Question about Car Audio & Video
Looking for instruction to operate an Alpine MDA-W905JB head unit in a Japanese car I just bought.
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 82 Answers
Go to the store and buy a mounting kit and wiring harness adapter that are for your car. There are alot to choose from and most are universal and come with instructions. You can get these at wal-mart or best buy. The mounting kit is meant to fill in the empty space left by the new aftermarket radio (your alpine). The alpine will have a metal sleeve around it. take this off and put it in the mounting bracket so it is flush. The sleeve will have little triangle shaped tabs on it. Bend these out so the sleeve cant fall out of the bracket or someone will be able to pull out your radio. Remove your stock radio by pulling off the trim around the radio. This is held on by clips, so be careful. There will be a couple of screws holding in the radio. Remove these and pull the radio out. Behind the radio there will be 1 or 2 wiring harnesses plugged into the radio. Unplug these. Then attach the wiring harness adapters you bought. These plug into the stock harness and have wires at the other end that are labeled. Wire the alpine wiring harness into the harness adapters that you plugged into the stock harness. If you want to you can unplug the harness from the alpine and wire it to the harness adapter before plugging it into the stock harness. The wiring diagram should be on the radio. If not the colors are pretty common.
RED = SWITCHED PWR LEAD (IGNITION)
ORANGE = ILLUMINATION
BLACK = GND
YELLOW = BATTERY LEAD
GREY = FNT SPKR RIGHT(+)
GREY/BLACK STRIPE = FNT SPKR RIGHT(-)
WHITE = FNT SPKR LEFT (+)
WHITE/BLACK STRIPE = FNT SPKR LEFT (-)
VIOLET = REAR SPKR RIGHT (+)
VIOLET/BLACK STRIPE = REAR SPKR RIGHT (-)
GREEN = REAR SPKR LEFT (+)
GREEN/BLACK STRIPE = REAR SPKR LEFT (-)
BLUE = PWR ANTENNA LEAD
BLUE/WHITE STRIPE = REMOTE TURN ON LEAD(FOR SUBWOOFER AMPLIFIER)
There may be RCA jack inputs in the back and these are for the subwoofer amp.
There will be a large black cable in the back and this is the antenna wire. Plug in the antenna wire from the back of the stock radio here. Yu may or may not need an adapter for this depending on the size difference between the wire and the hole it plugs into.
**Please note: if your car has a "premium" sound system that comes stock with an amplifier you will need to attach the power antenna lead from the alpine to the remote turn on lead on the harness adapter. If not when you turn on the radio/cd it will not turn on the stock amplifier and the speakers will not work.
I found this out with my 99 dodge avenger which has an Infinity stock radio. You can pop the trunk and look up at the back dash and see the small amplifier.
Once the radio is wired and the mounting bracket is installed, connect the harness adapter as well as the antenna wire. The new wiring harness adapter makes the wiring a little longer so you may have to stuff them back a little bit. Connect the harness from the alpine back into the back of the radio and slide the head unit into the metal sleeve until you hear a click. Before sucuring the mounting bracket and putting the trim back on it is a good idae to try the radio out so if there is something wrong you dont have to disassemble it again. When you buy the harness and bracket it will say on the packaging "nissan 84-94" or "Honda 83-99" or something similar. Look on the back for a complete list of compatable models.
Hope this was helpful. Please rate, and thanks!
Posted on Oct 17, 2010
How do you run the satillie radio and hookup an ipod to this radio (alpine IVA-d310) at the same time?
you can buy either a cable for the i pod or depending on the model of alpine you may need a part to go with it to operate this can be picked up at any car audio place there are also either multiple auxs for your unit for sat radio. some newer units allow you to buy the alpine part to adapt to a sirius or xm part that wires in behind the stereo to give you the operation on your head unit.
Aug 22, 2010 | Alpine IVA-D310 Car DVD Player
Replace my citreon c4 head unit
what year is your car?newer cars 1999 and up the radio wiring harness goes thru the ecm (electronic control module).if that head unit is not supported it wont work correctly.in a bad case senario the head unit could damage the ecm.
Nov 03, 2007 | Alpine CDA-9847 CD Player
Alpine radio works fine, but only searches fm stations from 69 to channel 90. Most stations here start at 90 and go as high as 107.Radio is new, just bought on e-bay. traffic information is on AM!!!...
it sounds like you have purchased a unit that does not operate on our wave length, it sounds American, and all i can suggest is be careful where you buy things from mate, sorry, colin.
Dec 02, 2009 | Alpine MRD-M605 Car Audio Amplifier
Bought a Alpine PDX1.1000. 1 - 8v issue
Hello rsnyder_223,
As long as the gain is adjusted properly for the input, there should be no problems with the amp.
The head unit preamp output is probably a little low or there is too much voltage drop on the RCA's. It doesn't take much of a drop when you are working with such a low level to begin with. That's one reason that Alpine gives you the option to select an input level.
It's also possible that the input sensitivity of the Alpine is slightly high. Electronic components usually have a nominal value and their actual value can range up to 20% from that nominal. But again, you have a gain adjustment to insure that the amp is not overdriven. Make sure that it's set so there's no distortion and you should be OK.
Hope this helps.
Aug 23, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Volume will not go passed 4
The amp requires a compatible Ai-net Alpine head unit to operate it. I bought one too and didnt know this and im still trying to put all of the peices together to create a working stereo system without buying everything all over again.
Nov 25, 2008 | Alpine MRA-F350 Car Audio Amplifier
Alpine cda-w550e
It must be an older unit, because it is not on the Alpine website call Alpine and they will help get you a manual. 1-800-421-2284 Ext.8853
Leadispenser
Aug 26, 2008 | Alpine CDA-7998 CD Player
Alpine cda-w550e manual
I needed a manua for my alpine cda-7897 and went to alpine's website and just type in my unit number under there manual section and there it was in a nice little pdf. file. hopes this helps.
About scheme
Try another repair shop. We repair stereos everyday without schematics.
Sep 08, 2007 | Alpine MDA-7755
MDA779JB Car Stereo
The manual appears to only be available in Japanese. Sorry. http://www.alpine.co.jp/alpine/owners/oml_images/pdf/mda-w779jb_om02.pdf I have however been able to badly translate the japanese for the clock setting - check page 50 of the manual (page 17 of the pdf file). It reads: To set the Time: keep pushing "Disp 1" until you get the time set mode (possibly means 'hold down' not keep pressing) press "Clk Adj" for 2 seconds or more and the time blinks If you push "H" within 5 seconds you can adjust the time. push "M" to change the values, then if you leave it for 5 seconds it is set. The first footnote says this directly translated - sorry I have no idea what they mean on this one (i think carries means saves in this case)- "When liking to adjust to time signal, when ?the time? ?, CT? is pushed after the setting ?amount? indication becomes with ?00?. ?: When indicating which exceeds 30? when ?CT? is pushed, ?the time? it carries" Second footnote says this; You can do this procedure starting from any mode. Hopefully, with the pictures in the manual to show you which buttons they are talking about, this can get your clock set. If so, then if you want to try and translate other parts of the book, just copy and past it bit by bit into; http://translate.google.com/translate_t?langpair=ja|en seems quite good as these things go. Hope this helps, if not please ask again and tell me what you got trying the above procedure. :)
Aug 02, 2007 | Alpine MDA-7755
CVA-1004 head unit set-up
check the cables, it may be one color switched
Sep 28, 2006 | Alpine CVA-1004 Car DVD Player
Car Audio & Video Logo
260 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
