Question about Kenmore Dryers
My Kenmore dryer makes a grinding noise while the drum is turning. There is heat; just a noise that sounds like metal on metal when the drum is turning. I don't want to allow the dryer to run causing more damage. What is it and how do I fix it without having to pay someone else to fix it?
    Top Expert:
  • Kenmore Master
  • 75,822 Answers
More than likely the drum bearing is defective. this job is not really for the amateur as the entire drum assembly of the dryer must come out, most late model Kenmore dryers are made by Frigidaire. Below find a link to the factory service manual, parts can be purchased at the time for the large factory repair manual to load, it is a PDF
http://current.frigidaire.com/tip/servicecd/Content/Laundry/5995373155.pdf
Go here for parts
http://www.appliancepartspros.com/
Posted on Oct 17, 2010
Why is the dryer making a squilling sound
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Aug 18, 2014 | Kenmore Elite He5T Dryer Heating Element...
My kenmore 84052 is making a squeaking noise
DRYER MAKES NOISES.
The pulleys or rollers. Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density gear grease to re oil/grease them.
The bearings by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The belt loose or worn can make funny noises
Aug 14, 2014 | Kenmore 84052 Dryer
Drum turns but sounds like a small metal object, possibly a screw, banging around inside . Continued to use and now sound is much louder and sounds like a bigger object.
DRYER MAKES NOISES.
Jun 27, 2014 | General Electric Profile DPSR610EGWT 7.0...
Kenmore he4t makes a whinning noise when it is not running
DRYER MAKES NOISES.
The blower:
The bearings:
May 16, 2014 | Kenmore Elite HE4 Electric Dryer
I have a kenmore 70 series dryer and it has been making a metal on metal sound as it turns for the past couple of days. Do I change bearings or rollers or what? It is heating up fine and was working...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Apr 05, 2011 | Dryers
Dryer making a grinding noise when turned on. How do you get the top off to check the barrel motor?
Clanging Sound
1. If the noise coming from your dryer can be described as a clanging sound, the solution is probably well within your grasp. This common sound is typically the result of loose debris accidentally put in with the load of laundry. Change may be left in pockets of pants or other objects may be dropped in the laundry basket by children --- perhaps a toy car. The objects may not be noticed when put into the wash, and the water in the washer may have dampened the sound. Simply remove these items, and restart the dryer to resolve the issue.
Sometimes the clanging is from snaps or buttons that are actually part of the clothing. If you are drying a jacket with metal snaps or another garment with metal attached, you should expect this clanging sound as they tumble and strike the inside of the dryer tub.
Humming or Whistling
2. Many Roper dryer models are equipped with a safety feature known as a lint signal, which is usually a light that often accompanies a warning signal, telling the machine owner that the lint trap has become clogged. When the dryer cannot pull adequate air through the lint filter, it can overheat and become a fire hazard. The warning alarm may sound like a hum or whistle to get your attention. Look at the lint signal light, clean out the trap and the noise should stop.
Thumping or Grinding
3. If the noise you are hearing can be described as a thumping sound or a metal grinding sound, the device that turns the dryer drum, known as the drum rollers or glides, can be worn out. As the drum turns, there may be a constant and rhythmic thump each time the drum rotates. A severely worn or broken roller could cause the metal of the drum to rub against the metal housing of the machine, causing a louder grinding noise. The rollers will need to be replaced to remedy the problem.
Squeaking or Squealing
4. Most dryers work by using belts to turn the rollers, which in turn make the drum rotate and tumble the clothes dry. When these belts get loose, a worn belt or a malfunctioning tensioner spring may keep the belt tight. In either case, belt slippage may occur and will produce a squeaking or squealing sound that is easily recognized. The problem is likely to be the tension on the belt since most belts will break before wearing out to this degree.
Feb 24, 2011 | Whirlpool Dryers
The dryer is making a thump/thud noise as the drum turns. The dryer works fine but the noise sounds like something hitting everytime the drum goes around. Could this be the belt going out?
heatman101
Asker
Jan 02, 2011 | Kenmore 83142 Electric Dryer
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Jan 21, 2009 | Kenmore 63942 Dryer
Dryer Making a Grinding Noise
The grinding noise is probably a worn out roller or the central bearing in the back. The center of the drum in the back has a part called a bearing which screws onto the back of the drum and has a stub which sticks out. The stub then goes into a bearing hole in the back panel of the dryer. If you are handy, you could try to replace yourself. I did it once. While you are at it, check the drum belt which goes around the drum and makes it spin. Replace it if looks like it has wear.
Feb 01, 2008 | Kenmore 63942 Dryer
Dryers Logo
83 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
