Question about Dell Inspiron 6000 Notebook
I HAVE A DELL INSPIRON 6000 SERVICE TAG HN98T61. THE AC POWER SUPPLY WELL NOT CHARGE THE BATTERY NOR WILL IT POWER THE LAP TOP. THE CHARGE LITE DOES NOT COME ON. I AM SURE OF THE AC POWER SUPPLY IS OK. IF THERE IS SOMETHING BAD ON THE MOTHER BOARD CAN YOU CLUE ME IN WHAT COMPONENT AND WERE IT IS ON THE MOTHER BOARD.
    Brigadier General:
  • 10,406 Answers
Take a multimeter, and measure the VOLTAGE and AMPERAGE being emitted by the AC power-supply. If "none", or much less than the ratings printed on the label, then it's time to replace the power-supply.
Otherwise, it most-likely is the connector where the AC adapter is plugged-in to the motherboard that is not transmitting, i.e., electrically-disconnected from the motherboard.
Maybe, resoldering the leads from the socket to the motherboard will fix the problem. Or, take the laptop to a qualified technician, for proper repair.
Posted on Oct 17, 2010
  • badbadbud Oct 19, 2010
    did that, its not the ac power supply and its not the jack. thank for you reply. anything else?
Com quitar password del bios dell inspiron 6000 service tag F4F8H91-595B
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-6000-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
May 25, 2011 | Dell Inspiron 6000 Notebook
Tip
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
dell-inspiron-6000-laptop-battery.jpg?w=200
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 | Computers & Internet
Connector not allowing charger to charge battery, loose in back of lap top
This will require either the replacement of the power connection by a competent board repair service or replacement of the motherboard
Example: (Not necessarily a recommendation)
http://comprehensivecomputing.net/79_dollar_power_jack_repair.htm
Motherboard
http://shop.ebay.com/i.html?_nkw=Inspiron+6000+motherboard&_sacat=0&_odkw=Inspiron+6000+power+jack&_osacat=0&_trksid=p3286.c0.m270.l1313
Sep 27, 2010 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 won't charge
Since you have already replaced the battery and the laptop works with the AC charger, then probably the charge circuit in the system board (mother board) is bad. I have rarely seen an AC charger that will power the laptop but not charge the battery. 99% of the time, if it is not the battery, it is the system board.
May 05, 2010 | Dell Inspiron 6000 Notebook
New aftermarket Inspiron 6000 battery will not power the Laptop
I would say that the power management portion of the system board is probably faulty if it behaves the same with both the factory battery and the aftermarket.
Many systems have the charge controller and battery interface on a separate board but unfortunately on the Inspiron 6000 it's integrated.
FYI, Here's a copy of the service manual for that system: http://support.dell.com/support/edocs/systems/ins6000/en/sm/index.htm
Jan 21, 2010 | Dell Inspiron 6000 Notebook
My Dell Inspiron 6000 works fine on AC, but will not charge
As a first step, Try reseating the battery on the laptop and see if the problem is resolved.
If not working, then try flashing the BIOS on the laptop.
You can find the latest BIOS for your system in the support.dell.com website.
1. GO to support.dell.com
2. Click on "Drivers & Downloads"
3. Either select your System model or enter your the service tag of the computer.
4. Under the "BIOS" section., you will find an option to download the BIOS.
5. Save it to your system., and just double click it, to install.
-> Make sure that the system is not turned off while Updating the BIOS...
Have a nice day
Oct 07, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Intermittent power loss to Dell Inspiron 6000
you need to replace the mother voard along with the power supply.. sorry:( ~~hardware issue~~
Apr 10, 2009 | Dell Inspiron 6000 Notebook
Labtop not charging
Try removing the battery and see if the laptop powers on. If it still doesn’t power on then either the motherboard is defective or the AC adaptor may have a broken wire in the cable.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 03, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
