Unable to get the auto feature to work - Heating & Cooling
    Problem Solver:
  • 8 Answers
THIS CUOLD BE A BAD THERMOSTAT. IF THE FURNACE OR A/C COMES ON WHEN IT IS IN FAN ONLY MODE THEN YOUR THERMOSTAT IS BAD. IF THE T-STAT IS PROGRAMABLE LOOK AT YOUR SET UP MANUAL AND MAKE SURE IT IS PROGRAMED CORRECTLY!!! GOOD LUCK
Posted on Oct 17, 2010
Auto Down window feature stopped working. Any ideas?
Try calibrating first,window up & hold switch for 3-4 seconds window down hold 3-4 seconds then back up & hold 3-4 seconds,check for the auto down to work if not then most likely the master switch is needed.
Oct 10, 2015 | Chrysler PT Cruiser Cars & Trucks
I have a A1221 FCC made in china the pictures have the feature were you move the cell phone side ways and the pictures does as well. but when I txt and try to do the same thing to the keypad it does not...
You don't have to bother yourself unnecessarily,your phone is in a good working condition,but unfortunately the feature in question called 'auto-rotate' does not apply to the text message keypad hence its unable to carry out the function.
Although the feature is present in the calculator,pictures and videos but absent in the text messaging.
Thanks for using fixya!
Dec 09, 2010 | Cell Phones
Cant install my hp deskjet d1469 printer because i lost the disc
I am unable to find your exact model number at hp, so I suggest that you take this link to hp, and select auto detect feature. It will find your printer and provide drivers at no cost.
http://www.hp.com/#Support
Nov 17, 2010 | HP DeskJet D1460 InkJet Printer
When i restart i get the error unable to install windows
if it tells you that it is unable to locate the hdd..when you install..and it works until the first restart ...than you should go to bios and disable the ACHI feature in the drives area..(Just point to the HDD in use in the bios and a function named ACHI will be on top) ..just disable it ..and save with F10 ..and after that will work ..
The issue is that that function require some Raid driver for the Sata ..and if you have no way to install it when it says to install the 3rd party ..the installation can not detect the HDD but when you disable that the HDD is seen auto with the raid driver from windows..
Sep 29, 2010 | Acer Aspire One PC Notebook
Screen out of adjustment
steamjet1,
Try to fix it by using the convergence adjustment. Use the manual method to set it if the auto feature fails. If you are unable to focus the TV using its convergence adjustment it's time to call the TV repair guy. Figure about $300.00 USD for your model.
-Chris
Aug 23, 2010 | RCA R52WH73 Projection Television
Box on the wall. Push buttons
mode will be heat, cool, or automatic. cool will show a snow flake flashing. Heat will show a flame and auto will switch from heat or cool by itself. Usually the auto feature does not work well as one is unable to set the heat and air where they are comfortable on both
Jul 27, 2010 | Carrier 38CKC036 Air Conditioner
FRONTECH TV TUNER MODL JIL-0606 CODE 10 DOESNOT START
How to configure Remote control in my TV tuner card Model No. JIL - 0606
Jun 16, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Timer does not work in auto mode but does work in timed mode
Check the venting for your dryer. Most "auto dry" features are controlled by a thermostat that is in line with the timer motor. If you have a gas dryer especially, a clogged or obstructed vent will stall the auto dry feature. If you can provide the complete model number, I can provide more insight.
Dec 11, 2008 | Dryers
Unable to get my Intellifax 775 to receive any fax's
Things to check: Do you have a live phone line? Are you using a dedicated fax line? You can check your fax line by using the feature hook call. Not all machine have them. Or use the hand set. If you have a live phone line now check this. Is you fax set to auto answer? If it is not you need to either find how to set it on the diplay or refer to your owners manual. If this does not work after you have done this then you possibly have a bad modem.
Mar 17, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
