Question about Dryers
I have a T8423C (Gala Grande) from Miele , dryer and althouht the drum s spinning i get an error that the air is cold. I can clearly see that the area inside the dryer is cold and i have 220V at the resistors. How could I measure the temp sensor ?
    President:
  • 3,074 Answers
Http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Posted on Oct 17, 2010
After washes it displays check detergent. some washes are also not spinning properly and cloths are still quite wet. Can you help I have a miele gala grande w 3000
Hi dear.
Basically you can check fluff filter otherwise you may need to have a technical assist. Fluff filter located on front LHS bottom corner of your machine.. Open plastic cover. Place small bowl under fluff filter area to collect about 2 Lt of water. Slowly turn fluff filter anticlockwise to let it drain remaining water in there.. Then remove it and check for blockage. ( Step by step You can get full instruction from your machine's user manual on cleaning and care section.) If that does not solve the issue you may call Miele to assist you or local repairer. I hope that helps.Thanks.
Jan 16, 2016 | Miele Washing Machines
Miele Softtronic T8423C only blows cold air..
If you are fairly sure that the power is reaching the clothes dryer, and the clothes drum is spinning, unplug the dryer first. Then using a continuity checker check the heating element. very often if the element needs replacing you will notice a break in the coil. Just like a light bulb, the heating element will eventually need to be replaced. The coil is the only source of heat, although it has components that operate it .
Dec 05, 2013 | Miele Dryers
No heat when drying
I have a Miele WT2780 where the fan motor stops spinning. This will stop the dryer from working even though the element heats up. The failure of the fan will not blow the air across the heating element and thus into the drum. New motors fitted are around £400 min. I am never going to buy another Miele - mine failed after 6yrs.
Another problem is the thermostat can trip. This is a small button inside the machine (TURN OFF MAINS ELECTRIC AND UNPLUG FROM WALL then remove the lid) on the right hand side of the alloy centre channel at the top. It has two wires connected to the switch and in the centre there is a small black button. Press it firmly and it will heat up again. If this keeps tripping then the air duct could be blocked with fluff. This is my next task as mine now trips more frequently so will post back here with instructions.
Update 12/10/16 - problem returned so dismantled top of air duct having removed the lid - tight torx screws - inside chamber was full of fluff. Removed and cleaned - all good now!.
Jan 04, 2013 | Miele WT 2780 Front Load Washer
TD514 TUMBLE DRYER POWERS UP OK DRUM DOES NOT SPIN TURN DRUM SLIGHTLY WILL START TO SPIN
Hi, Motor is going bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 09, 2011 | Miele T8005 Tumble Dryer
Dryer spins and drum turns, but only cold air c...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Kenmore 800 7982 Dryer
Miele w3033 tech fault f63. what to do?
i have washing machine miele gala grande w 3000.and i have a tech fa ult f63.what is this?
Jul 04, 2009 | Washing Machines
MIELE T 1520
I guess you already fixed it, sorry for the last replay,
however, if the belt did not spin that means that either the belt is slipped out, the motor had blown, or there is a problem with the drum bearing. Usually you need a technician to fix this.
Regards.
Oct 02, 2008 | Miele Novotronic T1520 Electric Dryer
The drum is not spinning on a miele dryer, model T5206, the appliance is generating heat, the brushes are intact and also the belt on the centre of the drum is intact.
the tensioning device [ spring] is weak or the belt is stretched beyond its usable length. if a new belt has been installed, the tech didn't put the belt on the correct side of the tensioning device. it is possible to install it wrong.
Jun 19, 2008 | Miele Dryers
Dryers Logo
237 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
