Question about Dirt Devil Reaction Twin Cyclone Upright Vacuum
My dirty devil dual was clogged and after i unclogged it it worked but then it turned off and does not want to turn back on, what could be the problem?
4 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: I have a Dirt Devil
Some of the Dirt Devils have a reset button on the back, near the bottom. But if the it is getting hot on the bottom, that may mean the motor is trying to run but can't. Maybe something has jammed it. You would have to disasemble it to find out.
Posted on Mar 06, 2008
ukvacfan
  • 328 Answers
SOURCE: Dirt Devil Reaction Dual Cyclonic- M110000, "cyclones" not spinni
If the filters have been washed and installed back in instantly there wont be any suction. Check the top filters have been cleaned thoroughly and also check inspection tubes/hose and dust channels to check for a clog. Also check the sole plate / bottom of where the beater bar as there may be a clog somewhere.
Posted on Jan 23, 2009
  • 8 Answers
SOURCE: no clogs, work fine, but makes a very loud wailing sound? what could it be?
My Dirt devil Reaction does the same thing. So I took apart the motor and it was crammed w/ dirt then I decided to clean it out. next time I vacuumed my house it was a lot quieter. The guy from Jones sew and vac said baggless vacuum filters most of the time fail and let dirt get in the motor and start to scream. I read a lot of things saying Dirt devil Reaction is the most common vacuum to get dirt in the motor and start to wail then get worse & worse and get to the point where they start to almost scream. P.S if you let it scream for along time of use it will give the motor permanent damage and you will smell electrical burning, if that happens it will be too late so you will half to buy a new machine. To get to the motor you can take the dust contaner off and take the black filter then use your down stairs vacuum and get a small attachament and stick it in and vacuum it out,if not have two vacuums borrow one. If that doesn't clean it out you will need to take all the plastic appart and realy get to the motor good. If my advice dosn't help it is ok to still use it, it will just be loud until the motor of it is totally fried. This should work it worked on my Dirt devil Reaction. I'm sorry if it doesn't work out. :D
Posted on Jun 12, 2009
I have plugged in my dirt devil and it wont turn on. other things are plugged into the same plug in and they are working. is there a reset button on the vacuum?
Hello! The Easy Lite does not have a reset button. It does have a thermal protector that will automatically shut the vacuum down if it is overheated. This is usually caused by either a clog or a dirty filter or a combination of the two. Try these trouble shooting steps below.
1. Remove the hose completely from the vacuum from both ends.
2. Use a broom stick or something similar to gently loosen and remove any clogs from the hose.
3. Remove the dirt cup. Remove the red air director by turning 1/4 turn counter clockwise. Remove any hair or debris from the air director.
4. Remove the filter from vacuum base. Hold filter under running water to rinse. Allow 24 hours to air dry.
When the thermal protector is activated the vacuum must cool down before it will power back on. This can take up to an hour. Hope this helps! If you still have questions feel free to reach out to us here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
Jun 03, 2014 | Dirt Devil Easy Lite Quick Vacuum
Vacuum is clogged
Without specifics of Model, I can't tell you how. There are no clog ports in Dirt Devil vacuums. Usually a hose has to be removed to unclog.
Apr 05, 2014 | Dirt Devil 12 Amp HEPA Filter Vacuum...
I have cleaned the canister, the filter, everything....and yet the dual blades won't turn and there is barely any suction. HELP?
the suction part must be a clog in between the suction port into the unit check that and if they dont turn maybe belt broke or something is stuck
Feb 15, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
I have a Dirt Devil M130000 I Dual, which just shut off.
yOU MIGHT TRY LOOKING DEEP INTO THE DEVIL PAST THE CANISTER INTAKE AS THIS IS WHERE THEY CAN GET A HUGE CLOG THAT YOU CAN'T SE UNLESS YOU STICK YOUR HAND WAY IN THE UBE. DO THID WITH THE DEVIL TURNED OFF. CHECK FOR A SHORT IN THE CORD AS WELL BE SAFE FIRST.
Jul 23, 2010 | Dirt Devil M130000 ''i'' Dual Cyclonic...
My dirt devil bagged upright(swivel glide) wont turn on..light on
  • its clogged that is what the light shows is that if your vacuum is clogged then that light will come on and it will shut off, i have the same vacuum and mine does not come on cause its not clogged
Mar 09, 2010 | Dirt Devil SwivelGlide Bagged Upright...
Low Hose Suction, Hose is open.
thanks for the clarification.
since the hose in unclogged, the next place to look is in the body of the vacuum.
there is usually a tight turn in the dirt channel in the base. often you can see the clog if you remove the hose.
the next step is to dissasemble the base and look for the clog.
does the motor sound normal?
is the impeller turning at a normal fast rate?.
Jan 07, 2010 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Jan 15, 2009 | Dirt Devil M110000 Bagless Upright...
I have a Dirt Devil Vacuum that won't start up anymore. It was working, but then it stopped. The tube got clogged up. Now the tube is unclogged and empty and it won't turn back on. It's also hot on the...
Mar 05, 2008 | Vacuums
Dirt devil 12amp,Patent No.6571425
Either it needs a new belt, they stretch and break, then won't turn the brush roll. The dirt inlet by the brush roll is clogged, the hose may have a clog in it, filters are bad. If the hose comes off on one end, is there suction there, is so then the clog is farther down. If no suction, then the clog is in the hose or filter.
Mar 02, 2008 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Dirt devil dual cyclonic bagless vaccum
Did you check the hose and the inlet by the brush roll for a clog?
Feb 16, 2008 | Vacuums
Dirt Devil Reaction Twin Cyclone Upright Vacuum Logo
54 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
