Question about HP LaserJet P3005n Printer
MEM TEST FAILURE REPLACE DIMM 1 for a HP 3800 There is no Dimm in the slot...I replaced the flash memory but all lights come on and the printer just sits there..but when I put the flash memory back in that's what I get ? Is it the formatter ? Will a firmware upgrade help ?
SOURCE: MEM TEST FAILURE REPLACE DIMM 0
Problem for HP LaserJet P3005n Printer MEM TEST FAILURE REPLACE DIMM 0
Posted on Apr 16, 2010
  • 526 Answers
SOURCE: Mem Test Failure Replace Dimm
The biggest problem with the P3005 is the main board. There has been a warranty extension on the P3005 if it is the main board.
it maybe a memory problem too, but unless you added memory, its usually part of the main board.
Posted on Jun 02, 2010
printerman40
  • 170 Answers
SOURCE: WE ARE GETTING
1. Turn the device off and disconnect the power cord.
2. Disconnect all interface cables.
3. Remove the right side panel by sliding it towards the rear of the device until the side slides from the device.
4. Open the access door by pulling on the metal tab.
5. Remove the DIMM from the antistatic package.
6. Hold the DIMM by the edges, and align the notches on the DIMM with the DIMM slot.
(Check that the locks on each side of the DIMM slot are open.)
7. Press the DIMM straight into the slot, and press firmly. Make sure the locks on each side of the DIMM snap into place.
NOTE To remove a DIMM, first release the locks.
8. Close the access door, and press firmly until it snaps into place.
9. To replace the right side panel, line up the alignment arrows and slide the panel toward the front of the device until it latches into place.
10. Reconnect the interface cable(s) and the power cord.
11. Turn the device on.
144-pin dual inline memory module (DIMM)
here's the memory part number/numbers you'll need also:
144-pin 133MHz DDR2 DIMM
Boosts the ability of the device to handle
large or complex print jobs.
32 MB CB420A
64 MB CB421A
128 MB CB422A
256 MB CB423A
Hope this helps and if so please mark fixya
Posted on Jun 25, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: hp laser jet3005n error mem
This means your formatter board has failed. This is quite common on the P3005. You need to call HP support and give them your serial number. They will tell you if it is under their extended warranty. They have a program to cover these defective boards. Just don't know wether your machine will still be under that repair program. In any case be assured it is the formatter board which is under the right side cover. The one that your network/USB cable plugs into. I repair HP printers and have personally seen this exact situation 4 or 5 times.
If your still unsure just Google search P3005 formatter or P3005 replace dimm 0. You will see lots of people with the same issue.
Good Luck and Thank You for using Fixya.
Posted on Aug 19, 2010
BaronVonNuke
  • 1915 Answers
SOURCE: MEM test failure Replace Dimm
This problem is one of two things. If you have additional memory installed, it might be bad. Remove any memory upgrades and trying restarting. If not then it is the formatter that is bad as the onboard memory has failed.
Posted on Mar 09, 2011
What does printer code "mem test failure 1/6
Hello carmen_alley,
This means the memory test process failed due to a bad module. DIMM ( Dual In-line Memory Module ) is the memory of your printer. It is really similar to computer RAM (memory).
If the printer is under warranty I would contact the manufacturer for a repair/replacement. If it is not, I would still contact them and get further information on what DIMM you would need to purchase to replace the bad one.
Hope this helps!
Jun 29, 2011 | HP LaserJet P3005dn Printer
Mem test failure replace dimm 1
As the message says, DIMM 1 failed.
It's pretty straight forward fix for a tech.
So the cost should be minimal for the labor and whatever the
replacement DIMM costs.
Jun 28, 2011 | HP LaserJet P3005n Printer
My printer shows memory error on its screen why?
Mem test failure replace Dimm 0 or Mem test failure replace Dimm 1
If either of the are the messages displayed, the problem lies with the mother board (formatter).
DIMM 0 = On Board Memory - cannot be changed. DIMM 1 = Add On Ram - Can be Changed
Make Sure the printer firmware is up to date FIRMWARE
Most Likely the formatter board would require replacing.
Feb 03, 2011 | HP LaserJet 2420dn Printer
Mem test fail replace DIMM1
This error indicates that either the formatter has failed, or if you have additional memory installed it is bad.
Dec 06, 2010 | HP Laser Jet Printer P3005dn
The printer states mem test failure replace dimm 0, what is this and how much does it cost?
Dimm 0 is the memory that is onboard the Format board, you can't just replace it like a memory upgrade where you would add another dimm. You would have to replace the whole format board, part number Q7848-61006. cost all depends on how much you shop around.
Sep 15, 2010 | HP LaserJet P3005dn Printer
WE ARE GETTING "MEM TEST FAILURE REPLACE DIMM 1" M: 98240 19614
32 MB CB420A
64 MB CB421A
128 MB CB422A
256 MB CB423A
Jun 25, 2010 | HP LaserJet P3005n Printer
Jun 02, 2010 | HP LaserJet P3005n Printer
DIMM 0 is the memory slot under the keyboard.
Apr 15, 2010 | HP Compaq Presario 3005US PC Notebook
Apr 15, 2010 | HP LaserJet P3005n Printer
Printer hangs and gives a message"MEM FAILURE REPLACE DIMM 0"
You would need to replace dimm memory if you have spare one. Or try to remove it and install it again
Sep 24, 2009 | Office Equipment & Supplies
HP LaserJet P3005n Printer Logo
1,999 people viewed this question
Seeker5211
Seeker5211
