Question about HP Pavilion dv7-1132nr Notebook PC
My HP pavillion had pepsi spilt on keyboard and now has 2 keys atleast that don't work. I have a spare PC and have cleaned underneath the keys, but the problem appears below that into the board underneath. I can clean the contacts if I have the schematics or even replace the board beneith the keypad but need to know more information before beginning to take apart my laptop. I am only familiar with towers so am in unfamiliar territory-- any help available? such as proper schematics for this problem of mine?
  • 31 Answers
Chances are the traces are burnt or there's still liquid in there. How long ago did this happen? You wont be able to repair the traces and a schematic will not help you here. Ebay will be your friend here. Purchase a replacement keyboard for your laptop. They are fairly easy to replace.
Usually a screw or two on the underside of your unit and then the top cover above the keyboard pops off from right to left. Then there will be a few screws to take it out. The keyboard has a ribbon. Care must be taken when removing it and installing the new keyboard.
keyboards for this model I have seen for as cheap as $45 US dollars + S&H out there on the Net.
In the meantime plug in a USB keyboard into your laptop and use that for all KEYS. :-)
And stop driking Pepsi over the laptop. :-)
Posted on Oct 17, 2010
  • 340 Answers
There is one other options before you decide to take apart your laptop.. if you have an extra keyboard that either hooks up to a usb port, or even a regular ps/2 mouse and you can get a usb adapter for this which is just called a ps2 to usb adapter, they are about $2. You can hook this up to your laptop and use this in the mean time. Just thought I would give a suggestion before you decided to take apart your laptop, especially if you are not too familiar with it
My `HP PAVILLION DM3-3110US NOTEBOOK PC' my Keyboard b, 5, n, and 6 is not working this is how it types 'n6 n6 b5 b5' can someone help!
I understand your problem, while there are many reasons this can happen, it is best to recommend the simpliest remedy for your problem
Since your laptop has USB ports, I would purchase a low cost keyboard and plu it into a spare USB and you should be OK.
You can try to see if there is anything under or around the bad keys, or get a can of air blower to see if it will clean out, chances are it might not help as you have mutible keys that are not working.
With a little assistance, you could possibly replace the keyboard.
I have posted a link to the HP parts store, as your laptop appears fairly new.
Please look on the bottom of your laptop for information to fill at HP to find the keyboard you need.
Good Luck
http://h20141.www2.hp.com/Hpparts/Default.aspx?mscssid=D2F400DA4EDC4E6CA8A0A0EC1FB54ADD
Aug 27, 2011 | Computers & Internet
Tip
HOw to Clean your keyobard effectively
Keyboard cleaningIf you're trying to clean a laptop keyboard see document CH000780 for additional help and information. All of the below information applies to standard desktop computer keyboards.
Why? Dirt, dust and hair can build up causing the keyboard to not function properly.
Procedure: Many people clean the keyboard by turning it upside down and shaking. A more effective method is to use compressed air. Compressed air is pressurized air contained in a can with a very long nozzle. Simply aim the air between the keys and blow away all of the dust and debris that has gathered there. A vacuum cleaner can also be used, but make sure the keyboard doesn't have loose "pop off" keys that could possibly be sucked up by the vacuum.
Why? If the keyboard has anything spilt into it (ie: pop, cola, Pepsi, Coke, beer, wine, coffee, milk, etc.), not taking the proper steps can cause the keyboard to be destroyed.
Procedure: Below are a few recommendations to help prevent a keyboard from becoming bad once a substance has been spilt within it.
If anything is spilt onto the keyboard turn the computer off immediately. Once the computer is turned off, quickly flip the keyboard over helping to prevent the substance from penetrating circuits. While the keyboard is upside down, shake the keyboard over a surface you do not mind getting wet or that can be cleaned up later. While still upside down, use a cloth to help clean out what can be reached. After you you have cleaned the keyboard to the best of your ability leave the keyboard upside down for at least one night allowing it to dry.
