I have a 15.6 toshiba laptop and the hdmi doesn't fit to hook up to the tv. is there is there mini ones you can get.
    Brigadier General:
  • 10,406 Answers
Take your laptop to the local "big-box" electronics store, and they will sell you a cable that, at one end, fits the HDMI socket on your laptop, and at the other end, fits the HDMI connector on your TV.
Posted on Oct 17, 2010
I have a toshiba laptop a205 I have the usb adapter to hdmi cable hooked up to the tv I cant get picture or sound
First, you need to check the input setting on the TV (change it to HDMI and which HDMI because some TV have more than one HDMI input).
Second, please check the Output on the laptop (cycle it; laptop only, external monitor only, both of the screens).
Mar 04, 2014 | Computers & Internet
How do i hook my Samsung Notebook Series 9 up to a tv?
you need a hdmi mini to hdmi normal cable.or if you can find one an hdmi mini to component.. and that will work on most tv's im pretty sure you can pick it up in the tech department of a local supermarket like walmart.
Aug 18, 2013 | Computers & Internet
How to connect a toshiba satellite L675 to a tv using HDMI cable
If you TV has HDMI connections. All you need is a HDMI cable. Hook the HDMI cable into the laptop and into the TV. Turn the TV on and go to that HDMI connection on the TV. It will show everything on the laptop on the TV. Videos, Documents, and anything else.
Jan 18, 2013 | Toshiba Satellite L675-S7044 Notebook
Toshiba x205-59349 hdmi doesn't register on the tv
If you hooked up with set and or a box on that may be the issue--HDMI does not like connections being made with units on.
disconnect power from set and or box if used for a while and then with HDMI reconnected power up the set and or box.
Dec 03, 2012 | Toshiba Televison & Video
How to connect tv to laptop
you would need a HDMI cable I purchased a 25 foot cable at amazon.com for $20 they are about 85 at walmart for a 15 foot cable of course you nee a hdmi output on your laptop and a hdmi input on your tv they should have them if they are fairly new. hook up cable, select correct source on tv, mine is hdmi 4 .go to your laptop right click on background select properties from menuset up tv like it is a second monitor for your laptop. enjoy
Jan 12, 2012 | Sharp Computers & Internet
How do you use PS3 and DVD player with the Toshiba 32Dtu2 LCD TV?
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Hope this helps!
Sep 19, 2011 | Toshiba 26HF84 26" TV
I want to know exactly what cable to i need to hook my acer aspire one to my plasma tv that has RCA and hdmi hook up
First identify what port you have on the computer. Type A,C or D http://discountlowvoltage.blogspot.com/2010/07/hdmi-mini-vs-hdmi-micro.html (what they look like)
If... A - Buy a full sized HDMI cable C - Buy a mini to HDMI cable D- Buy a micro to HDMI cable
DO NOT BUY CABLES AT RETAIL STORES, buy online www.monoprice.com
WHY? 15 ft HDMI at bestbuy is about $60 at monorpice.com they are about $5... http://www.monoprice.com/home/index.asp
Comment if you need further assistance
Aug 17, 2011 | Acer Computers & Internet
If our Toshiba Satellite Pro 300 laptop does not have a HDMI output, is there a way we can we still hook up our laptop with our TV?
Yes. The best option would depend on what TV you have. The HDMI inputs on most consumer displays won't accept PC resolutions. Assuming you want to take the VGA output of your PC, and that it doesn't have a Display Port or DVI output, and without knowing the model of your TV, the safest recommendation would be to use a product specifically designed to cross-convert VGA to HDMI formatted for consumer displays (1080p, 720p, 1080i), such as this one.
http://www.atlona.com/Atlona-VGA-to-HDMI-Scaler-Converter-USB-Powered.html
Jun 03, 2011 | Toshiba Satellite Pro L300 Notebook
Can I connect my Toshiba NB 205 to my TV to watch etflix movies? the netbook has a VGA out, and the TV has S-cable and HDMI inputs. Thanks!
Interfaces 1 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45 , 1 x Microphone - Input - Mini-phone 3.5 mm , 1 x Headphones - Output - Mini-phone stereo 3.5 mm , 3 x Hi-Speed USB - 4 pin USB Type A
The above interfaces are in your laptop. There is no S-cable or HDMI interface.
If your TV have VGA port you can connect your TV to the VGA port in laptop. This will alow you to convert the TV as monitor.
May 31, 2010 | Toshiba Computers & Internet
Computers & Internet Logo
David Payne
David Payne
