its display is half top the screen. is the phone slide? if it is, it is the flex on the phone screen that will need to be change. but if it did not solve the problem, then,
I advice you get a brand new screen for replacement and when going to get the screen, please go with the phone so that you can get the exact screen and a working screen.
Regards
Apr 25, 2010 | Samsung Star GT-S5233 Cell Phone
The screen keeps cutting out at certain angles when I open it up. It now doesn't work at 90 degrees as the screen goes white/grey when it is opened. I think this problem has been caused by heat damage as...
This problem could be down to a loose connection or a dry joint on one of the componants inside the monitor, around where the crack is, check all the cables if there are any or componants, get a magnifying class if it helps to spot a loose connection somewhere, iam pretty sure you will find something out of place. good luck post back your findings. cheers.
Jan 28, 2010 | Computers & Internet
BLANK SCREEN ALL BLACK
check he back and try to push it in more
Dec 20, 2009 | Sony Playstation 3 (PS3) Console
Both screens are blank
try pushing down on the screens. lightly but firm. i dropped mine once and i had to push my touch screen back in place. maybe a connector got knocked loose. if that doesnt work try getting a replacement screen and swap it out yourself. you can find the screen pretty cheap online as well as the screw driver you will need to do the work
Jun 30, 2009 | Nintendo DS Lite Console
Blank screen LG KE970
Ok The Software Your Phone Is Running Is Very Well Out-Dated You Can Fix This By Seeking Out A Phone Technician Prices Vary depending On Where You Go, Another Reason May Be Faulty Wireing Inwhich You'll Have To Fix If You Know A Bit About Phones Motherboards Ect. I Recommend Getting 3 Quotes From 3 Different Stores Fully Explaining Your Problem To Them And Asking What Can Be Done. Hope This Helps
May 11, 2009 | LG Shine KE970 Cellular Phone
Olympus 1050 - lcd screen blank, gasket was loose.
It is possible that since water did get into somehow that it did some internal damage to the camera. I recommend that you call Olympus Customer Service and discuss the repair process with them. Their telephone number is 800-622-6372 option 2 and then option 3
Dec 17, 2008 | Olympus Stylus / mju 1050 SW Digital...
Toshiba screen goes blank when it is opened too far
Sounds like a problem with the ribbon for the screen being either having a loose connection or getting nipped. Pretty common on laptops because the ribbon runs along by the hinges on the base and then up to the screen.
Hopefully you will be able to access the ribbon on your model by removing the plastic bezel which lies just above the keyboard. The ribbons I have seen are about 1/2 inch wide and as I said connect on the base and the screen. The connection just pushes in. If its loose at the connection on the base then obviously push the connection fully home. If it's getting nipped then reseat it so that it does not get caught. ***NOTE*** a problem could arise if the ribbon has actually been damaged from being nipped - opening the laptop could cause it more damage and then you could lose the screen until you replace with a new ribbon. These can normally be purchased on places like Ebay and don't cost an arm and a leg.
If this helps, I'd appreciate feedback so other people can use this as a solution. Thanks
Nov 22, 2008 | Toshiba Satellite M65-S9092 Notebook
Helio Ocean..blank screen
I managed to fix mine! It takes some doing and is probably not for the faint hearted. You have to disassemble the Ocean from the battery side, removing the qwerty keyboard, to gain access to the slider assembly.
Disassemble the slider (pay attention to the spring!) and clean all contacts and make sure all of the flex cables are seated completely. Mine was working OK the qwerty way, but was blank and/or garbled the long way. Now it works great!
Sep 09, 2008 | Helio Ocean Cellular Phone
Screen problems with 540
Sounds like the shock from being dropped may have caused some internal connections to the screen to become loose causing the stripes or blank screen. It is also possible something might have been damaged. It sounds more like a loose connection and not any damage, but I don't know for sure. My suggestion would be to get it looked at by a professional.
Sep 12, 2005 | HP Jornada 540 Pocket PC
Motorola Mobility RAZR V3 Logo
61 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
