I adjusted screen resolution on my HP mini notebook now when I turn on I get to Window XP then screen goes blank after that.
    Brigadier General:
  • 10,406 Answers
You selected a device-resolution that your LCD screen does not support.
Restart your computer, and immediately press the 'F8' key until you see the Windows "start-up" menu (white text over a black background). Select "Start in VGA mode" or "Start in Safe Mode".
Reset the device-resolution to a "low" value, e.g. 800-by-600, that is supported. Later, you can "tune" the resolution to the "best" value.
Posted on Oct 17, 2010
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
How can i change my display settings on my inspirion mini i cant change my screen resolution
Just right click on a BLANK area of screen and select the graphic properities from there
depending on the operating syetem vista and windows 7 will actually offer you the "change resolution" option near the bottom of the pop up when you do that.
Feb 04, 2011 | Dell Inspirion Mini 884116022442 Notebook
I adjusted resolution on my HP notebook now when I turn on cant see screen. Please help
Hi Jess,
Boot the computer in SAFE MODE by Restarting the computer, and the moment its on keep tapping the F8 key untill you see a screen saying "Windows Advanced option...".
1. Select Safe Mode using the keyboard arrow key and hit enter.
2. This will load all basic drivers to start safe mode operation.
3. Go to Display Properties (WindowsXP) or Display Settings (Windows Vista) by right click on empty blank space on Desktop, then select Properties(Windows XP) or Personalize(Windows Vista).
4. Then change the resolution by sliding the Low to High slider bar. Do not press "OK" or "Apply" at this time.
5. Instead, click on Advanced Settings, and then click OK. Windows in Safe Mode will change the screen resolution according to new settings, and prompt a "Monitor Settings" dialog box prompting that desktop has been reconfigured, with countdown timer. Click on Yes to keep the new settings.
6. Alternatively, simply click on Advanced, go to Adapter tab, then click on List All Mode. Select a mode with screen resolution size and color mode that you prefer, and click on OK. Windows will apply the new resolution size and color quality on Safe Mode too.
Regards
Riztech
Oct 17, 2010 | HP Mini 1000 Netbook
How to adjust screen resolution with external monitor/hp pavillion dv 2000 laptop
1.Right-click on an empty area of your desktop screen
2.Left-click on Properties at the bottom of the drop down list
3.Left-click on Settings in Display Properties window.
4.Left-click on the 1 monitor icon to adjust the screen resolution for the HP dv2000 LCD screen.
Left-click on the 2 monitor icon to adjust the screen resolution for the external monitor.
5.Go down to where you see the heading - Screen Resolution, and the slider underneath the heading.
Left-click right on the slider, hold the mouse button down, and slide to the Right to increase resolution, to the Left to decrease resolution.
Oct 19, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp mini blank screen
use the graphics media accelerator driver this will adjust the display of screen and adjust the resolution...try
Jun 20, 2009 | Computers & Internet
Blank/Black Screen Asus PC 4G
When you first turn on the computer, start tapping the F8 key to bring up the safe mode screen. You have a very short window in which to press the F8 key before XP loads, so it is possible to miss it. If this happens, just restart it and try it again. Once you are on the safe mode screen, select the enable VGA mode. This will boot your computer to a default 640 x 480 resolution so you can change it back to normal.
Thanks and please don't forget to give this solution a fixya rating.
Jan 26, 2009 | ASUS Eee 4G Notebook
Dell C400 Resolution Problem
Boot into BIOS and go to the Video card setting, that sould fix it
Jan 26, 2008 | Dell Latitude C400 Notebook
Aquos lc-26ga5u to mac mini
Adjust resolution on your mac mini to something the TV supports. Usually 1080 vertical resolution or below
Nov 07, 2007 | Sharp Aquos LC-32D40U Television
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
