I was just fixing one of the my main speakers because the sound wires weren't connected properly and then everything was fine... but then all of a sudden the system turned off. Now whenever I try to turn on the system, the system makes a humming sound like a quiet generator and on the system screen F61 shows up and the system then turns off on its own. I unplugged the system several times however, the same thing repeats itself. What does this mean? pls help me because I do love this system and I'm sure this can be fixed with a little assistance... thx Alif
  • 186 Answers
Open it up and see if it has glass fuses.one might be blown
Posted on Oct 17, 2010
Arcam avr-250 shuts off?
New problem?
Did you move it recently? Sometimes the speaker wires are stripped too long and short out against each other in the back
Disconnect EVERYTHING from the unit but please take great care to document how everything is connected so you can connect it again the same way.
IF the unit powers on fine with everything dis-connected, I can assume that you have a connections problem with the speaker wires being the most likely culprit.
Make sure your speaker wires are not stripped too long where bare copper is touching other terminals OR make sure the speaker wire is pushed cleanly into the speaker connections without stray wires to cause a short.
Also make sure you have the speaker wires connected to the proper terminals and are not mis-wired into the wrong terminals.
IF it still shuts down after a few seconds with nothing connected then there is an internal problem that will need to be repaired.
Good luck.
May 28, 2014 | Audio Players & Recorders
Speakers, no sound
Since they were working, check the basics first.
  1. Check the speakers on another device. Mp3 player will work fine.
  2. check the sound card on your computer (use a set of headphones or another speaker set).
  3. If you find they weren't plugged in, powered on, etc. resolve that. Usually the power plugs are black, and only fit in one spot. The audio cable to plug into the computer is similar to a headphones jack (3.5mm). On most computers the audio output (speakers) port is colored green.
  4. If none of these get you fixed, go into the control panel and click the sounds icon. From there you can view your volume levels (is the sound muted?), view your playback device (it might have a hardware problem, or be disabled), and test the settings.
  5. If you are still stuck after this please also post your version of windows, and the make/model of your computer. If you know it, the type of audio device you are using would also be helpful.
Thanks for asking, and Good Luck!
Dec 18, 2011 | JBL CREATURE II Computer Speakers
Main 5 1/4 driver cuts in and out, and distorted sound. what is the cheapest and the best way to fix this problem?.
probably the the wire connecting the cone and terminals at speaker are short.hold them with you fingers so that they cant move up and down with bass.if working fine then get them soldered.
Aug 23, 2010 | Mission 783 Main / Stereo Speaker
Kenwood kdc-x769.everything works on the deck just fine other than no sound at all-not even static. did a full and proper install into vehicle and cant get anything to come through the speakers-any help or...
you may want to check and make sure none of the speaker wires or speaker terminals are shorting out. it just takes one shorted speaker or speaker wire to shut off the entire audio.
Jul 13, 2010 | Kenwood eXcelon KDC-X769 CD Player
My computer fell down from my mattress, and the sound is breaking now, what can I do ? get a new computer, current one is a two year old HP dv5120 is there any way I can fix te sound on this one....
IF EVERYTHING IS FINE WITH THE SYSTEM, IT MIGHT HAD DAMAGED THE AUDIO LUG WHICH IS CONNECTED TO THE SPEAKERS, IF POSSIBLE FOR YOY TO OPEN AND CHECK..GIVE A TRY...BETTER TO FIX RATHER THEN BUYING NEW ONE...
Oct 14, 2009 | HP Pavilion dv5120us Notebook
I dont receive any sound on my speakers
check if all the wires are connected properly.. then check if your device is giving sound with headphones. if yes then speakers have some problem and need to get repaired.. there may be a problem with the sound driver, if everything else is fine.. install the sound driver.
Jul 11, 2009 | Intel D102GGC2 Motherboard
No sound from speakers. Everything else OK.
If headphones work then so does the amplifier. When did this problem start? From what I can find it almost sounds like it thinks you have headphones plugged in, which would disable the speakers.
Apr 24, 2009 | Audio Players & Recorders
Simply no sound from PC
Check if you have plugged in the stereo pin to the right port on the PC.
Open sound control (in control panel) and check if the both speaker(main volume) and the wave volume sliders are not set to the lowest.
Apr 02, 2009 | Computers & Internet
No sound on coming out of speakers and theres no wires touching everything looks like it works fine
Make sure you didn't accidentally hit the mute button.
You should always test sound with a CD, testing sound via AM/FM will produce interference and almost no sound when between stations, also don't to forget to connect the antenna lead.
Check that the speakers are wired correctly.
Check that the sound controls are adjusted properly, i.e. Balance, Fade etc.
Good luck...
Feb 24, 2009 | JVC KD-G210 CD Player
 Grubhead
Grubhead