If a keyboard does not work after trying it again later it is recommended that it be replaced. If the keyboard works but some of the keys are sticky or cannot be pressed in you can attempt to do additional cleaning in attempt to resolve the issue. Unfortunately many times when any sticky substance such as a non-diet pop is spilt directly onto the keyboard it's usually a loss unless you plan on spending dozens of hours attempting to clean each key.
Why? A keyboard that is used by multiple people, such as students or different employees, may need to be disinfected to help the spread of germs.
Procedure: Turn off the computer. Spray a disinfectant onto a cloth or damp a cloth with alcohol and rub each of the keys on the keyboard. As mentioned in our general cleaning tips, never spray any type of liquid onto the keyboard.
Additional Information: Keyboard Page
on Feb 01, 2010 | Computers & Internet
My keyboard is working fine but my enter key or return key as they say and shift key below the enter key isnt working.
If there is a mechanical fault there is not much you can do. If other keys are working then there definitely is a mechanical fault. Some crafty expert has to remove those keys and find out what the problem is. There can be broken brackets underneath or there might be some drops of liquid food congealed underneath the keys. Only the person who will open the keys will find out first.
Jul 22, 2011 | HP Mini 1000 Netbook
Have a HP Pavillion 3163cl Entertainment Laptop and the Space Bar asks like someone is pressing down on it at all times. Like a stuck key and makes the noise when turning it on. The Laptop belongs to my...
To clean your laptop's keyboard you have to look under your laptop, you can see like keyboard icons with some scews, so, open them, they will let yout to remove your keyboard.
So now your can remove just your keyboard slowly for some connectors on the motherboard then clean it with a tooth brush.
You can only clean your keyboard with a toothbrush without rmoving it,
Try to remove the space bar key and clean under it.
Try to hard press the space bar for about 5 times, it can release the pusher under the key.
it some liquid was spilt on it you have to remove the keyboard and clean the plastic under ther keyboard.
Good luck
Jan 20, 2011 | Computers & Internet
I have a gateway keyboard ku-0833 and its working fine but I spilt a little coffee on it and a few of the keys are stiff to push. Is there a way I can clean it, tried using cotton swabs around the keys but...
You can pry out the keys using a butter knife and use rubbing alcohol to clean the underneath.
if the coffee got into the connectors you might be out of luck.
**THE FOLLOWING IS NOT RECOMMENDED**
When i spilt mt dew on my keyboard i took out the battery let it decharge for 5 minutes. I put it in a pan and poured rubbing alcohol on it and let it sit for 5 min. While it was sitting i swished the alcohol around a little bit so it could flow. took it out and let it dry for about 1-2 hours and it worked perfectly. this is orta used as a last resort
Nov 24, 2010 | Gateway 2520915 Keyboard
Spillage!!
Only thing you can really do is take apart the keyboard and clean it out with rubbing alcohol short of that you need a new keyboard
May 28, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
My keys on my HP G60-230US are not working
bota esa pendejada a la basura o ask to hp for repair, is a keyboard fail they have to change your pc uner waranty
Mar 16, 2009 | HP D8597A Keyboard
Keys are sticking the keyboard. Can i clean underneath the keys?
Depending upon how sticky the keys are, it might be easier to buy a cheap replacement keyboard.  Trust me, it takes a whole lot of patience and a steady hand to take apart the keyboard key by key and then put it back together.
Mar 09, 2009 | Toshiba Computers & Internet
Viewsonic Tablet PC keyboard issue.
Try reseating the cable that connects the keyboard first.
If that doesnt help there may be liquid around the connector and it needs to be cleaned off to keep the circuit from shorting out. You will need to find someone with the appropriate chemicals and may have to take the laptop further apart to clean it all up.
This is why when anyone gets a liquid spill i recommend getting it torn down right away and cleaned up, as it can damage things you cant even see. If the liquid has been in there too long it may not be repairable.
Dec 21, 2007 | HP Pavilion dv4000 Notebook
HP Pavilion dv7-1132nr Notebook PC Logo
82 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
