Question about Motorola Mobility Backflip Smartphone
My 2GB micro SD card have been locked. I can't add/remove anything. How can I unlock it?
  • 410 Answers
Go to a mobile Repairing Shop end give that there and ask for unlocking it...all your data will be erased but if you don't want lose your data...than make a copy of your data on the PC using mobile usb. then they will Unlock your card and it will be empty...so add your copied data to it..
Posted on Oct 17, 2010
Unlock password
HI, did you actually add a password to the memory card. Or did you have a adapter for the micro sd card to fit into when using in card readers etc a sd slot on the device you are using. There is sometimes a lock on the side of the adapter, check that you haven't locked the card and simply remove the adapter from the pc, and switch to unlock position. other than this you can download a some free software called card unlocker online. Hope this helps.
Jan 23, 2014 | SanDisk 2GB microSD Memory Card
How do i shut off write protection
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 16, 2011 | SanDisk 2GB microSD Memory Card
My micro sd card is locked how to unlock
Aug 12, 2011 | SanDisk 2GB microSD Memory Card
When i try to format my micro sd card system shows remove write protect how can i format it
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
My sandix 2gb microSD mameory card is write protected how will i remove it?
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 29, 2010 | SanDisk 2GB microSD Memory Card
I have my 2GB MICRO SD MEMORY CARD it automaticaly got locked .Now i dont know the password how to open it ? I am using Nokia C3
Here is a tip that I wrote about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory card locked message then check this out.
How to Unlock SD Card
heatman101
Oct 12, 2010 | SanDisk 2GB microSD Memory Card
My microsd 2gb memory card show write protected.plz help me
You will need to use a regular SD Card Adapter for the micro sd card. The micro sd card itself does not have a write protected switch, but a regular SD card adapter will, and that does affect the microsd card. You just need to put it in an adapter, flip the switch to make sure it knows it is "locked" - so switch it to locked first, then switch it to unlocked. From there you should be able to write to the card. If you can not then it is possible the micro-sd card is having physical problems and may need to be replaced. Here is a little diagram showing how to unlock the card. Before you go though please make sure to rate my answer 4 thumbs up, it is extremely important to me for you to do so. I would be forever grateful!
Here's the link:
http://www.instructables.com/id/Remove-the-write-protection-on-a-Micro-SD./#step1
Thanks
Tim
Oct 12, 2010 | PNY 2GB microSD Memory Card
How to remove write protection from micro sd card
on the adapter that comes with the micro sd card, there is a lock switch on the side of it for write protection. just unlock and youre good to go.
Jul 05, 2010 | Kingston 2GB Secure Digital Memory Card
PROTECTED CARD
Most SD memory cards have a small slide switch on the edge off the card. This switch is used to write ptotect the data on the SD card - you can lock or unlock the SD card be sliding this switch.
Jun 18, 2010 | SanDisk 2GB microSD Memory Card
My Micro SD Card No.- Kingston 2GB micro SD Card
My Kingston Micro sd-c02G is Locked i want unlock password
Jan 04, 2010 | Kingston 2GB Secure Digital Memory Card
Motorola Mobility Backflip Smartphone Logo
190 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
