Question about Whirlpool 4396841 Whirlpool Refrigerator Water Filter
We are using a 4396841 Pur filter on our Whirlpool fridge. The filter lasts us about 2 weeks then saturates with sulfer due to our well water. Now the water coming from the faucets do not have a sulfer smell, only the wate coming from the fridge. My question is do we really need a filter? Will it hurt the fridge if we do not have a filter installed? We simply cannot afford to keep buying a filter every two weeks.
2 Suggested Answers
archaeology
  • 662 Answers
SOURCE: I changed my filter, PUR
The vibration is a tiny bit of "water hammer." Previous to your filter change, the water flow was restricted, and therefore incapable of causing water hammer. Now that you've changed the filter, the flow is large enough to cause a little water hammer when you shut off the flow.
How to fix: shut off the flow SLOWLY. Water hammer is caused when the flow of water is shut down quickly. This is just as true with large flows (as in fire engine pump panels), as it is in itsy bitsy
filtered water lines & filter housings.
Posted on May 13, 2011
Diagnostics check say water valve is off
there is two seperate water valves first insure that water lines coming and going to tank are not frozen..if not replace inlet valve on back of fridge
Jan 11, 2014 | Whirlpool 21.8 cu. ft. Side-By-Side...
What water filter Number is used on Whirlpool side by side refrigerator Model ED2FHEXVS
Your filter part number you seek is 4396841.
I hope this helps you.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Nov 03, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
I changed my filter, PUR 4396841 and now it is vibrating when I stop dispensing water. Any suggestions? Do I have it installed correctly?
May 13, 2011 | Whirlpool 4396841 Whirlpool Refrigerator...
I cant believe i cant find the model # of this fridge but anyway , i installed a new water filter a purr #4396841 and did it according to the instructions , did everything but the red light remains, wonder...
The model # is located inside refridgerator door on the upper right side panel.To reset the light you have to open fridge door and by the light there is a button you have to push in the button 5 times in 10 seconds to reset.Hope this helps if so give us a 4 thumbs up. THANKS
Mar 03, 2011 | Whirlpool GD2SHGX Refrigerator
I replaced the water filter in my Whirlpool/Roper side-by-side refrigerator. Now ice maker and purified water (on front of door) don't work. No water is getting to the ice maker. Is it a defective water...
1.CAN YOU TELL IF WATER IS GOING TO THE FILTER, FIRST OF ALL.
2.IF WATER IS NOT GOING THREW THEN THERE IS A BLOCKAGE BEFOR THE FILTER
3. IF WATER IS GOING TO THE FILTER { CHECK TO IF THE FILTER IS IN CORRECTLY}
4.IS THE WATER GOING THREW THE FILTER, IF SO THERE IS A PROBLEM WITH THE KINE FROM THE FILTER TO THE LEVER TOR THE WATER TO COME OUT.
5. ALSO CHECK FOR LEAKS GOOD LUCK
Jun 23, 2017 | Whirlpool 21.8 cu. ft. Side-By-Side...
Whirlpool ref model #ED5PVEXVS00, need filter for this model. We don't know the part number needed or where on the refrigerator that the filter is located. Please help with both
The original part number is 4396841; cartridge T2RFWG2. The filter fits into the grill at the bottom of the refrigerator (nearly centered on the left hand side of the grill). There is a cap covering the filter.
The fridge can be used without a filter if the cap is taken off the old filter and put back into place. For a diagram that includes the filter and grill location see: http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0812046-00001.png . The filter is part 30 in the diagram. The entire set of parts diagrams, leading to parts list and prices are available here: http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Refrigerator-Parts/Model-ED5PVEXVS00/1198/0165000 .
Another on-line source for the filter is: http://www.partstore.com/Part/Whirlpool/Whirlpool/ED5PVEXVS00/Whirlpool/Whirlpool/4396841/New.aspx .
I hope this helps.
Nov 20, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Replaced a waterfilter in my ref with wrong filter model
The new filter you used will not damage anything in the refrigerator, the only difference will be in the fill rate, it may fill slower than you like.
Apr 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice tastes bad from ice maker
Sometimes filters have issues like this even being new , it is located at the bottom kickplate [round] , pick up a new filter -part number 4396841 - install the filter , dump remaining ice in bin out , purge the water through the new filter through water in door for a few minutes and you should be good.
Phil
Apr 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
My new Whirlpool Refrigerator the water and ice still stink
We have the same problem. Started 2 weeks after purchase. (6 months ago). Tech. replaced fliter, worked for another 2 weeks, then water & ice awful again. Tried to live w/ it - ordered another filter a week ago. Replaced & within 24 hrs. problem was back. Called Whirlpool. Said tech who came to my househad written in his report that tap water & fridge water tasted the same. A lie - he agreed w/ me that the water from fridge was bad, & replaced filter which had a musty odor. Whirlpool basically called me a liar but agreed to send another tech to check it out. I will never buy another Whirlpool product & plan to tak this problem as far as I need to in order to get satisfaction. This is ridiculous!
Dec 19, 2008 | Whirlpool Refrigerators
Whirlpool 4396841 Whirlpool Refrigerator Water Filter Logo
76 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
