Question about Kenmore HE2 Plus Front Load Washer
Whats the f28 error. Heard something about a filter...?
  • Kenmore Master
  • 8,220 Answers
Aha! F28 Com error between MCU and CCU (central control unit) Broken wire, very interesting. What you should do is look for a bad connection in the harness. More here
Posted on Oct 17, 2010
  • Dan Webster
    Dan Webster Oct 17, 2010
    The filter thingy:
I have an F28 error what is wrong
As far as I know F28 error code means - SERIAL COMMUNICATIONS ERROR/MOTOR CONTROL UNIT ERROR. Caused by either a communications problem between the Central Control Unit and Motor Control Unit, or Motor Control Unit internal failure.
Jan 12, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wfw9200sq02 f28 error code
What the F28 error code means is "serial communaction error" to put that in simple terms it says the main control board isn't talking to the motor control board. What would need to checked when the F28 code is displayed is for good tight wire connection on all the wiring harnesses between the main and motor control boards, if all the wiring plugs fit tight onto both control board while i hardly advise this and belive in the you can do it byself spirit it advise, ya call for service so the operation of both control boards can be checked to see which on has failed.
GENE
Oct 06, 2011 | Kenmore Elite 45986 Front Load Washer
It gives a F28 code. What is that?
F28 is a motor controller error... Try unplugging the machine for a minute or two, then starting it again. If no good, you can remove the access cover and check the connections to the motor... BE SURE TO UNPLUG FROM WALL FIRST...
Peace,
Mar 30, 2010 | Kenmore Elite 45986 Front Load Washer
What does f28 error mean
Your camera does not support the aperture range, maybe.
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35 on my washer
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
5E Washer - Won't Fill / F28 Error
check if hoses are reverse when installed
May 12, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
479 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
