Question about Frigidaire 20.3 cu. ft. Upright Freezer GLFU2067F
Fridigidaire commercial freezer model LFFH2067DW1 serial # WB43731084 The red & yellow light on the lower panel are both on. When I flif the switch to on it continues to buzz, things are melting in the freezer. What do I need to do? Is there a reset button?
3 Suggested Answers
SOURCE: whirlpool upright freezer making buzzing noise and not working
I had a similar problem yesterday. I woke up and the freezer was not working anymore. It would make a buzzing noise and then it would click and shut off. I looked online for some possible solutions. Here is what I did:
I unplugged the fridge. I pulled it out and took off the cardboard backing. I used an air compressor to blow out all of the dust and dirt that had accumulated on the condenser coils. A shop-vac just wasn't powerful enough to pull out all of the dust/dirt. After that, I plugged it back in....and the same thing was happening. It would buzz, and then it would click off. I figured out that the "click" was coming from a starter relay (a small plastic piece attached to the big black compressor). I detached the plug from the relay and then detached the relay from the compressor. The relay was burned out. It turns out this is a common problem with the relay. I replaced the relay for $50 (from an appliance parts store) and put the whole thing back together in about 10 minutes.
I plugged the fridge back in and the compressor started, and now the freezer works better than other. I saved about $400 doing it myself, all in about one hour. And better yet, my wife was very impressed. Not bad for a doctor.
Posted on Jul 04, 2009
  • 18 Answers
SOURCE: freezer is only 6 years old and compressor stopped
Does it have a defrost cycle? If so, it could be the defrost timer is stuck on defrost. If not, unplug it and bypass the thermostat. try it then. Ifit works its the thermostat. Does the com[pressor make a humming noise when it tries to start? If so, it's a bad compressor. Could resolve with a "Hard start kit". Worst case, the compressor is shot and time for a new freezer.
Posted on Nov 28, 2010
Testimonial: "Yes it has a defrost cycle. I will check unplug it and check it out. "
Why isn't it freezing?
Hello friend, thanks for your inquiry!
From the information you have provided your Frigidaire freezer is no longer freezing and all the lights are on. You may need to perform a reset on your freezer and you can do that by disconnecting the power cord for at least ten minutes. If this does not start your freezer would you be able to provide me with your model number? You can locate the model number on your serial tag which can be found on the inside wall. I look forward to assisting your further. -Matt
Feb 28, 2016 | Frigidaire Freezers
My Frigidaire commercial freezer model LFFH2067DW1 makes a loud, almost rhythmic, knocking sound. What can that mean?
Could be a compressor on its way out, a warped or clogged fan could cause similar sound issues, the valve plates in the compressor could be worn causing pressures issues.
Nov 15, 2014 | Frigidaire Freezers
Zanussi freezer red light
make sure the fan runs
Dec 18, 2013 | Freezers
Turn the unit on and it fills up with water,then goes into defrost cycle then into freeze cycle it starts freezing then just cuts off with no lights on board, not even red power light then will try again...
Most all of Hoshi ice makers have power go thru the bin stat first. It sends power to the board and everything then powers up. Start there and get back to me.I will need model and serial numbers to be sure I have the correct wiring diagram for your unit should we need to go any further. Good Luck.
Sep 11, 2010 | Hoshizaki Freezer Commercial Ice Machines...
I need a new part for Hoshizaki Model # KM-500MAE. Help!
Rick at Restaurant Parts and More can get Hoshi parts. Just have model and serial numbers. He takes credit cards. Usually can it parts in about 3 days to your door.
Aug 02, 2010 | Hoshizaki Freezer Commercial Ice Machines...
How old
May I get the model and serial # to help you find out the year.
Jul 02, 2010 | True 49 cu. ft. / 1388 liter Commercial...
Light on freezer
This just means that you have power to the freezer.  It's letting you know it is plugged in.
Oct 11, 2007 | Freezers
Frigidaire 20.3 cu. ft. Upright Freezer GLFU2067F Logo
135 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
